    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree287Likes
Old 10-14-2016, 04:11 AM   #3766
I have read and checked build videos of the B6 and it seems like it dosent need any lube on the gears so i skip that since i dont have any diff lube at home now.
Sweddriver is offline   Reply With Quote
Old 10-14-2016, 04:39 AM   #3767
If you don't want to use the black grease there, I think shock oil will be better than nothing on the transmission gears.
mushroomed is offline   Reply With Quote
Old 10-14-2016, 09:18 AM   #3768
Originally Posted by Ericc View Post
Ok so I got the lunsford motor screws for my laydown. The only thing is that the driver rubs against the side rail when I try to screw the bottom screw. Anyone else have this issue? I guess it's because the lunsford screws have a 2.5mm hex. And I guess the only fix is to dremmel down a bit of the side rail.
get one of these and you'll be able to adjust the screw at an angle
https://www.amainhobbies.com/protek-...k-8209/p212265
Allen Drebi is offline   Reply With Quote
Old 10-14-2016, 03:22 PM   #3769
mellow's Avatar
Trader Rating: 17 (100%+)
Just dremel down the side rail, or buy a ball end driver. You'll have to do this regardless if you have lunsford screws or not.
"It'd be a lot cooler if you did."
mellow is offline   Reply With Quote
Old 10-14-2016, 06:52 PM   #3770
Trader Rating: 68 (100%+)
It's frustrating to need special tools or modify original parts to get to motor screw.
Seems strange to me that AE didn't make a notch as part of the design.
Pinebox is offline   Reply With Quote
Old 10-14-2016, 07:08 PM   #3771
Silverstonev8's Avatar
Not really a special tool... More so a basic version...
Silverstonev8 is offline   Reply With Quote
Old 10-14-2016, 10:36 PM   #3772
aeRayls's Avatar
Surely you're not suggesting he use the wrench that comes IN THE KIT? That would be too simple of a solution.
aeRayls is offline   Reply With Quote
Old 10-15-2016, 12:42 AM   #3773
thecman26's Avatar
Trader Rating: 98 (100%+)
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 10-15-2016, 01:47 AM   #3774
I've noticed some of the factory drivers are putting a 1 mm shim between the front bulkhead and chassis. What effect does this have on the car, and why are they doing it?
crowbar1 is offline   Reply With Quote
Old 10-15-2016, 07:51 AM   #3776
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
This is why AE buggies are awesome. So much aftermarket support.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 10-15-2016, 08:39 AM   #3777
Anybody find a replacement for the upper shock bushings? Would like to find something tighter and longer lasting than the factory part.
belewis01 is offline   Reply With Quote
Old 10-15-2016, 09:05 AM   #3778
Trader Rating: 16 (100%+)
I think either Avid or M2C make delrin bushings.
MX304 is offline   Reply With Quote
Old 10-15-2016, 10:44 AM   #3779
abailey21's Avatar
Trader Rating: 36 (100%+)
Pretty sure Schelle does too
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 10-15-2016, 11:22 AM   #3780
nodrog's Avatar
I'm following a setup sheet and for the rear hub spacing it says 'forward' does that mean the hub forward and shims to the back or shims to the front (forward).
I'm guessing it's hub forward, shims to the back..shorter wheel base. It's the Ray Munday NSW State sheet
nodrog is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
