    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree287Likes
Old 10-12-2016, 07:50 PM   #3751
Or the Blue one:
https://www.amainhobbies.com/protek-...k-7821/p480541
Yokomo BD8 x 2 , BD7 2016, YRX-12, Tamiya TRF419, Associated B6, B6D, B5M Factory Lite, B64D, B44.3, RC8B3, RC8B3e
My Outdated R/C Car collection:
Associated B44, Associated NTC3, Tamiya TRF415, TRF415 MSX MRE, TRF416X
190mph is online now   Reply With Quote
Old 10-12-2016, 07:52 PM   #3752
tom2tone's Avatar
Trader Rating: 98 (100%+)
Originally Posted by MX304 View Post
Thank you!
TEKNO EB48.3 / ET48
AE T5M & B6
Tekin / AKA / Hitec / SMC / Futaba
Trains and Lanes Racing http://tandlracing.com/
Dunn Raceway Park http://drprc.com
tom2tone is offline   Reply With Quote
Old 10-12-2016, 09:52 PM   #3753
speaking of servo horns...whats the correct alignment when fitting? i only have experience with the TLR22 which needed to be slightly left
RC10 B6
LC Racing truggy,
Tamiya lunchbox, Blackfoot 3
"where am I going, and why am I in this hand basket?"
Lunchie is offline   Reply With Quote
Old 10-12-2016, 11:52 PM   #3754
abailey21's Avatar
Trader Rating: 36 (100%+)
Straight up and down
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 10-13-2016, 07:17 AM   #3755
WOW this page looks like the font of all knowledge for the B6
Im over in good old England, just upgraded from a fully tricked up B5m to a B6 for our winter indoor carpet racing season
loving the car and very impressed with the overall build quality and how well it seems to be thought out
TonyCooperUK is offline   Reply With Quote
Old 10-13-2016, 07:26 AM   #3756
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
so far I am liking it from what I am seeing, I need to still give mine the good ol full teardown and rebuild since its used (however, looks very good) but happy so far.
Mine came with those Kashima or whatever they are called shocks and the stock bodies still, anyone point keeping the stock bodies around (like say, certain, conditions, etc)?
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Cain is online now   Reply With Quote
Old 10-13-2016, 08:21 AM   #3757
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
spares? tuning (pre build shock packages), they have very little resale value....
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 10-13-2016, 11:19 AM   #3758
Super Moderator
racer1812's Avatar
Trader Rating: 30 (100%+)
I would say NO resale value. So Cain, just send them to me so I can do as Untamed Kitty said and build a spare set of shocks for testing.
Stand for the flag, kneel for the fallen.
Thank you to all of our service men and women!
racer1812 is offline   Reply With Quote
Old 10-13-2016, 10:00 PM   #3759
JsK
JsK's Avatar
Keep them for a carpet SC build.
JsK is offline   Reply With Quote
Old 10-14-2016, 12:12 AM   #3760
Ok so I got the lunsford motor screws for my laydown. The only thing is that the driver rubs against the side rail when I try to screw the bottom screw. Anyone else have this issue? I guess it's because the lunsford screws have a 2.5mm hex. And I guess the only fix is to dremmel down a bit of the side rail.
Ericc is offline   Reply With Quote
Old 10-14-2016, 12:34 AM   #3761
Anyone using the anti roll bars? Suggestions on which to use for carpet? There's 3 different ones for the front and rear. Thank you.
EDIT: NVM. I see it really depends on the track itself.
LVNeptune is offline   Reply With Quote
Old 10-14-2016, 03:24 AM   #3762
Started to build my B6 today and now when i started to build the
diff the manuals says "Add a drop of Diff Lube (#6591)" i have looked in the box but cant find it?
Should it be included in the kit? Or can i use the included Black Grease instead or some other grease?
Sweddriver is offline   Reply With Quote
Old 10-14-2016, 03:34 AM   #3763
In the B6D kit, the clear diff lube should be included in a small tube the same size as the one for the black grease. I expect that the B6 kit with the gear diff may not come with the diff lube. If it is just calling for the drop of diff lube for the transmission gears the black grease will be okay.
mushroomed is offline   Reply With Quote
Old 10-14-2016, 03:42 AM   #3764
Ok thanks for fast answer, i have checked every bag and itīs not there so it looks like the clear diff lube isnt included in the B6 kit only B6D is it because the geardiff doesnīt need any lube on the gears?
Old 10-14-2016, 03:58 AM   #3765
The internal diff gears will be lubricated by the diff oil, and yes you can still lubricate the outer gear of the diff (with a dab of grease, or if you get the diff lube).
Currently Active Users Viewing This Thread: 5 (4 members and 1 guests)
05PSD, asadrian, Bull_Dog
