    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree287Likes
Old 10-11-2016, 08:44 PM   #3736
is there a t6 coming out
pauldiebert is offline   Reply With Quote
Old 10-11-2016, 08:56 PM   #3737
anyone know the weight difference with the kit plastic rear hubs vs. the aluminum hubs?
M2126 is offline   Reply With Quote
Old 10-11-2016, 09:05 PM   #3738
5tone's Avatar
Default T6 released
Probably,
but I hope it will be after the 4wd.
XB4 17' will be released soon and I don't wanna come to the dark and expensive side
5tone is offline   Reply With Quote
Old 10-11-2016, 09:56 PM   #3739
Am i missing something???.
The build manual says the front camber link shoild be adjusted down to 22ish mm yet the shoulders of the turnbuckles are 28mm long?
Lunchie is offline   Reply With Quote
Old 10-11-2016, 11:35 PM   #3740
abailey21's Avatar
Trader Rating: 36 (100%+)
download the manual off the website, there were a couple McTypos on the paper copies
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 10-12-2016, 06:20 AM   #3741
The ball cup is the limiting factor on how short the camber link can get not the threads on the turnbuckle, alot of cars are this same way.
Tijuana_Taxi is offline   Reply With Quote
Old 10-12-2016, 07:05 AM   #3742
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
I am curious as well on the VRP pistons in particular the "Euro" style ones if anyone has run them.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 10-12-2016, 07:21 AM   #3743
Has anyone used the titanium turnbuckles from their B5m on their B6? Any issues with them being too long?
MrLean is offline   Reply With Quote
Old 10-12-2016, 07:53 AM   #3744
The B5M buckles work fine on the B6. The B5M buckles are slightly longer and you'll have less thread showing when you install them on the B6
Allen Drebi is offline   Reply With Quote
Old 10-12-2016, 03:03 PM   #3745
As a matter of fact some B5M parts fit the B6D. Some not all of course.
A racer let me borrow some B5M parts so I could finish racing the B6D for the night, of course I gave him his parts back when we got done racing.
Associated B6 "Dirt Version" latemodel, Team Losi Racing 22T 2.0 Bomber Truck.
Team Losi Racing 22 2.0 2wd Short Course Truck,Duratrax 835e Brushless 8th scale Buggy,
Stock Slash, B4.1 latemodel(retired), T4.2 Factory Team BOMBER CAR
Castle Creations( Since April 2016)
bmag5000 is offline   Reply With Quote
Old 10-12-2016, 04:57 PM   #3746
Logi Maker's Avatar
Trader Rating: 49 (100%+)
I always put the diff screw head on the same side as the slipper nut so I remember what side it is on...
More focus on driving will result in less broken parts for the most part...
B6 with laydown is the new B5 with 3 gear...
Now I am all caught up...
Kyle Predmore
FB AE Fanboy/Insta @ae_fanboy
Sticky Kicks RC\Prolevel RC\MIP\Schelle
Logi Maker is offline   Reply With Quote
Old 10-12-2016, 05:01 PM   #3747
Logi Maker's Avatar
Yes.
Kyle Predmore
Old 10-12-2016, 05:10 PM   #3748
Brit_racer's Avatar
Trader Rating: 130 (99%+)
Just finished a B6 Box art body
Official Team Associated B6 &amp; B6D thread-b6-box-art-.jpg   Official Team Associated B6 &amp; B6D thread-screen-shot-2016-10-12-6.58.08-pm.jpg
freezeframe007 likes this.
Rc10B5m, Serpent SRX4, Xray XB2, T5m, RC8B3e, RC8T3e
Innovation Raceway
Brit_racer is offline   Reply With Quote
Old 10-12-2016, 07:31 PM   #3749
tom2tone's Avatar
Trader Rating: 98 (100%+)
Hey guys.. Just picked up a new B6 kit and started the build. I bought a Hitec HS-5565MH to run in the buggy. My local hobby shop recommended it. Anyways, what are the alternative aluminum servo horns out there that will fit?
I wanted to just buy the AE aluminum horn but they only come in 23 or 25t and hitec is 24t.
I tried to make the blue aluminum horn work that comes with the servo and its too tall and hard to space correctly.
Thanks!!
TEKNO EB48.3 / ET48
AE T5M & B6
Tekin / AKA / Hitec / SMC / Futaba
Trains and Lanes Racing http://tandlracing.com/
Dunn Raceway Park http://drprc.com
tom2tone is offline   Reply With Quote
Old 10-12-2016, 07:47 PM   #3750
Trader Rating: 16 (100%+)
Thanks!!
https://www.amainhobbies.com/protek-...821-bk/p480542
MX304 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 8 (4 members and 4 guests)
CCristo, Cday, hamustar, Rotten
