    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree308Likes
Old 05-06-2016, 06:30 AM   #361
Trader Rating: 16 (100%+)
Originally Posted by Gearhead82 View Post
That can only be done with the laydown trans.
Thus why I think it will be the first mod someone will try. That or a 3D printed 4 gear setup for the dirt car.
MX304 is offline   Reply With Quote
Old 05-06-2016, 08:01 AM   #362
Logi Maker's Avatar
Trader Rating: 49 (100%+)
[QUOTE=Mxer210;14520313]
Originally Posted by Logi Maker View Post
You'll be at TRCR for the JCon race? Me too!
But that is awesome, how do you know it will be announced next week? Can't wait to get one ordered for my B6!
Yes... I will be making an appearance in the low main of stock buggy with my outdated 1500 gram B5m and an appearance in the lower main of 13.5 4W with my BJ4 v44.3..
My privateer/Fanboy part of the team is starting to pay off...
Kyle Predmore
FB AE Fanboy/Insta @ae_fanboy
Sticky Kicks RC\Prolevel RC\MIP\Schelle
Logi Maker is offline   Reply With Quote
Old 05-06-2016, 08:05 AM   #363
tsair's Avatar
Originally Posted by bmag5000 View Post
The new B44 might be called the B64.
I thought that was the new Nintendo.
Razor RC blog:
http://razorrcblog.blogspot.com
http://youtube.com/c/RazorRC
tsair is online now   Reply With Quote
Old 05-06-2016, 08:18 AM   #364
Gigasipke's Avatar
This is already listed as an option in the Spec PDF from AE, no need to print one.
4-gear standup transmission available as option
https://www.teamassociated.com/pdf/c...0B6D-90012.pdf
-T5M (13.5), - B6D (17.5)
-Mad Dogz Hobby Team Driver
https://youtu.be/Rg4Jlid5dFo
Steve Aldous
Gigasipke is offline   Reply With Quote
Old 05-06-2016, 08:43 AM   #365
Jmuck69's Avatar
What's confusing is Kody said the shacks cannot be mounted in front of the A arm on the D model just the carpet version yet the features list says it can. hmmmmm must be a typo.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 05-06-2016, 08:51 AM   #366
I think it's the transmission that dictates whether the shocks can be mounted in front or not. So I think technically you can move the shocks forward on the B6D, but you'd have to have the laydown installed. So their spec sheet is either slightly misleading (needs an asterisk), or it's a typo like you said.
Gearhead82 is offline   Reply With Quote
Old 05-06-2016, 08:57 AM   #367
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
correct. you can, but you need the laydown tranny.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 05-06-2016, 10:15 AM   #368
I hope someone can clarify this. Why would the change in trany mean that the shocks can't be mounted in front? The chassis is the same so the outdrives should be in the same location right? Well if that is the case then all that one would need to do is to make a brace that attaches the transmission to the tower? I have to take a better look at the pics again.
jneg is offline   Reply With Quote
Old 05-06-2016, 10:19 AM   #369
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
Look at the top down picture....Im going to guess that the gear cover is keeping you from moving the shocks to the front of the arm in B6D config...That and based on the location of the tower on the B6D trans, you would need to space the shocks quite a bit forward at the upper shock mount.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 05-06-2016, 10:33 AM   #370
LOL i completly forgot about the gear cover
Old 05-06-2016, 10:36 AM   #371
Just took a look again like you said and they will not fit. Thanks for clearing that up for me.
Old 05-06-2016, 10:45 AM   #372
I dont think the B6D transmission case even has the ability to move the tower forward
Old 05-06-2016, 11:55 AM   #373
Pinkz's Avatar
will there be a rear motor option for this buggy? just wondering, thinking the B5 will be dropped?
It rubs the lotion on its skin or else it gets the hose again.....Yes, it will, Precious, won't it? It will get the hose! https://www.youtube.com/watch?v=cyn0DVSn96I
Pinkz is offline   Reply With Quote
Old 05-06-2016, 11:59 AM   #374
I think the B5 will be around for awhile. The B5M series is discontinued now on the AE website but the B5 is still listed as a current buggy.
-Ryan-
TLR 22 4.0SR
CTRJ is offline   Reply With Quote
Old 05-06-2016, 12:01 PM   #375
Jmuck69's Avatar
Nope, RM is dead.
Flamming to begin in 3...2....1....
B6D | B64D
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
frankf
