    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree287Likes
Old 10-10-2016, 05:29 PM   #3676
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
Originally Posted by Scargoes View Post
I'm a crappy driver and have yet to break my shock towers.
Weird...the internet tells me that's impossible.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 10-10-2016, 05:41 PM   #3677
OK I will probably regret this comment but the carpet track I race at probably has a front tower on average that gets fractured each race day, not broke fractured. In AE's defense there is a weird jump that's throws you funny sometimes. Yes they're getting broke from crashes, bad crashes I don't think so. Here's my question why didn't AE just make a plastic tower version also?
jswo is offline   Reply With Quote
Old 10-10-2016, 05:45 PM   #3678
Super Moderator
https://www.teamassociated.com/contact/
They make race cars...the car is plenty durable. You start making everything out of plastic you create flex
Old 10-10-2016, 06:01 PM   #3679
I get that also I'm not a engineer just not sure a plastic tower would add that much unwanted flex. Thanks for the reply
Old 10-10-2016, 06:22 PM   #3680
Same, I've had some spectacular crashes and my towers are fine. I took a look at the AE towers compared to the Schumacher towers and there's is actually more material on the AE towers. Never broke a Schumacher tower either.
Bill
AE SC5M / Viper VTX10R & Maclan 10.5
Schumacher KD and KC / Maclan MMax Pro & MMR Team Edition 17.5
Schumacher KF2 / VTX 10R & MMR 17.5
Schumacher K2 / MMax Pro & MMR Team Edition 13.5 /// Airtronics MT-4
Riverbluff is offline   Reply With Quote
Old 10-10-2016, 06:31 PM   #3681
I race carpet not sure if that makes a difference
Old 10-10-2016, 06:47 PM   #3682
Seems like a weak point. My B6 front tower lasted quite some time until a marshal blocked my view for a second and I tagged the wall at fairly slow speed. I'm fine with it, but the towers could be a bit beefier.
mx836 is offline   Reply With Quote
Old 10-10-2016, 06:58 PM   #3683
Anyone know the admins on rc10b6 nation facebook page? They dont seem to be approving my join request
Lunchie is offline   Reply With Quote
Old 10-10-2016, 07:10 PM   #3684
Trader Rating: 18 (100%+)
Do those of you wanting a plastic tower really think associated didn't do testing with plastic towers? Of course they did and in the end they decided on carbon fiber ones. Cars today are much more durable than cars of years before. But every car will break somewhere. It's part of racing. These aren't weak towers by any means. Just accept it and move on.
Chris Brown is offline   Reply With Quote
Old 10-10-2016, 07:10 PM   #3685
I'm in the group but don't know any admins =/
LVNeptune is offline   Reply With Quote
Old 10-10-2016, 07:26 PM   #3686
Phillip F's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Matt Trimmings View Post
I have also seen zero issues with the stock towers. Club days have 40-50 buggies with a good portion of those being b6's. You must need some practice instead of spending money on hop ups....
I break during practice too.
Phillip F is offline   Reply With Quote
Old 10-10-2016, 07:39 PM   #3687
Super Moderator
Proves my point.
Old 10-10-2016, 08:26 PM   #3688
It really doesn't... Just because you haven't seen it doesn't mean there isn't a problem.
Old 10-10-2016, 09:20 PM   #3689
tsair's Avatar
Carpet is so much harder on your cars than dirt. All that plywood doesn't give.
Razor RC blog:
http://razorrcblog.blogspot.com
http://youtube.com/c/RazorRC
tsair is offline   Reply With Quote
Old 10-10-2016, 09:35 PM   #3690
On a separate note, why is AE confusing the heck out of consumers?
The B6 uses the gullwing B6D arms...
The B6D uses the flat B6 arms...
It makes it confusing when ordering parts. You are ordering a B6D arm for your B6 and a B6 arm for your B6D ? Why?
Currently Active Users Viewing This Thread: 7 (2 members and 5 guests)
ryanwi1113, SevetS
