    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree287Likes
Old 10-09-2016, 01:14 PM   #3646
Eli
Eli's Avatar
Default X-rings
How much life are you guys getting out of a set of X-rings for you car? Is it rather short or on the same set for a little bit of time with no noticeable amount of stiction from them?
I picked up a second hand pair of kashima coated shocks and have gone through 2 sets of x-rings in about 5 weeks. This last set was put in as i was installing the FT shock bushings and removing the stock black shock bushings. I was hoping to re-use the x-rings as they were about 2 weeks old at the max but i noticed they had swelled a good amount already and had a lot of stiction, so much that it would make the car not drive correctly.
Maybe it is possible that now with the FT machined bushings i will gain some extra life out of them. I have heard there were some bad batches of these shock bodies as well. Currently my car is sitting upside down after racing yesterday and im tempted to just drain the shock oil until next race day.
I was gonna wait a couple more weeks to post this question but figured it would be a good break from diff nuts.
Eli Westrup - SDRC Raceway - B6D - SC5M - B64D ALL FOR SALE!
Eli is offline   Reply With Quote
Old 10-09-2016, 01:33 PM   #3647
Default Running a stick pack didn't affect my handling of this car.
I actually thought it would handle terrible with a stick pack.
Now if I got the laydown transmission I'd have to run a shorty.
Now granted I raced it on dirt oval and not offroad.
bmag5000 is offline   Reply With Quote
Old 10-09-2016, 02:39 PM   #3648
omarwashington's Avatar
What gearing are you guys starting with for 17.5? Spur.
RCCARS!
omarwashington is offline   Reply With Quote
Old 10-09-2016, 03:26 PM   #3649
69/30 for 17.5 with a shortstack fantom rs motor
I get a few weeks out of x-rings ..They do swell. Did you use green slime,or the like when building shocks?
hyperdive08 is offline   Reply With Quote
Old 10-09-2016, 03:38 PM   #3650
Eli
Eli's Avatar
Nope, didn't use anything other than shock oil on the o-rings.
Old 10-09-2016, 03:42 PM   #3651
xyzracer's Avatar
Use the green slime like mentioned above, it kind of puts a seal on the xring so it doesnt soak up the oil and swell near as fast.
xyzracer is offline   Reply With Quote
Old 10-09-2016, 04:00 PM   #3652
Eli
Eli's Avatar
Ill go back to using it. I stopped since i wasn't sure how much good it was doing in the past. Thanks guys!
Old 10-09-2016, 04:23 PM   #3653
Originally Posted by RCBuddha View Post
I've been running TRF spring perches on my AE shocks on both the B5m and now the B6. They are 0mm also and match the blue on the AE shocks already.
Edit: Should have clicked the link before posting. Looks like Exotek has them available in blue also.
mx836 is offline   Reply With Quote
Old 10-09-2016, 05:02 PM   #3654
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
I've used the protek blue stuff and it was horrible. Incredible amount of stiction. I have been using just shock oil the past few weeks and it's been good. I wish the xrings were a bit better....the tlr black xrings are better imo.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 10-09-2016, 05:23 PM   #3655
Eli
Eli's Avatar
Good to know Matt! Also the TLR rings are for a larger shaft? I have some friends with 22's and they are on their original set of o-rings still.
Old 10-09-2016, 05:58 PM   #3656
Super Moderator
Exactly....the tlr rings wont transfer over to the ae shocks . I was just mentioning that i thought the xring material was better quality.
Old 10-09-2016, 06:07 PM   #3657
Eli
Eli's Avatar
I was just confirming incase by some chance they could work but was doubtful as I've heard they are for a 3.5mm shaft.
Old 10-09-2016, 08:01 PM   #3658
Trader Rating: 32 (100%+)
OK guys my B6D is on the way with lay down transmission order too our local track is mid/high grip my question which one to be run 3 gear stand up or 3 gear lay down. any input kindly appreciated. RJ
raved007 is offline   Reply With Quote
Old 10-09-2016, 08:09 PM   #3659
Eli
Eli's Avatar
Laydown for sure
Old 10-09-2016, 08:12 PM   #3660
1/4milecrazy's Avatar
If you have both coming it wont hurt to run both. I got the chance to drive a stand up car yesterday (Mine is lay down). Lap times were verey similar between both drivers with both cars. But they had a VERY different feel on track. The stand up car, with the way it was set up, seemed like it was more point and shoot, but had the forward grip, and braking grip, to drive it hard that way. Mine seemed to have more corner speed. The cars were both geared differently that seemed to fit the driving style accordingly. Mine was gear more for top speed, so acceleration suffered, where the other car clearly out accelerated mine, mine had more top end. Which like I said, the cars were geared the way they seemed to want to be driven. In fact, I am gonna build a mod car one of these days and I am gonna copy that setup exactly.
1/4milecrazy is offline   Reply With Quote
