    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree286Likes
Old 10-06-2016, 05:08 PM   #3601
thecman26's Avatar
Trader Rating: 98 (100%+)
Originally Posted by awtwac View Post
Thanks, but I did come across that page already. Looks like none of them tried to make the gear diff work on dirt/clay. Messaged received loud and clear...
I tried my dangest to get a gear diff to work in my Durango SCT, went to ball diff and it was a completely different truck. Never tried it in a buggy though. A local AE sponsored guy tried it in the B5M and wasn't terribly excited.
Have a buggy on the way and may be stuck with the gear diff for a lil while.
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 10-06-2016, 05:11 PM   #3602
Has anyone tried runnning only 2 spiders instead of 4 in the gear diff? What weight diff oil are you using with only the 2?
roysays is offline   Reply With Quote
Old 10-06-2016, 05:11 PM   #3603
Yanks213x's Avatar
I feel like it's binding when not bolted in still.
Didn't mean to open a can of worms with the bolt side. Just wanted to state what I did and if see if it mattered.
Anyway. I'm not sure what to do.. hmmmm maybe the diff is built wrong.. I'm a little lost right now. Mig by try to rebuild it and see what happens
Yanks213x is offline   Reply With Quote
Old 10-06-2016, 05:45 PM   #3604
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
Originally Posted by RcForLife View Post
The VRP +2 is the same as stock, just moves the wing 2mm higher. I spoke to them the other day. Very soon they will have the gullwing front and tall rear towers available.
See more towers at amain.
They give an idea on when they will have the front gullwing and the tall rear towers?
For you guys doing carpet or other high traction but have say "rumble" sections on the track, have you tried the tall rear towers and any comment on how well they work?
I have both tower types here buggy already setup with tall rears so could just give those a go on Nov 5th but would be curious if those who are in the know have ideas. One part of the track can be "rough" for carpet and when last running my DEX210F which is oriented more to carpet, I remember getting kicked around a bit more than I liked.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 10-06-2016, 06:30 PM   #3605
sport10's Avatar
Since the down travel is the same only difference is the oil volume it should help more than hurt Imo. I do recommend running them in front of the tower though. If I go that way I think I will go with the schelle tower since it uses the short eyelets.
Hot Bodies VE8 w/ RX8-1900 combo
Losi XXX-SCT CRC conversion MMP/hacker 13.5
Associated B44
Associated B6
Durango DESC410V2 Pro
sport10 is offline   Reply With Quote
Old 10-06-2016, 07:21 PM   #3606
I run 2 gears in my diff only.. 7000 diff fluid.
hyperdive08 is offline   Reply With Quote
Old 10-06-2016, 10:01 PM   #3607
vr6cj's Avatar
Trader Rating: 124 (100%+)
diff nut side topic....
It doesnt matter one bit what side the diffs go in the tranny. racer1812 alrdy told you guys like a million times this. Its a preference unless your building a 4wd wheeler or something like that.
if you THink it goes in a certain way. Fine, your right. Ill put it in the other way and guess what...its fine too.
vr6cj is offline   Reply With Quote
Old 10-07-2016, 01:20 AM   #3608
Originally Posted by LVNeptune View Post
Not sure that Northern Hemisphere vs. Southern Hemisphere really makes any differences for mounting a screw O_o
our turnbuckles work the opposite way too down here.
Lunchie is offline   Reply With Quote
Old 10-07-2016, 05:55 AM   #3609
rvrslt1's Avatar
Trader Rating: 24 (100%+)
Originally Posted by MX304 View Post
If you are running 17.5 stock class, very worth it. Mod class, maybe. Depends on a few variables.
Yes running stock. They will be back in stock next week. Will try it out
rvrslt1 is offline   Reply With Quote
Old 10-07-2016, 06:14 AM   #3610
buckeye dan's Avatar
Who makes that gold top shaft?
Buckeye Dan
buckeye dan is offline   Reply With Quote
Old 10-07-2016, 07:01 AM   #3611
RCBuddha's Avatar
Trader Rating: 33 (100%+)
Exotek. Coming soon
RCBuddha is offline   Reply With Quote
Old 10-07-2016, 08:22 AM   #3612
Default Results 10/6 at highside.
Still couldn't compete with the Custom Works Rockets I raced against. But this B6D was really lightweight compared to my durango dex210 and B4.1.
bmag5000 is offline   Reply With Quote
Old 10-07-2016, 08:26 AM   #3613
Default My pit area yesterday. I brought my blue aluminum car stand to sit my B6D on.
Old 10-07-2016, 09:18 AM   #3614
kdub's Avatar
Originally Posted by thecman26 View Post
B5,B5M, & B4.2 manual says which side to put it on. I am pretty sure they were designed to be places on a specific side, too bad there's no AE design team support on here. I am sure every other AE manual I have seen also says which side it should be on. But neither here nor there... I haven't decided to go rogue and test out what would happen if I was a rebel and put it on the other side...
Chief Engineer, Schelle Racing Innovations, SchelleRacing.com - Team Associated - Reedy - JConcepts - Sanwa - MIP - StickyKicksRC - UpGradeRC - Darkside Designs
kdub is offline   Reply With Quote
Old 10-07-2016, 09:40 AM   #3615
I wonder if the diff nut should be replaced for those who feel it loosens on them and think it is because of on a certain side and the plastic material that is threaded is not acting like the lock part of the nut.
Yokomo BD8 x 2 , BD7 2016, YRX-12, Tamiya TRF419, Associated B6, B6D, B5M Factory Lite, B64D, B44.3, RC8B3, RC8B3e
My Outdated R/C Car collection:
Associated B44, Associated NTC3, Tamiya TRF415, TRF415 MSX MRE, TRF416X
190mph is online now   Reply With Quote
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
rubezzz
