    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree308Likes
Old 05-05-2016, 10:54 AM   #346
Originally Posted by Raulote View Post
How does the rear axle height affect to the car?. What is better for what in terms of handling?
There are 2 ways to get a lower ride height. One way is to just run the car lower through shock settings. This places the car at a below arms level position at ride height and results in a suspension geometry that has a generally high roll center at that height. The geometry at that point is not optimal. The other way is to adjust the axle height. If you move the axle height up, the results is essentially just lowering the chassis. The difference is that the suspension geometry can stay closer to arms level at ride height and get the same ground clearance. Now your roll centers are more optimal for that lower ride height. Go back to a place where you need more clearance and you can change axle height and hence ground clearance without changing the roll centers. Losi on the JRX-Pro and Kyosho on the Ultima Pro both offered this feature in 1991.
Follow my rc products on Facebook at Raborn Racing Originals and the line of 3D printed parts at
http://www.shapeways.com/shops/rebellionrc
fredswain is offline   Reply With Quote
Old 05-05-2016, 01:08 PM   #347
Thank you Fred!!!, great explanation!
So in theory, upper position of rear axle is better for higher bite and smooth tracks, and lower position suits better on rough and med/low bite tracks.
Right?
Raulote is offline   Reply With Quote
Old 05-05-2016, 01:20 PM   #348
Right?
That's how I use it. My dirt oval car, the Raborn Invencer, also has this feature and it's use is based on necessary ground clearance and tire diameter since in dirt oval we may run foam tires or 2.2 rubber.
Old 05-05-2016, 05:25 PM   #349
Mason's Avatar
Hey Buddha, can you keep track of the "first modification" bets? Put me down for shorter wheelbase.
Mason is offline   Reply With Quote
Old 05-05-2016, 05:32 PM   #350
Trader Rating: 16 (100%+)
I was thinking dirt version with the rear shocks mounted in front of the tower.
MX304 is offline   Reply With Quote
Old 05-05-2016, 05:55 PM   #351
That can only be done with the laydown trans.
Gearhead82 is offline   Reply With Quote
Old 05-05-2016, 05:59 PM   #352
Rear shocks mounted in front of the tower would require the laydown transmission to be fitted. Can't do it with the standup transmission.
will5879 is offline   Reply With Quote
Old 05-05-2016, 06:00 PM   #353
Jmuck69's Avatar
I must say the stock body is one of the best looking bodies out there.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 05-05-2016, 08:16 PM   #354
Cridd's Avatar
I think so too.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 05-05-2016, 08:25 PM   #355
RCBuddha's Avatar
Trader Rating: 35 (100%+)
I'd bet people will try to mod b5m parts to fit their B6's.
RCBuddha is offline   Reply With Quote
Old 05-05-2016, 11:40 PM   #356
[QUOTE=Logi Maker;14519216]
Originally Posted by Mxer210 View Post
Did anyone see the video Spencer posted on FB a couple days ago about him getting his B6 ready for the JConcepts Spring Indoor National (a clay track) and he said something about a Shorty Reedy Servo, anyone catch that? Any news on
Will be announced next week. Howart has had one for a while in his TC.... I have been all over it for my TC7... 100% Reedy power.
Maybe I'll win Spencer's heart over next week in Tacoma for the B6 dirt DEBUT and he will give me his...
You'll be at TRCR for the JCon race? Me too!
But that is awesome, how do you know it will be announced next week? Can't wait to get one ordered for my B6!
Mxer210 is offline   Reply With Quote
Old 05-05-2016, 11:53 PM   #357
Originally Posted by dsms4ever View Post
My hope by buying this kit is to just run it with a 6.5 and be competitive without having to upgrade anything.
My b5m set up for stock racing has cost too much money to set up right and I think a yz2 would have been better initially.
The b6 on the other hand looks promising.
If you are wanting to run stock with the B6 the only things you'll really need to be super competitive is buying the B6D kit, then the laydown transmission case, motor plate, idler gear and everything past that I really don't think you'll need for med-high traction clay tracks. Yes there will be way more available and some cool stuff but with what I mentioned above that is going to cost around $30-$40 I am guessing and that's not even going to be mandatory.
These kits coming out seem to be so well equipped out of the box it would be crazy to think you can't be competitive with what it comes with in any class.
Old 05-06-2016, 06:09 AM   #358
Volition's Avatar
Don't know if it's been mentioned. But I think this car also has some elements from the new 4wd to be released soon. I think it's a platform thing. My crystal ball says so.
B64?
Volition is offline   Reply With Quote
Old 05-06-2016, 06:27 AM   #359
Jmuck69's Avatar
B64?
I hope so. The entire back end configuration could be utilized
B6D | B64D
Old 05-06-2016, 06:29 AM   #360
The new B44 might be called the B64.
Associated B6 "Dirt Version" latemodel, Team Losi Racing 22T 2.0 Bomber Truck.
Team Losi Racing 22 2.0 2wd Short Course Truck,Duratrax 835e Brushless 8th scale Buggy,
Stock Slash, B4.1 latemodel(retired), T4.2 Factory Team BOMBER CAR
Castle Creations( Since April 2016)
bmag5000 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 12 (0 members and 12 guests)
