    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree287Likes
Old 10-05-2016, 08:53 AM   #3556
mellow's Avatar
Trader Rating: 17 (100%+)
I'm guessing his comment had a bit of sarcasm on it
"It'd be a lot cooler if you did."
mellow is offline   Reply With Quote
Old 10-05-2016, 10:27 AM   #3557
That's why "/s" was invented
LVNeptune is offline   Reply With Quote
Old 10-05-2016, 12:27 PM   #3558
Eli
Eli's Avatar
It was mostly sarcasm. I actually don't own a B6 yet as I recently returned after a 3 year break and am very happy with my b5m and still competitive with it and just recently was given a laydown trans on a chassis so will be playing with that soon.
Eli Westrup - SDRC Raceway - B6D - SC5M - B64D ALL FOR SALE!
Eli is offline   Reply With Quote
Old 10-05-2016, 12:31 PM   #3559
mdwaeracer's Avatar
Trader Rating: 19 (100%+)
it is little bit disappointing that AE has become the flavor of the month like Xray.
B4 was a great plat form for forever
TEAM ASSOCIATED Rc10, rc10B6D ,FUTABA , TEAM ORION, KYOSHO RB6.
mdwaeracer is offline   Reply With Quote
Old 10-05-2016, 12:37 PM   #3560
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
AE is far from Xray....and times changed, rear motor has nothing compared to mid motor on 99% of the tracks these days
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 10-05-2016, 12:43 PM   #3561
Eli
Eli's Avatar
Times sure have changed for sure. Mid motor feels like I have to be precise like a go kart versus my old b4 felt like I could drive it like a dirt bike
Old 10-05-2016, 12:50 PM   #3562
SMcD's Avatar
Trader Rating: 61 (100%+)
Flavor of the month?
I have built and raced b4.2 FT, OG B5M (first batch), B5M FL and, now, a B6D. Over those four AE race builds every version has improved over the previous car whether it be the molds, materials, hardware, whatever. Friends have asked me should they get the B6D. I honestly answer that, if the B6D doesn't improve their lap times, they will none-the-less enjoy the build, appreciate the thought behind the engineering, and will love how much easier the car is to service track side. So, sign me up for the monthly club.
B6.1D - it will come. Prediction - when Team AE starts winning big events with "their" version of the car, we will see the B6D laydown kit the way it should be released. Too many variables have to be worked out in the meantime.
For now, I race with my B6D. And will try to make laydown work on my dirt track
We Shall See
The Track Raceway, RCRNV, JMR
Team Jacobs Racing
YouTube: looking for turtles entertainment
B6D, X-1 2016, T4 2014 VTA, SCX-10 II
SMcD is offline   Reply With Quote
Old 10-05-2016, 03:35 PM   #3563
mdwaeracer's Avatar
I appreciate the quality, engineering that has gone into this vehicle. What I meant is the other platforms had longer runs than the B5m to the 6d. I've had a AE car since 1987. Still have it. Still race it. So please don't think I'm a hater.
Old 10-05-2016, 04:58 PM   #3564
Trader Rating: 478 (100%+)
The problem for all of the manufacturers is that they've done such a great job making these cars so much more durable that they aren't selling parts like they use to. That's the bottom line. I also think technology is pushing things forward a little faster. I loved my B4's but they were big piles of crap compared to the B5s and the B6s are looking pretty good.
Now that I've discovered the ignore list I plan to use it.....14 and counting!
QDRHRSE is offline   Reply With Quote
Old 10-05-2016, 09:04 PM   #3565
Yanks213x's Avatar
i'm having an issue with my laydown transmission .. It's hard to explain but with no motor or anything I feel like it doesn't not rotate smoothly .. I thought at first it was how I put the diff in. I'm running a ball diff and currently have the head the opposite way. The instructions call for the head to be in the direction of the spur but looking at the B5M 3 gear instructions .. it calls for the head the opposite way. Is there a reason why you'd do it differently with the laydown?
B6D (more like a b6) - Reedy 17.5 SS Mach 3, SC5M
Island Raceway and Hobby - Long Island
Support your local hobby shop!!
Yanks213x is offline   Reply With Quote
Old 10-05-2016, 09:29 PM   #3566
The head of the thrust bolt should always be on the right side of the car...
jbirdsfl is offline   Reply With Quote
Old 10-05-2016, 09:31 PM   #3567
AZJP's Avatar
Trader Rating: 20 (100%+)
It does not matter.
AZJP is offline   Reply With Quote
Old 10-05-2016, 10:00 PM   #3568
what would you hardened racers say is a good spares package to carry?I have ZERO support for this car at my track
Rear hubs/inserts?
Front shock tower?
front bulkhead?
wing mount?
Lunchie is offline   Reply With Quote
Old 10-05-2016, 10:08 PM   #3569
thecman26's Avatar
Trader Rating: 98 (100%+)
Originally Posted by AZJP View Post
It does not matter.
If that's the case why would they specifically state in the instruction manual? A direct quote from the manual Bag 11-14 step 5: "Install the Diff with the head of the Diff Thrust Bolt (#6573) facing the side with the spur gear."
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 10-05-2016, 10:51 PM   #3570
bru00z's Avatar
Make sure you used the correct length screws for the transmission through the chassis. Think its meant to be 8mm. I had 1 10mm by accident and it hit the diff!
Alex
Team Associated / Ace Hobbies / Proline Australia / VRP
bru00z is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Dirtraycer
