    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree298Likes
Old 09-29-2016, 12:49 PM   #3496
Super Moderator
racer1812's Avatar
Trader Rating: 30 (100%+)
Originally Posted by Speedychris22 View Post
Can someone post their radio settings for the b6d. Specifically talking about the airtronics/sanwa m12s
I'm confussed Why would you want everyone elses radio settings??
I run a DX4R, I don't want anyone elses radio settings....why would I??
Stand for the flag, kneel for the fallen.
Thank you to all of our service men and women!
racer1812 is offline   Reply With Quote
Old 09-29-2016, 01:08 PM   #3497
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
My radio settings are going to do you absolutely zero good.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 09-29-2016, 01:13 PM   #3498
onefast8's Avatar
Trader Rating: 41 (100%+)
You might be able to get a rough idea looking at some of the set up sheets on AE's website. Though their going to change quite a bit from driver to driver
Jake R.
onefast8 is offline   Reply With Quote
Old 09-29-2016, 01:37 PM   #3499
Trader Rating: 48 (100%+)
Just looking for some reference. More or less expo, brake dual rate, steering speed. I noticed not much info on what people have so wanted to open a conversation about it.
Thanks to my sponsors:
My Credit Card
Speedychris22 is online now   Reply With Quote
Old 09-29-2016, 01:41 PM   #3500
mellow's Avatar
Trader Rating: 17 (100%+)
It's all personal preference.
"It'd be a lot cooler if you did."
mellow is offline   Reply With Quote
Old 09-29-2016, 05:37 PM   #3501
team green's Avatar
Originally Posted by Cain View Post
spoke with rep from amain they are looking to carry the rest of the VRP towers soon.
Maybe someone can laymen terms explain what you gain with the VRP towers with the outer hole removed and what conditions is it best for?
So can you use the 31mm shock body with the rear towers?
team green is online now   Reply With Quote
Old 09-29-2016, 05:45 PM   #3502
UN4RACING's Avatar
Trader Rating: 22 (100%+)
Has anyone tried the laydown with the long tower? I was pleased with it on the 6D. The rear just seem to hang on longer in the turns with more confidence coming out of the turn. Jumps better to.
A Special Thanks to Arno and Rigor for there support...
http://www.rctech.net/forum/electric-off-road/664682-ae-factory-team-b44-2-thread.html
http://www.petitrc.com/setup/associated/setupb44/B44.2_BuildAdvice/
UN4RACING is offline   Reply With Quote
Old 09-29-2016, 08:00 PM   #3503
Trader Rating: 483 (100%+)
I run my M12S & MT4S with all the settings they came with....I don't use any of that stuff and I'm not sure that I know anybody that does. I adjust the end points and brake settings, that's it. My HW ESCs have punch settings and WOT delay settings so I don't bother with the radio.
Now that I've discovered the ignore list I plan to use it.....14 and counting!
QDRHRSE is offline   Reply With Quote
Old 09-30-2016, 03:33 AM   #3504
scr8pn4205's Avatar
radio settings are personal preference. Depends on a lot of things. Driver, servo, esc setting, track. Take for example on the same car but different servos. One I needed 0 exp on steering and the other in at -25 on steering expo. Its all preference and best to go to track and try each adjustment out to make car drive better for you. I think Kinwald said that 80 percent of the way the car races is all in radio settings
Airtronics M12
Team Xray XB2 2017 CE
TSR power
scr8pn4205 is offline   Reply With Quote
Old 09-30-2016, 06:38 AM   #3505
The only settings that I use apart from sub-trim to centre the steering are:
EPA (ch1): L82, R104. I set these to the points where the steering just begins to move away from full lock, so that the steering servo isn't pushing against the locked steering.
EXP (ch2): -25%. To dedicate a bit more of the trigger throw to the lower/mid range of speed and give a bit more control when accelerating.
mushroomed is offline   Reply With Quote
Old 09-30-2016, 07:17 AM   #3506
Tech Legend
Cain's Avatar
Trader Rating: 234 (100%+)
Originally Posted by RcForLife View Post
The new middle hole on the option towers is a good option for high bite tracks. You can purchase the front and rear aluminium towers on the vrp site (visionracingproducts.com) Thats where I bought mine.
Thanks for the info. Looking at amain mainly as I have some credit there with them I want to use up
Looking to pick up some springs, thinking of going say a rate higher and lower than what is stock for the B6D and the B6 versus full kits, depending of course on price. I figure that could give me some options for indoor carpet as well as outdoor. Sound good or are you guys finding for AE springs there are just certain ones that you want to use all the time?
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 09-30-2016, 10:51 AM   #3507
chris c's Avatar
Trader Rating: 60 (100%+)
Probably beating a dead horse and really can't find via search a good ocrc 17.5 with lay down ball diff setup.
chris c is offline   Reply With Quote
Old 09-30-2016, 10:53 AM   #3508
mellow's Avatar
Kurt Wengers setups. http://site.petitrc.com/setup/associ...tedRC10B6.html Or he posted them on the RC10B6 Nation page on Facebook.
Old 09-30-2016, 11:00 AM   #3509
Tech Legend
Cain's Avatar
on that site does the (D) after the name denote that the setup is from a B6D base?
Old 09-30-2016, 11:01 AM   #3510
Super Moderator
I think so....it doesn't really matter though. The setup sheet notes all the details.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
mx836
