    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree287Likes
Old 09-24-2016, 07:38 PM   #3406
sport10's Avatar
Originally Posted by Cain View Post
alright I got one of these on the way with a variety of upgrades based on the listing and pics.
This will be a vehicle used on carpet and I think the previous owner was using it on something high traction as he has the hard arms on the car and has a laydown transmission as well included.
At the moment right now, what would be considered one of the better carpet setups to look at, even, better, if its a b6d laydown setup?
Once it arrives will give it the usual run through, but I know it has the MIP puck system including the stock ball diff, the track has decided however to go back to mod apparently. Is there a limit to where the MIP pucks can safely be ran motor wise? I am looking at most an 8.5 motor, but may go to something like a 10.5 or 13.5 since its small.
And if I go ball diff, I am assuming no funny issues on carpet, just that gear is more consistent?
Lastly, if using the slipper setup on carpet with something like mckune or rcshox style pads, anyone compare how they feel in comparison to a slipper eliminator?
thanks before hand for all your help.
I would copy the B6 stock setup as close as possible for carpet. The gear diff also lives much better on carpet than a ball diff. The only difference is gear diff and gullwing arms and tower since you already have the laydown tranny.
Hot Bodies VE8 w/ RX8-1900 combo
Losi XXX-SCT CRC conversion MMP/hacker 13.5
Associated B44
Associated B6
Durango DESC410V2 Pro
sport10 is offline   Reply With Quote
Old 09-24-2016, 09:32 PM   #3407
Originally Posted by sport10 View Post
Will they not let you fun a horizontal shorty battery.
They will but a stick pack has a higher capacity then a shorty, that's why I dont like shorties until the technology improves and they can hold at least 6500mah. I have to have that minimum
Associated B6 "Dirt Version" latemodel, Team Losi Racing 22T 2.0 Bomber Truck.
Team Losi Racing 22 2.0 2wd Short Course Truck,Duratrax 835e Brushless 8th scale Buggy,
Stock Slash, B4.1 latemodel(retired), T4.2 Factory Team BOMBER CAR
Castle Creations( Since April 2016)
bmag5000 is offline   Reply With Quote
Old 09-24-2016, 09:44 PM   #3408
JAE
Trader Rating: 26 (100%+)
Default Pistons
A lot of alternative Pistons coming out of the woodwork. Gimmick?
Anyone try the VRP pistons? Look interesting and wondering if they function as advertised
JAE is offline   Reply With Quote
Old 09-25-2016, 06:15 AM   #3409
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
Good stuff. I'll keep that in mind and pick up one as an option.
hmm, wonder if they could squeeze anymore into a square lipo assuming that would fit, the nano-techs are up to 6200mah from my battery reviews for a desc410.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 09-25-2016, 07:27 AM   #3410
Anyone try the BMI Vari-flow CNC machined pistons?
The have them in 2 types: 2 x 1.7mm and 2 x 1.8mm
Yokomo BD8 x 2 , BD7 2016, YRX-12, Tamiya TRF419, Associated B6, B6D, B5M Factory Lite, B64D, B44.3, RC8B3, RC8B3e
My Outdated R/C Car collection:
Associated B44, Associated NTC3, Tamiya TRF415, TRF415 MSX MRE, TRF416X
190mph is offline   Reply With Quote
Old 09-25-2016, 09:10 AM   #3411
Are you running a 5.5 motor or a 6.5 motor? I'd try a little less timing and see if that gets you some more run time.
I'd also check for bad bearings in the tranny and wheel bearings.
Eddie_E is offline   Reply With Quote
Old 09-25-2016, 01:30 PM   #3412
sport10's Avatar
Looks like a castle 1410 four pole short course motor to me. That would explain the high amp draw. A more suitable motor will allow much better runtime. I would get something in the 6.5 to 7.5 range in two pole. With a motor like this a 5000 mah shorty will easily make run time and then some.
Associated B44
Associated B6
Old 09-25-2016, 03:00 PM   #3413
Trader Rating: 25 (100%+)
That moment when you ran your b6 for the first time, love it... then realize you didn't sand and glue the shock towers... sigh
B5M - Hobbywing v3.1 Stock Spec, Team Scream 17.5, Team Scream Battery
B6 - Hobbywing v3.1 Stock Spec, Team Scream 17.5, Team Scream Battery
Ronisonce is offline   Reply With Quote
Old 09-25-2016, 03:55 PM   #3414
xyzracer's Avatar
I didnt glue mine yet either...what happened, are they delaminating or did it just break completely?
xyzracer is offline   Reply With Quote
Old 09-25-2016, 04:15 PM   #3415
Default Horizontal stress
The other day, my local track did an outdoor race at an RC Airshow at a small airport. They rolled out the turf, put down some plastic jumps and tubing to create the track. This was laid over pavement. So, I ran my freshly built B6 during warmups and I had to call it quits when the screws on the bottom that hold everything in the rear in all backed out. Guy there said it was caused by the horizontal stress. The track was so grippy, there was almost no sliding at all.
My question is, how would I prevent this? Keep in mind everything is stock so far. I got the aluminum d mount and a chassis protector. Haven't had time to rebuild yet.
AllDamage is offline   Reply With Quote
Old 09-25-2016, 04:17 PM   #3416
Trader Rating: 29 (100%+)
Touch of CA in plastics or blue thread lock on metal to metal.
DustinEich is offline   Reply With Quote
Old 09-25-2016, 05:02 PM   #3417
Not sure why everyone is so worried about sanding and gluing the CF parts. It's not needed, the CF stuff now is really good quality. Cheap CF can delam but the quality stuff doesn'. I've been running Schumacher off road cars for 3 years and I have never had a issue with any CF parts. I've never sanded and sealed any of the parts and to date, I have never had a piece of CF break, crack, or delam.
Bill
AE SC5M / Viper VTX10R & Maclan 10.5
Schumacher KD and KC / Maclan MMax Pro & MMR Team Edition 17.5
Schumacher KF2 / VTX 10R & MMR 17.5
Schumacher K2 / MMax Pro & MMR Team Edition 13.5 /// Airtronics MT-4
Riverbluff is offline   Reply With Quote
Old 09-25-2016, 06:11 PM   #3418
What ^ guy said.... Also knocking on wood.
Old 09-25-2016, 07:01 PM   #3419
Who is that Guy's Avatar
I sand the edges but don't glue I have yet to break a tower!!!
Who is that Guy is offline   Reply With Quote
Old 09-25-2016, 07:09 PM   #3420
Eli
Eli's Avatar
Gluing it isn't going to hurt, its piece of mind if anything.
Eli Westrup - SDRC Raceway - B6D - SC5M - B64D ALL FOR SALE!
Eli is offline   Reply With Quote
Currently Active Users Viewing This Thread: 6 (4 members and 2 guests)
3n90t, EbbTide, Kelseyrc
