    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree311Likes
Old 09-24-2016, 07:06 AM   #3391
Default My B6D
bmag5000 is offline   Reply With Quote
Old 09-24-2016, 08:16 AM   #3392
People in my area are converting B5Ms to sprint cars to compete with Custom Works Sprints. Let me tell you they are having good luck with that.
I had an idea to convert a B6D to a latemodel. And I still wanted to use stick packs.
I was racing the B4.1 and getting killed so I thought it was my car because it was old.
I haven't raced this yet but I know it will be good. The latemodels ill be racing against are Custom Works Rockets and B5m converted latemodels.
My SC10 body mounts and mounting plastic brackets did fit this with a little modification. You have to dremel the brackets a little bit.
Rear body mount is screwed down to the Wing Mount and I Zip tied it just as a precaution measure.
Associated B6 "Dirt Version" latemodel, Team Losi Racing 22T 2.0 Bomber Truck.
Team Losi Racing 22 2.0 2wd Short Course Truck,Duratrax 835e Brushless 8th scale Buggy,
Stock Slash, B4.1 latemodel(retired), T4.2 Factory Team BOMBER CAR
Castle Creations( Since April 2016)
Old 09-24-2016, 08:26 AM   #3393
Originally Posted by bmag5000 View Post
What bumper is that?
Asking for my kids....
Bomba is offline   Reply With Quote
Old 09-24-2016, 08:31 AM   #3394
Its an RPM bumper I took off my B4.1
Old 09-24-2016, 08:36 AM   #3395
sport10's Avatar
Now if traction is good convert to laydown tranny and see if those custom works can keep up. Maybe slot the sides for a lengthwise full size battery.
sport10 is offline   Reply With Quote
Old 09-24-2016, 08:45 AM   #3396
Tech Legend
Cain's Avatar
Trader Rating: 234 (100%+)
Does that bumper bolt up fine or did you have to mod it?
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 09-24-2016, 08:47 AM   #3397
Bolted right on. I was very surprised
Old 09-24-2016, 08:51 AM   #3398
nodrog's Avatar
I just ordered the B6D and I'm trying to find information on what upgrades to get.
what wings is everyone running? will any 1/10 scale wing fit?
I'm thinking about trying this one as I've heard the stock wings don't last.
also do you guys recommend the Ti-Nitride or chrome shock shafts?
so far the only things I have on a wish list is the longer rear tower and shock shafts, caster hat bushings, bulkhead shims, tapered pistons, brass c and d blocks but I'm not sure which ones yet
when doing the rear longer shock tower upgrade do i just use longer shock shafts or do i need the longer shock body too, seems obvious but I thought I saw setups with the longer tower/shafts with the stock shock bodies. This upgrade is for outdoor for the season remainder and then I'll switch back to stock rear shock setup for indoor.
thanks, can't wait to get this kit built
nodrog is offline   Reply With Quote
Old 09-24-2016, 09:12 AM   #3399
sport10's Avatar
Any 1/10 wing will fit just have to trim it right. The proline TriFecta wing is twice a thick and works well. I would try the stock shocks first before upgrading. Only upgrade if necessary.
Old 09-24-2016, 09:18 AM   #3400
sport10's Avatar
Old 09-24-2016, 10:42 AM   #3401
xyzracer's Avatar
You want the longer shock body not the shaft. And yes it is a worthwhile upgrade especially outdoors if a bumpy track. Car lands much better.
Precut tlr 22 wing is nice!
xyzracer is offline   Reply With Quote
Old 09-24-2016, 10:54 AM   #3402
nodrog's Avatar
i will definitely try it stock first but I want to know the options available for set ups and how to apply them to simplify things down the road...thanks, trifecta wing in the cart!
so stock rear shafts and 31mm shock bodies, with the long option tower, ya this will be for offload setup with big jumps
Old 09-24-2016, 06:57 PM   #3403
Kegman21's Avatar
Anyone try this VRP front tower yet?
https://www.amainhobbies.com/vrp-ass...rp1241/p530924
HB D413/ SMC160A/ Sanwa M12S/ Associated B6 🚓
Kegman21 is offline   Reply With Quote
Old 09-24-2016, 07:14 PM   #3404
vito's Avatar
ok i need a hand i got a nova slipper kit with 69 tooth gear for a stock motor 17.5 28 . what or how dose the spring to use or the the stock one that came off the b6 kit and what whaser to run under the slipper nut ?
LikeShow more reactionsCommentShare
the happy racer
drango 410 v 4
am dyslexic
b5 mid motor
vito is offline   Reply With Quote
Old 09-24-2016, 07:32 PM   #3405
sport10's Avatar
Will they not let you fun a horizontal shorty battery.
Hot Bodies VE8 w/ RX8-1900 combo
Losi XXX-SCT CRC conversion MMP/hacker 13.5
Associated B44
Associated B6
Durango DESC410V2 Pro
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
