    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree287Likes
Old 09-21-2016, 12:14 PM   #3331
onefast8's Avatar
Trader Rating: 41 (100%+)
First time trying the AE screws when I built my B6d. Never again. Complete trash.
Jake R.
onefast8 is offline   Reply With Quote
Old 09-21-2016, 12:16 PM   #3332
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
Originally Posted by racer1812 View Post
The posting like a Pro part wasn't directed at you bud
Fact is, the B6 cars are light enough out of the box with standard electronics that most are under legal weight as it is. There's little to no need to run Ti screws for the sole purpose of saving a couple grams on the scale.
I know . The car is definitely lightweight. I add a good amount to mine. Racing outdoors my car weighs in about 1570g and gets better each time out.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 09-21-2016, 12:16 PM   #3333
Same here. I guess they're "cheap" for a reason.
Sean B. is offline   Reply With Quote
Old 09-21-2016, 12:23 PM   #3334
mellow's Avatar
Trader Rating: 17 (100%+)
I just ordered the protek ti set the other night..Schelles just came back in stock though, so I might go with a set of those and either sell/return the Proteks. The Schelles are shinier anyways.
"It'd be a lot cooler if you did."
mellow is offline   Reply With Quote
Old 09-21-2016, 12:26 PM   #3335
Super Moderator
racer1812's Avatar
Trader Rating: 30 (100%+)
Originally Posted by Matt Trimmings View Post
I had the associated and protek kits on some of my 5 series cars...price was decent but the quality could have been better. I am using the Schelle now and have had zero issues with them. I think we would all like to have Lunsford but I also like to eat and have a roof over me.
Hard to hammer on Lunsford, he gives us top quality stuff for sure. But you're right. Social Services isn't likely to be very understanding when I tell them my kids go to school without shoes because I had to buy screws for my R/C cars..
Stand for the flag, kneel for the fallen.
Thank you to all of our service men and women!
racer1812 is offline   Reply With Quote
Old 09-21-2016, 12:35 PM   #3336
Super Moderator
Nothing against Lunsford in any way. They definitely produce only the best....it's just that I don't need the best when pretty dang good will do the trick.
Old 09-21-2016, 12:37 PM   #3337
Yeah there's no way I would pay $100 for some screws. Unless she was a real looker.
Old 09-21-2016, 12:43 PM   #3338
Super Moderator
racer1812's Avatar
Again I agree...How did we get hear anyway? Oh ya, my fault..
Old 09-21-2016, 04:37 PM   #3339
mourinho's Avatar
Trader Rating: 40 (100%+)
they're not that bad really. you have to build the car with the steel screws first to thread all the plastic and then replace with the titanium.
doing it that way i did not strip a single screw and the heads all look new.
mourinho is offline   Reply With Quote
Old 09-21-2016, 05:56 PM   #3340
Trader Rating: 18 (100%+)
Or just buy a tap and tap the plastic parts first. Been doing that for years. Takes a couple more minutes per part but everything lasts much longer.
Chris Brown is offline   Reply With Quote
Old 09-21-2016, 07:03 PM   #3341
Trader Rating: 29 (100%+)
Quick question B6D what eyelet for front shock shaft... Short or Long?
Manual contradicts itself.
DustinEich is offline   Reply With Quote
Old 09-21-2016, 07:07 PM   #3342
Never mind quick goole search says short... Why were the long included B6 maybe?
Old 09-21-2016, 07:19 PM   #3343
aeRayls's Avatar
Long is for outside hole on front arm and when rear shock on rear of arm.
aeRayls is offline   Reply With Quote
Old 09-21-2016, 07:21 PM   #3344
Ahhh... Thanks
Old 09-21-2016, 08:22 PM   #3345
Brass D mount is in stock now:
https://www.teamassociated.com/parts...m_mount_d_12g/
BruceR. is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
