    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree287Likes
Old 09-16-2016, 12:49 PM   #3271
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
Originally Posted by onefast8 View Post
I ordered the xfactory towers from amain as backups. They look pretty nice and have a little more material in some areas. I have yet to run them so I cant comment on any improvement over stock. I would have preferred to get the factory rc towers but who knows when they will actually have them is stock.
+1 I was waiting on them as well. I gave up and made a brace for my ae tower
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 09-16-2016, 02:13 PM   #3272
Phillip F's Avatar
Trader Rating: 15 (100%+)
Lets see that brace
Phillip F is offline   Reply With Quote
Old 09-16-2016, 02:26 PM   #3273
Originally Posted by Cain View Post
Any opinion on diggity designs? used there stuff in the past so curious they are any good still.
Still good. Damon uses only quasi carbon.
Sean B. is online now   Reply With Quote
Old 09-16-2016, 02:39 PM   #3274
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
Originally Posted by Phillip F View Post
Lets see that brace
If you don't know what it looks like already be glad.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 09-16-2016, 04:54 PM   #3275
RC*PHREAK's Avatar
Trader Rating: 119 (100%+)
Lets see that brace
more importantly, let's see how it was made.
RC*PHREAK is offline   Reply With Quote
Old 09-16-2016, 06:24 PM   #3276
I cant post pictures of my car online atm. But I took some scrap aluminum. used an existing tower to trace the top 1/3 of the tower. Used an automatic punch to make the holes for the shocks. then I used a cut off wheel and a sanding drum from my dremel to cut/shape the piece. Then i slightly undersized the shock mount holes and 3m tapped them. I then bolted it up the the tower. marked any areas needing a little more material used, then used my sanding wheel to finish it off. The alum is 2mm thick. Took me about 30 minutes to make it. I have had it on the car for about a month, with it attached to a cracked tower. The tower has not broken any more, so the piece seems to work. the brace is less than a gram.
Old 09-16-2016, 06:40 PM   #3277
Trader Rating: 137 (100%+)
What kinda hits are the towers taking that makes them break? Are they just weak like the B44 towers have always been, or does it take a pretty serious whack to break them?
TLR 22T 3.0, TLR 22-4 2.0 , TLR 22 4.0 X2, 22SCT 3.0, Tekno SCT 4X4, Hobbywing, Futaba, LRH Hobbies, Spektrum Servos, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 09-16-2016, 07:32 PM   #3278
RCBuddha's Avatar
Trader Rating: 33 (100%+)
http://www.redrc.net/2016/09/avid-b6...ng-block-arms/
RCBuddha is offline   Reply With Quote
Old 09-16-2016, 09:37 PM   #3279
AZJP's Avatar
Trader Rating: 20 (100%+)
They designed them to break. Nothing else on the car does. If they didn't make them to break, they wouldn't make any money after the sale of the unit, so they focused on a more expensive piece. Everything wears out on your automobiles for a reason
AZJP is offline   Reply With Quote
Old 09-16-2016, 10:13 PM   #3280
1/4milecrazy's Avatar
Mine must be defective then because I haven't broken it yet. Come to think of it, all the ones at my local track must be defective because I haven't seen any of theirs break either. I think I am gonna call AE tomorrow and complain that the part "they designed to break" has not broken yet on my car and I want them to ship me some pre-broken ones because "some guy on RCTech" told me they are supposed to break.
1/4milecrazy is offline   Reply With Quote
Old 09-17-2016, 05:11 AM   #3281
onefast8's Avatar
Trader Rating: 41 (100%+)
Anyone have any feedback on this fan mount?
http://www.shapeways.com/product/VQ7...431308&li=cart
Jake R.
onefast8 is offline   Reply With Quote
Old 09-17-2016, 07:05 AM   #3282
Super Moderator
It takes a good hit. Wildcat races at srs...which is basically modeling clay. When you crash you don't skate over the dirt, you dig into it. They are not 'designed' to break...
Old 09-17-2016, 07:59 AM   #3283
Phillip F's Avatar
I have one. It fits with the stock body. After a while though the fan gets noisy. I took it out and just used a servo tape and mounted the fan behind the motor.
Old 09-17-2016, 09:33 AM   #3284
Ok, thats clears it up LRH is really high bite clay as well, but it has give.
Old 09-17-2016, 09:58 AM   #3285
JAE
Trader Rating: 26 (100%+)
What other parts do I need to run the b5m kashima shocks? Is it worthwhile doing this? I have some sitting around. Thx much
JAE
JAE is offline   Reply With Quote
