    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree287Likes
Old 09-15-2016, 06:51 AM   #3226
mjbtaco's Avatar
Got my B6D built up and painted. Just need some knobby tires so i can do some outdoor racing.
Official Team Associated B6 & B6D thread-fb_img_1473947244578.jpg   Official Team Associated B6 & B6D thread-fb_img_1473947365041.jpg
Barrios Paints
mjbtaco is offline   Reply With Quote
Old 09-15-2016, 11:34 AM   #3227
bmx_ican92's Avatar
Looks like the aluminum shock tower prayers have been answered!
From the liverc site- "
VRP would like to introduce its 7075 Aluminum Shock Towers for the Associated B6 buggy. They are 100% made in the USA out of American 7075 aluminum. We make them in house at VRP.
For the Front Shock Tower, there are 2 versions. First, a Standard Tower with the normal shock mounting holes, and then an Option Tower that eliminates the outer shock mounting hole. By doing this, you have the stock middle hole as the very outside hole, as well as the stock inner hole. But as an added tuning option, we added a half hole between the inner and outer hole. This will offer a fine adjustment for the different grip levels found in modern racing.
For the Rear Shock Tower, there are 3 versions. First, the Standard Tower with the normal shock mounting positions. Second, we have the Option Tower. This tower is much like the Front Option Tower. It eliminates the outer hole, and makes the middle hole the outside hole, normal inside hole, and new half hole between the two. Third, we have the Option +2 Tower. This tower is just like the Option Tower, but it raises the wing position up by 2mm. Testing has shown that this increases the total downforce and thus makes the car harder to traction roll. Very much in line with the way F1 aero packages work.
Towers made out of American 7075 Aluminum
CNC, Anodized, and Laser Etched in house at VRP
100% American Made
2 different Front Towers (Standard and Option Tower)
3 different Rear Towers (Standard, Option, and Option +2 Tower)
No more breakage issues
All Towers available in Silver, Blue and Black
Includes Velvet Storage Pouch
Rear Towers include 4 Mounting Washers"
bmx_ican92 is offline   Reply With Quote
Old 09-15-2016, 12:38 PM   #3228
I was always told if you bundle the antenna wire it creates a coil and that causes glitching. What do you think or have you had any experience in this? Sure does make for a cleaner looking body.
Bubonic-X is offline   Reply With Quote
Old 09-15-2016, 12:39 PM   #3229
onefast8's Avatar
Trader Rating: 41 (100%+)
Hey guys, need some help with a few settings on my b6d laydown.
I just finished building my b6d (ill spare you the unimpressive pics) and I'm trying to decide if I want to get new alum. rear hubs or use my B5m single axle height Schelle rear hubs.
What is this adjustment really doing? Is this a well used adjustment? Is it the same as +/- a shim under the outer ballstud? Also, is this a necessary change for raising or lowering the inner hinge pin height?
On that note I am trying to run a wide inner pivot with 2.5 tow in and 1 anti squat. So as far as I can tell I need center 1's facing out in C and center .5's facing out in D? Not sure here still kinda confused on the whole pill insert thing.
Appreciate any input!
Jake R.
onefast8 is offline   Reply With Quote
Old 09-15-2016, 01:09 PM   #3230
Phillip F's Avatar
Trader Rating: 15 (100%+)
100% American Made
Where can I buy a pair?
Phillip F is offline   Reply With Quote
Old 09-15-2016, 01:11 PM   #3231
mellow's Avatar
Trader Rating: 17 (100%+)
I've done it with all my Futaba receivers and never had an issue.
I'll let someone else explain the hubs and their adjustments, but here's some good info on the pills for the d/c blocks. You can adjust antisquat and toe, as well as roll center. It is a little confusing to wrap your head around, but a pretty good system once you figure it out. The info on the inserts are mid page.
http://site.petitrc.com/setup/associ.../B6_BuildTips/
Also a lot of good info in general if you go through all the links on the main page for the B6/D on PetitRC.
Found here:
http://site.petitrc.com/setup/associ...tedRC10B6.html
http://www.visionracingproducts.com/...ted-B6_c38.htm
"It'd be a lot cooler if you did."
mellow is offline   Reply With Quote
Old 09-15-2016, 03:26 PM   #3232
Probably heard it most back in the 72 / 75 MHz days. With 2.4 it's generally not an issue as the active antenna is the last 30 - 31 mm ( ? ) un-shielded portion of the wire. For Airtronics rxs I've been coiling the excess wire and use a short antenna tube bent at 90 degrees to keep it all under a buggy body.
belewis01 is offline   Reply With Quote
Old 09-15-2016, 03:33 PM   #3233
vito's Avatar
the happy racer
drango 410 v 4
am dyslexic
b5 mid motor
vito is offline   Reply With Quote
Old 09-15-2016, 03:36 PM   #3234
mellow's Avatar
Nice puss
Old 09-15-2016, 03:50 PM   #3235
Super Moderator
racer1812's Avatar
Trader Rating: 30 (100%+)
put the cat away Vito. ;(
Stand for the flag, kneel for the fallen.
Thank you to all of our service men and women!
racer1812 is offline   Reply With Quote
Old 09-15-2016, 03:53 PM   #3236
vito's Avatar
iam at a stand still to my new diff parts get in i got a bad stuck cross pin in the out drive
the happy racer
drango 410 v 4
am dyslexic
b5 mid motor
Old 09-15-2016, 04:09 PM   #3237
JAE
Trader Rating: 26 (100%+)
The below is for a different buggy, but checkout all the settings for the bushings. It's easier to understand by looking at what the bushing placements do to toe and anti squat
http://site.petitrc.com/setup/xray/s...2_SetupHelper/
JAE
JAE is offline   Reply With Quote
Old 09-15-2016, 04:45 PM   #3238
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
Before I went to the new receivers, I coiled up, shrink tubed and servo taped it to my receiver. Never had an issue in 2 years. It does lower the range. I tested that. But, not enough to mater in racing. Guys are doing it at fear farm, which is large, without issue.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 09-15-2016, 08:48 PM   #3239
bmx_ican92's Avatar
So just had my first outing at the track with my b6, I am noticing my inside front wheel is coming off the ground when I take corners hard. Im running the kit spec set up. Any advice on what I can do to fix this?
Old 09-15-2016, 09:07 PM   #3240
JsK
JsK's Avatar
Raise the inner ballstud 1mm. Its gonna pick up steering but you want it to roll a little more
instead of picking up the inside wheel.
JsK is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
gdbracing
