    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree285Likes
Old 09-10-2016, 03:49 PM   #3151
anyone make there own front wing mount
B4,T4,B44
RC12R5.2
T.R.C.R
pinky13 is offline   Reply With Quote
Old 09-10-2016, 06:57 PM   #3152
vito's Avatar
come on monday i get my b 6 and i got a low pro savox and a 17.5 motor and the astro tires came today all most there
the happy racer
drango 410 v 4
am dyslexic
b5 mid motor
vito is offline   Reply With Quote
Old 09-10-2016, 11:45 PM   #3153
Cridd's Avatar
Trader Rating: 16 (100%+)
Nice
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 09-11-2016, 10:18 AM   #3154
bmx_ican92's Avatar
Can't wait to get this on the track
bmx_ican92 is offline   Reply With Quote
Old 09-11-2016, 11:29 AM   #3155
Those are the Front JConcepts Slims rims and the Swaggers Staggers rib tires right?
Yokomo BD8 x 2 , BD7 2016, YRX-12, Tamiya TRF419, Associated B6, B6D, B5M Factory Lite, B64D, B44.3, RC8B3, RC8B3e
My Outdated R/C Car collection:
Associated B44, Associated NTC3, Tamiya TRF415, TRF415 MSX MRE, TRF416X
190mph is online now   Reply With Quote
Old 09-11-2016, 01:04 PM   #3156
Exclamation It may be just because they are a new design.
Originally Posted by HotRodDiesels View Post
I had a split ball cup too.
I ordered a bunch of spares just in case.
lanec1227 is offline   Reply With Quote
Old 09-11-2016, 01:27 PM   #3157
Default Wallie build/ motowhips edition
Originally Posted by suby723 View Post
Wish they would have a black edition. I don't mind the blue though.
Nick Waulet, a.k.a Wallie Builds teamed up with Motowhips to make a black edition!
Old 09-11-2016, 02:41 PM   #3158
bmx_ican92's Avatar
Yup
Old 09-11-2016, 02:42 PM   #3159
Finally got the chance to bring my B6D to the track today. Broke the rear shock tower on the second battery pack. Three dudes broke their B6D rear shock tower on my track today. So I am wondering: Any better choices than the stock shock tower?
Johnyolo is offline   Reply With Quote
Old 09-11-2016, 03:36 PM   #3160
Phillip F's Avatar
Trader Rating: 15 (100%+)
Welcome to the club. One guy here is coming up with an anodized aluminium version. ...waiting for him to start sell it.
Phillip F is online now   Reply With Quote
Old 09-11-2016, 04:51 PM   #3161
Trader Rating: 18 (100%+)
I did the same. So far my Infinity tower is holding up great. It's .5mm thicker and has a little more material above the shock holes.
iTz Nicholas72 is offline   Reply With Quote
Old 09-11-2016, 06:08 PM   #3162
Glad to hear that. I also prefer aluminum.
Thanks! I will give it a try.
Old 09-11-2016, 09:09 PM   #3163
Finished building this B6D late last week, but racing was washed out this weekend. Can't wait to get it on a track!
mushroomed is offline   Reply With Quote
Old 09-12-2016, 01:26 PM   #3164
Hi guys anyone have problem with gear diff on b6?I run on carpet with b6
dylanshock is offline   Reply With Quote
Old 09-12-2016, 03:00 PM   #3165
abailey21's Avatar
Trader Rating: 36 (100%+)
I changed mine to the ball because I'm just more used to running a ball diff. I had zero issues with mine when I ran it other than lack of knowledge on tuning with oils
K.C.C.O.
abailey21 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 6 (0 members and 6 guests)
