    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree287Likes
Old 09-09-2016, 07:05 PM   #3136
Cridd's Avatar
Trader Rating: 16 (100%+)
Originally Posted by 40yoCaliRacer View Post
Which bearings? Inner Hub? Inside the gearbox?
Rear hub, inside bearing.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 09-09-2016, 07:23 PM   #3137
Hey gents,
3.0 or 2.5 degrees rear toe on a B6 running med-high bite clay? Pretty sure I had 2.5 when I put it together for carpet racing. But I think I might need the extra toe to get forward bite on dirt?
BruceR. is offline   Reply With Quote
Old 09-09-2016, 08:00 PM   #3138
These Schumacher Low Profile Stagger fronts are annoying to mount on the JConcepts Slim front wheels.
The tires have the lip of the bead made to work with standard width rims basically it feels like.
Does anyone cut back the bead lip on them?
Yokomo BD8 x 2 , BD7 2016, YRX-12, Tamiya TRF419, Associated B6, B6D, B5M Factory Lite, B64D, B44.3, RC8B3, RC8B3e
My Outdated R/C Car collection:
Associated B44, Associated NTC3, Tamiya TRF415, TRF415 MSX MRE, TRF416X
190mph is offline   Reply With Quote
Old 09-09-2016, 08:03 PM   #3139
JAE
Trader Rating: 26 (100%+)
What's the most aggressive steering setup you can get on a b6d Laydown on medium bite clay (Ocrc). Coming from a laydown xb2 so looking for max steering. Any tips on setup (bushings etc). Thx!
JAE is offline   Reply With Quote
Old 09-09-2016, 09:01 PM   #3140
Trader Rating: 15 (100%+)
Flat arms, with the aluminum steering rack/assembly....I was running all the aluminum stuff, but went back to stock because it was too twitchy
motoman811 is offline   Reply With Quote
Old 09-09-2016, 09:12 PM   #3141
JAE
Aluminum steering have different ackerman settings or just remove slop and flex?hiw about the bushings on the caster blocks? Top or bottom? Thx man
M
Old 09-09-2016, 10:44 PM   #3142
JsK
JsK's Avatar
Never had any problems with AE, Schumacher, Losi or Avid wheels. Must just be
a Jconcepts issue.
Nope,they are made to run with no foam on a narrow wheel.
No, But they do come in a premount.
JsK is offline   Reply With Quote
Old 09-10-2016, 12:34 AM   #3143
Eli
Eli's Avatar
Originally Posted by bmx_ican92 View Post
About to be a fun weekend 😁
Nice dude!
Eli is offline   Reply With Quote
Old 09-10-2016, 09:45 AM   #3144
I haven't found them hard to get on the wheels, but gluing them is a different story...... I only buy them pre-mounted for the front.
MX304 is online now   Reply With Quote
Old 09-10-2016, 10:17 AM   #3145
Using the 7/13 Hartson setup, I added the brass bulkhead and got a TON of steering. I also got the front servo weights, but haven't tried them yet. I had so much rear traction, I couldn't get enough steering until the brass bulkhead. (It may be overkill, so I'm gonna go back to plastic bulk and try the weights next)
stevewolfie159 is offline   Reply With Quote
Old 09-10-2016, 11:17 AM   #3146
JAE
Everyone using the 25 gram brass c for the laydown? Mine came with the 12 and wondering if that will provide enough grip. Bushings on to on the spindles add more steering in this buggy (like others) right? Thc
Old 09-10-2016, 11:22 AM   #3147
Rookie question that I'm hesitant to ask.... When setting rear camber to -1, do you guys set it by adjusting the tie rods or do you leave the tie rods at the manual set up length and move the mounting point on the rear hubs.
The reason I'm asking is that I'm using a new setup sheet for my first runs on the B6D which says which mounting hole to upper middle.
Bomba is offline   Reply With Quote
Old 09-10-2016, 11:39 AM   #3148
tsair's Avatar
Adjust the tie rods lengths. Don't worry about what the lengths say in the manual, I never found them to be very accurate.
tsair is online now   Reply With Quote
Old 09-10-2016, 01:06 PM   #3149
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
I tried both the 12g and 25g versions when I was at OCRC last weekend and preferred the 12g. A buddy liked the 25g better. Just shows that it boils down to personal preference.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 09-10-2016, 01:36 PM   #3150
JAE
Thx Matt ! You get consistent grip there with the laydown on a practice day? Coming from xray I needed 3-4 degrees toe (4 degrees is shockingly kit setup)
Currently Active Users Viewing This Thread: 7 (4 members and 3 guests)
bsp, hairy17, RaceAce701, rgrg2
