    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree311Likes
Old 09-08-2016, 10:00 AM   #3106
Super Moderator
racer1812's Avatar
Trader Rating: 30 (100%+)
I don't know if I should laugh or shake my head...
I don't care if he's using a NASA satellite or a Polaroid (some might have to Google that)..send the guy a PM
Stand for the flag, kneel for the fallen.
Thank you to all of our service men and women!
racer1812 is offline   Reply With Quote
Old 09-08-2016, 10:15 AM   #3107
liljohn1064's Avatar
Trader Rating: 17 (100%+)
I've not run buggy for 6 years and then it was hit or miss. I'm now running a B6 with box stock shocks, springs and oil. I've updated to the brass bulkhead, Ti front axles, The B5 Schelle rear hubs and Lunsford turnbuckles. We run on ozite, indoor with foam tires. So far I'm having a blast on my return. I'm also setting up a second chassis to blue groove clay/dirt. Just want to say this kit is one awesome ride. Can't wait to get the second kit ready to run.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 09-08-2016, 10:28 AM   #3108
Trader Rating: 29 (100%+)
You should laugh it was a joke.... sort of
DustinEich is offline   Reply With Quote
Old 09-08-2016, 10:40 AM   #3109
Eli
Eli's Avatar
Im returning after a 3 year break of RC. Sold all my stuff when the B4.2 was the car to have for dirt and mid motor was starting to be a thing for clay. Raced a B6 last night that the owner of SDRC let me race, after un doing all his carpet stuff it was a pleasure to drive. Looking forward to getting a B6 soon, for now I have a nice B5m to drive. Cheers to you all!
Eli Westrup - SDRC Raceway
Eli is offline   Reply With Quote
Old 09-08-2016, 11:35 AM   #3110
bmx_ican92's Avatar
Originally Posted by tylem28 View Post
Just out of curiosity how long did it take each of you to fully assembly the couple kit including motor, esc, servo, receiver, etc. Also for reference was this your first time putting a kit together or did you have experience from in the past builds. Just trying to get an idea as a newbie how long it takes to assembly the entire buggy?
Im not new to RC cars just new to Buggy's. I have a couple of Traxxas Slash and have taken one completely apart to put a LCG chassis on and rebuild the transmission. thanks for all your help!
Just set aside a Saturday and take your time making sure every assembly is built exactly to the kit specs. With the build, electronics install and body it should be easily achievable in a day.
I'm also talking to you on your thread about the b6 vs b4.2 if you have any questions don't hesitate to shoot me a pm.
bmx_ican92 is offline   Reply With Quote
Old 09-08-2016, 12:20 PM   #3111
Well, the B6 is pretty good box- stock on carpet. However, carpet racing has been suspended until sometime in Oct, so I bought a set of white front and green rear springs tp go dirt racing. Hard packed clay, med-high grip. (THunder RC Raceway in Nashville).
Added a set of Electrons for tires. My question is: Do you think the 37.5 front oil iss too stiff? I was thinking trying 32.5, maybe 35w oil in front and leave the rears at 30w. Does that sound like a good starting point? I know B6D calls for 30-30 oil. But I thought the heavier front oil might help on-power steering?
Oh, I'm also going to add the 25 gram brass c block...
BruceR. is offline   Reply With Quote
Old 09-08-2016, 12:56 PM   #3112
suby723's Avatar
Trader Rating: 21 (100%+)
Way too thick. 30w front 27.5 rear.
suby723 is offline   Reply With Quote
Old 09-08-2016, 01:43 PM   #3113
vito's Avatar
just order my kit with a 17.5 and black savox servo low pro one
the happy racer
drango 410 v 4
am dyslexic
b5 mid motor
vito is offline   Reply With Quote
Old 09-08-2016, 02:02 PM   #3114
Thanks Suby. Looking to get out to practice Wednesday night...got a late start on tearing the buggy down this past week.
Old 09-08-2016, 03:00 PM   #3115
I just ordered my very first buggy kit 2wd to race. I'm super stoked i made the decision to go with the b6d and lookforward to building it.
Risingsun is offline   Reply With Quote
Old 09-08-2016, 03:21 PM   #3116
Phillip F's Avatar
Trader Rating: 15 (100%+)
This.
Phillip F is offline   Reply With Quote
Old 09-08-2016, 03:28 PM   #3117
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
Originally Posted by Phillip F View Post
Anybody knows where we can get the updated shock towers ? aluminum... thicker graphite?
I plan to try the factory rc ones....once he get more in. I have zero desire for alum towers.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 09-08-2016, 05:22 PM   #3118
Making come back after 4 years my B6 with ball diff
B4,T4,B44
RC12R5.2
T.R.C.R
pinky13 is offline   Reply With Quote
Old 09-08-2016, 06:21 PM   #3119
scr8pn4205's Avatar
On rear hubs if you only change the hub inserts and no camber link or shock length from+3 to +2 what does this change? Is it adding more roll to rear?
Airtronics M12
Team Xray XB2 2017 CE
TSR power
scr8pn4205 is offline   Reply With Quote
Old 09-08-2016, 07:20 PM   #3120
It lowers the chassis without changing suspension geometry for sure.
Currently Active Users Viewing This Thread: 14 (4 members and 10 guests)
anr211, Cday, jswo
