Team Associated B6 & B6D thread
#3016
#3017
Got my B6D with laydown built, painted and ran it for some practice laps a couple days ago. All is working really well, definitely notice the lower CoG compared to my B5M. Otherwise it feels similar which is nice. One question, Ive got my fan setup working great, so great in fact that my motor is literally cold to the touch, even in warm non-ac indoor temps after running a full battery. Its a Reedy Sonic 17.5 with the timing all the way up, geared 31/72 currently with a hobbywing justock speed control. Since my motor is staying so cool, what would you guys recommend I try for gearing? Im running indoor only on smooth high traction tracks.
Black wheels
Yellow wheels
Wiring isn't perfect but its close enough to run. Still need to shorten the servo wire and speed control to receiver wire.
Black wheels
Yellow wheels
#3018
Black wheels
Yellow wheels
Black wheels
Yellow wheels
#3020
The main track is small-ish, the secondary track is about 50% longer and pretty sizable for an indoor track. I have enough punch to clear the biggest jump but only if I have my line perfect which doesn't happen nearly enough hah. I know I need more practice but Id like to have a little more punch. Id like to try a different gear combo before throwing money at aftermarket parts.
#3021
#3023
ill soon have a new b6 lay down car
what to look out for in the build up and tips
#3024
i wouldn't have the balls to post pics of my ride with all the wiring nazi's round these parts. LOL
#3025
I know you where lol man it takes awhile to get the wiring good. Everything has to be shortened. I found with the r10 I could take apart the casing and run the wires out the back of the casing instead of the front. After the b5s and b6s I've gotten a lot better at crimping new wire leads.
#3026
Suby723 - since you came from an xb2 as well, can you post a setup that exceeded what the xb2 could do? I'm in uber high grip clay with a b6d laydown on the way.... Thx!!!
#3027
http://site.petitrc.com/setup/associ...CRC2016082628/
Also they lie about the springs. All the top Ae guys are running green rear Yokomo springs(non yatabe) and white front kyosho springs. My carpet car is similar to Ryan cavs eos setup but I use Yokomo yatabe springs. You are going to love the car! It's night and day better then the xb2. The xb2 was an epic letdown IMO but it's the first year car so I would expect the 17 model to be better. Anyways enjoy!
#3029
https://www.amainhobbies.com/yokomo-...-a1200/p417650
https://www.amainhobbies.com/kyosho-...xgs002/p193576
I've been so impressed with the b6. I even raced it on a low/med surface with the laydown and it was fairly easy to drive but I did get the b6d just because I have been so impressed with the platform I just had to get them both lol
#3030
