    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree315Likes
Old 08-30-2016, 01:04 PM   #2911
onefast8's Avatar
Trader Rating: 41 (100%+)
b6 wing mounts were a step back from the b5 imo.
Jake R.
onefast8 is offline   Reply With Quote
Old 08-30-2016, 01:55 PM   #2912
Sorry for the newbie question. But Im wanting to buy B6D and race it locally.
I viewed the links on page one and see the electronics layout
site.petitrc.com/setup/associated/setupb6/B6_ElectronicsSetup/
What are 2 to 3 small resistor looking things next to the ESC in most pics? Do they come with ESC or are they separate purchase? What is their function?
Hopefully not the completely wrong place to ask :-)
Trickyii is offline   Reply With Quote
Old 08-30-2016, 02:01 PM   #2913
They are capacitors that come with the esc.
Team Associated / Reedy / JConcepts / BoomRC
boucher is offline   Reply With Quote
Old 08-30-2016, 02:03 PM   #2914
Jmuck69's Avatar
No joke! Very flexible and feel cheap, B5M mounts way more rigid. Needs to be a running change made, possibly with a 10mm spacer for more rear traction.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 08-30-2016, 03:21 PM   #2915
You were running the 4 gear trans?
Yokomo BD8 x 2 , BD7 2016, YRX-12, Tamiya TRF419, Associated B6, B6D, B5M Factory Lite, B64D, B44.3, RC8B3, RC8B3e
My Outdated R/C Car collection:
Associated B44, Associated NTC3, Tamiya TRF415, TRF415 MSX MRE, TRF416X
190mph is offline   Reply With Quote
Old 08-30-2016, 05:18 PM   #2916
Jmuck69's Avatar
I did this past weekend with the Ray Munday set-up.
B6D | B64D
Old 08-30-2016, 08:45 PM   #2917
RCBuddha's Avatar
Trader Rating: 35 (100%+)
http://www.redrc.net/2016/08/mip-b65...iff-outdrives/
RCBuddha is offline   Reply With Quote
Old 08-30-2016, 10:09 PM   #2918
sport10's Avatar
Good call on the manual I agree use the middle hole and the length should be correct. The extremely positive camber is the red flags like the above poster mentioned. You will have to shorten the camber link if you use your previous ballstud location. Opps, noticed I responded to a much earlier post. My bad.
Hot Bodies VE8 w/ RX8-1900 combo
Losi XXX-SCT CRC conversion MMP/hacker 13.5
Associated B44
Associated B6
Durango DESC410V2 Pro
sport10 is offline   Reply With Quote
Old 08-30-2016, 10:23 PM   #2919
Built mine to this setup. I hope to take it on it's first run this weekend.
Also picked up a 15g motor weight since I didn't want to do all the cutting to run the 25g C mount with the 4 gear.
Bomba is offline   Reply With Quote
Old 08-30-2016, 10:29 PM   #2920
aeRayls's Avatar
There's almost nothing to making the 25g brass mount work. It's a 10 second job. Just notch either the motor plate or the mount with a dremel and sanding drum. Simple and easy.
aeRayls is offline   Reply With Quote
Old 08-31-2016, 04:42 AM   #2921
Default New B6
New B6 is being delivered today. Build will begin this weekend. Been reading this thread for a while and lots of great info. This is my first new build and can't wait to dig in.
AllDamage is offline   Reply With Quote
Old 08-31-2016, 10:24 AM   #2922
Jmuck69's Avatar
Essentially the setup takes the B6D back to a B5M setup meaning, narrower wheelbase.
B6D | B64D
Old 08-31-2016, 10:50 AM   #2923
scr8pn4205's Avatar
where doyou get the carbon towers that Jason Snyder is talking about on the video on petitrc. I think he says rosby towers but unsure. They have 1mm more material above the shock holes.
Airtronics M12
Team Xray XB2 2017 CE
TSR power
scr8pn4205 is offline   Reply With Quote
Old 08-31-2016, 10:54 AM   #2924
They are Raw Speed towers, they are made by his company.
jdutch03 is offline   Reply With Quote
Old 08-31-2016, 11:34 AM   #2925
BIGSKI15's Avatar
Trader Rating: 18 (100%+)
When adding the 25g weight, are you adding some weight to the front too to reduce the pendulum effect or does it remain somewhat balanced?
B6D
B5M
Airtronics M12
BIGSKI15 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
1/4milecrazy, tony6187
