    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree287Likes
Old 08-27-2016, 02:48 PM   #2881
Awesome, thank you! Am also considering getting a steel gear for added weight in the back...
microjam is offline   Reply With Quote
Old 08-27-2016, 02:49 PM   #2882
mellow's Avatar
Trader Rating: 17 (100%+)
Probably best to add weight outside of the drivetrain if you're running stock. Hence the plastic pinion used by Layton.
mellow is offline   Reply With Quote
Old 08-27-2016, 02:54 PM   #2883
Yeah try to keep weight as low as possible in your rotating parts. The brass C block would be a better alternative.
Team Associated / Reedy / JConcepts / BoomRC
boucher is offline   Reply With Quote
Old 08-27-2016, 05:44 PM   #2884
Originally Posted by suby723 View Post
My b6 was very good at thunder. I placed 6th in the Amain at the sizzler race. You will need a ball diff. Remove the waterfall to push the battery back as far as possible, 25gram brass weight and white front springs and green rear should be a good baseline setup.
In my frustration about Matt being passive aggressive on not racing, I ordered a b6d and will be racing at thunder a lot more.
Thanks for the reply. What 25 gram weight are you talking about? I see a 24g steel chassis weight. Do you happen to have a part #? I might try the gear diff with 4k oil in it for a couple of practice nights.
BruceR. is offline   Reply With Quote
Old 08-27-2016, 11:48 PM   #2885
mellow's Avatar
Uh oh...
Old 08-28-2016, 06:05 AM   #2886
Here's a cool motor plate design by VRP. Incorporates the spur protector idea into the plate.
http://www.neobuggy.net/2016/08/24/v...-motor-plates/
Old 08-28-2016, 07:02 AM   #2887
suby723's Avatar
Trader Rating: 21 (100%+)
https://www.teamassociated.com/parts...m_mount_c_25g/
suby723 is offline   Reply With Quote
Old 08-28-2016, 12:08 PM   #2888
Cuebulon's Avatar
I know its early but has anyone installed the MIP top shaft yet and notice a difference?
Cuebulon is offline   Reply With Quote
Old 08-28-2016, 12:55 PM   #2889
Default Link didn't work
Trying to post a photo and I'm struggling. Any help?
NCOHOG is offline   Reply With Quote
Old 08-28-2016, 01:07 PM   #2890
[img] *image address* [/img]
Old 08-28-2016, 01:16 PM   #2891
Thanks for the help. Finally figured it out.
Finished up a little work in the awesome factory today.
Just need to do a little deburr work.
Old 08-28-2016, 01:37 PM   #2892
Those look great. Great job!
mgers75 is offline   Reply With Quote
Old 08-28-2016, 01:45 PM   #2893
JEFFs SC10's Avatar
Trader Rating: 14 (94%+)
was anyone missing the little tiny orings that go on the outdrives?
The manual didn't show them so I figured it was ok but someone said his diff leaked all over the place without them.
XRAY 2017 T4
CRC Gen X SE- 17.5 GT
Xray X12-17' GT12
support your local tracks- Beachline Raceway-386-Full Throttle Raceway
JEFFs SC10 is offline   Reply With Quote
Old 08-28-2016, 02:16 PM   #2894
Get some MIP outdrives and lighten those. Money.
Old 08-28-2016, 07:14 PM   #2895
RC*PHREAK's Avatar
Trader Rating: 119 (100%+)
I know it was discussed but I can't remember. Is there a difference on the alum hubs if you put the zero degree etching facing forward or back?
RC*PHREAK is offline   Reply With Quote
