    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree311Likes
Old 05-03-2016, 10:10 PM   #271
Finalist's Avatar
Is anyone thinking B6D for the ball diff and flat front arm/tower with laydown kit added on, ball diff and rear shocks mounted behind arms? Also using ti rods from B5m, and aluminum hubs.
Finalist is offline   Reply With Quote
Old 05-03-2016, 10:24 PM   #272
Cridd's Avatar
Trader Rating: 16 (100%+)
Originally Posted by Jmuck69 View Post
The weights held in by grub screws is cool. Need to make a cf weight just so you can clean your car without adding weight for stock. Cool little features in new car. Battery hold down is going to be so nice, no foams or dealing with tight space.
Can't wait to see all the different setups. Stock Nats will be give a better idea for grip like OCRC. Wonder how weight looks with out of box build.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 05-03-2016, 10:27 PM   #273
Originally Posted by yeaimfast View Post
the carpet b6 would run a super high grip clay okay or would it be better to go with the 6d?
I asked Kody from AE the same question. He advised to go with the B6D for dirt/clay tracks. If you feel the need to go with the lay down transmission it is less expensive to buy the parts to convert to the lay down transmission then to get a B6 then have to get all the parts for the B6. So I'm going with the B6D and all I have to buy is the lay down transmission case, idler gear, waterfall and motor plate.
flintTRDTC is offline   Reply With Quote
Old 05-03-2016, 11:16 PM   #274
Guys,
I think we need to invent the track grip level checker tool.
I think something like a Swiffer with Sensors and a display meter. Just mount a replaceable pad and rub the track in a few places and get a reading. Then we can have a matrix chart developed to give an indication on what setup to use!
LOL!
Yokomo BD8 x 2 , BD7 2016, YRX-12, Tamiya TRF419, Associated B6, B6D, B5M Factory Lite, B64D, B44.3, RC8B3, RC8B3e
My Outdated R/C Car collection:
Associated B44, Associated NTC3, Tamiya TRF415, TRF415 MSX MRE, TRF416X
190mph is offline   Reply With Quote
Old 05-04-2016, 05:23 AM   #275
Mason's Avatar
On Clay use ankle twist method. If your foot sticks while you try to twist you may need the B6. Otherwise it will be the B6D.
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 05-04-2016, 05:25 AM   #276
Originally Posted by 190mph View Post
Guys,
LOL!
Here is what they use in the NHRA
Rhett McNair is offline   Reply With Quote
Old 05-04-2016, 05:38 AM   #277
Wonder why they didn't put out a new b44.4 first.
cosmicpilot is offline   Reply With Quote
Old 05-04-2016, 06:24 AM   #278
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Kody gave me the impression that 2wd is easier to design than a 4wd.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 05-04-2016, 06:31 AM   #279
PW
PW's Avatar
Send a message via AIM to PW
Because they finished the 2wd B6 first Stay tuned
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 05-04-2016, 07:15 AM   #280
Any info on trans ratio? Same as the B5M?
brian6674 is offline   Reply With Quote
Old 05-04-2016, 07:15 AM   #281
Want an SC6. That will be a while thou. :/
Associated B6 "Dirt Version" latemodel, Team Losi Racing 22T 2.0 Bomber Truck.
Team Losi Racing 22 2.0 2wd Short Course Truck,Duratrax 835e Brushless 8th scale Buggy,
Stock Slash, B4.1 latemodel(retired), T4.2 Factory Team BOMBER CAR
Castle Creations( Since April 2016)
bmag5000 is offline   Reply With Quote
Old 05-04-2016, 07:31 AM   #282
Jmuck69's Avatar
Should be the same, I don't think there would be any reason to change that.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 05-04-2016, 07:53 AM   #283
RCBuddha's Avatar
Trader Rating: 35 (100%+)
Same ratio. Was Confirmed on the Facebook thread
RCBuddha is offline   Reply With Quote
Old 05-04-2016, 10:13 AM   #284
Super Moderator
racer1812's Avatar
Trader Rating: 30 (100%+)
hmm that's funny...
Official TLR 22 3.0 Race Kit Thread!
Stand for the flag, kneel for the fallen.
Thank you to all of our service men and women!
racer1812 is offline   Reply With Quote
Old 05-04-2016, 10:15 AM   #285
Super Moderator
racer1812's Avatar
They're just trying to figure out how NOT make it look like an Xray
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
JsK, millsj2
