    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree287Likes
Old 08-25-2016, 06:46 AM   #2806
Originally Posted by Phillip F View Post
Is it true that the puck system is costly than using the stock parts?
You have to be very careful to watch the wear on the little orange pucks. They don't last long and if you don't change them when they start to wear you will destroy the aluminum outdrives. That's when they get expensive to maintain.
afm223 is offline   Reply With Quote
Old 08-25-2016, 06:58 AM   #2807
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
Anything you change from stock is costly....
If you are not on top of changing inserts it can ruin the outdrives very fast. Personally, I ran the pucks for a while in my b5m and one day swapped in the stock parts and had the exact same lap times...I am not a fan of the pucks and they will not be making their way into my car.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 08-25-2016, 07:10 AM   #2808
Fabulous's Avatar
Trader Rating: 42 (100%+)
You will be spending money to buy the puck system theres a cost. Does it last longer than stock parts? No! It will give you more maintenence, with little extra performance.
Fabulous is offline   Reply With Quote
Old 08-25-2016, 08:45 AM   #2809
Besides what's in the B6D kit, which oils and grease do I need to buy for build and racing? Is anyone using Utter Butter?
I don't mind spending a little extra for rebranded RC hobby stuff because I'm not likely to use all the bulk automotive stuff and I like that the hobby oils/grease come in little applicators, I just don't know which ones are good value...
microjam is offline   Reply With Quote
Old 08-25-2016, 08:48 AM   #2810
mellow's Avatar
Trader Rating: 17 (100%+)
Always good to have some Loctite in the box.
"It'd be a lot cooler if you did."
mellow is offline   Reply With Quote
Old 08-25-2016, 08:49 AM   #2811
Only thing I'd really recommend is some green slime (#1105). You'll get enough diff lube and grease in the kit to rebuild your diffs a couple times. I guess you could pick up some different shock oils too.
Team Associated / Reedy / JConcepts / BoomRC
boucher is offline   Reply With Quote
Old 08-25-2016, 09:37 AM   #2812
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
not true. it really depends on your surface. for indoor wet clay I only work on the pucks twice a year. if you are on a dust dirty surface. the new roller pucks might be good. we grease the plastic pucks, and dust can mix in with the grease and require more cleaning and such
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is online now   Reply With Quote
Old 08-25-2016, 09:44 AM   #2813
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Wildcat1971, I think this part of your statement validated his point.
Moral of the story, if you grease the plastic pucks and that grease gets contaminated with foreign debris it will require you to clean and re-grease them in order for them to last longer than if you left them alone.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 08-25-2016, 09:49 AM   #2814
I agree. I was being more specific to the need for additional maintenance. the more dirty a track is, the more the maintenance of everything goes up. bearings, hinge ins, etc.
my personal laptime are .5 second faster with pucks. because the car corners better and faster
Old 08-25-2016, 09:54 AM   #2815
Super Moderator
Piggybacking off this ^
Keep in mind that pucks will free up the rear of the car...both due to the less weight over the rear end and the less bone bind. If you run on a high bite track (like Wildcat) this could be a benefit...if you run on a low bite track throwing a bunch of lightweight parts in your driveline will probably make the car worse.
Old 08-25-2016, 10:19 AM   #2816
rvrslt1's Avatar
Trader Rating: 24 (100%+)
I am having an issue with my car pushing real bad in the corners. What can be done to reduce this?
rvrslt1 is offline   Reply With Quote
Old 08-25-2016, 10:25 AM   #2817
Super Moderator
Without posting current setup, track, tires, etc... no one can give you any info.
Based of the info you currently have I would say turn the wheel more.
Old 08-25-2016, 10:31 AM   #2818
need more info like are you pushing on power or off power? entry mid or exit? but generally you could try things like:
- add weight to front or remove weight from rear
- reduce front roll center
- play with suspension, maybe your rear is too soft or front is too stiff
- what is your camber set at and camber gain?
- increase rear droop
- 3 gear or 4 gear tranny? laydown or stand up? laydown will reduce a push
i was on board with you until you said turn wheel more. turning the wheel more when your car is pushing wont solve the problem. if your going to be smart, at least be intelligent.
| XRAY XB8E 16' | XRAY XB4 16' | XRAY XB2 CE 17' |
| New England | RCE | RCM |
lyons238 is offline   Reply With Quote
Old 08-25-2016, 10:40 AM   #2819
rvrslt1's Avatar
Thanks for the help. Will try to turn a little more
3 gear lay down. Brass C mount AE front bulk head Gray front 32.5 oil 2x1.6 green rear 30wt oil green spring 2x1.7. Schelle rear hubs 22mm front and back ride. -1 camber front and rear. Clay track with proline electrons
Real close to Kurt's set up from Schelle
Old 08-25-2016, 10:41 AM   #2820
vito's Avatar
do i need to buy rims is so what one fit will the b 5 one still work
the happy racer
drango 410 v 4
am dyslexic
b5 mid motor
vito is offline   Reply With Quote
Currently Active Users Viewing This Thread: 7 (3 members and 4 guests)
bobf24, joncmack, Phillip F
