    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree287Likes
Old 08-24-2016, 10:36 AM   #2791
lbckevin's Avatar
Trader Rating: 89 (99%+)
Originally Posted by JEFFs SC10 View Post
Will the exotek slipper elim from the B5 fit on the B6?
yes
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 08-24-2016, 11:05 AM   #2792
mellow's Avatar
Trader Rating: 17 (100%+)
Good to know.. I have a team orion servo, whcih I believe uses the same horn.
On the exotek slipper elim, it works.
"It'd be a lot cooler if you did."
mellow is offline   Reply With Quote
Old 08-24-2016, 11:27 AM   #2793
BIGSKI15's Avatar
Trader Rating: 18 (100%+)
It fits perfectly onto the spline. The only issue I've had is that since its aluminum, the servo horn screw has come loose twice, so I used a small amount of loctite
Originally Posted by 190mph View Post
Tower has in stock the #1366 25T Futaba fitting servo horn if anyone is waiting for this. I just hope it slips on nice, I hate the badly made spline teeth ones that you have to hammer on and pry off with the screwdriver.
B6D
B5M
Airtronics M12
BIGSKI15 is offline   Reply With Quote
Old 08-24-2016, 11:35 AM   #2794
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
Also, the servo link tends to bind up more than the rest of the ball cups. which helps the stud come loose. you can use the b5 pinch method or use a ball cup reamer. I pinched mine until it was good
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 08-24-2016, 12:22 PM   #2795
mellow's Avatar
B5 pinch method?
Old 08-24-2016, 12:23 PM   #2796
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
Originally Posted by mellow View Post
B5 pinch method?
pinch the ballcup while it is installed on a ball to free it up.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 08-24-2016, 01:31 PM   #2797
mellow's Avatar
That's kind of what I figured. Thanks Matt.
Old 08-24-2016, 07:41 PM   #2798
JEFFs SC10's Avatar
Trader Rating: 14 (94%+)
How much weight do you have to add for a B6 to make weight? sorry haven't been keepin up. do I need to buy that brass sheet to go under the batt?
XRAY 2017 T4
CRC Gen X SE- 17.5 GT
Xray X12-17' GT12
support your local tracks- Beachline Raceway-386-Full Throttle Raceway
JEFFs SC10 is offline   Reply With Quote
Old 08-24-2016, 08:22 PM   #2799
With the bi-metal pucks from a B5, lay down tranny, cut gears, full size servo, xr10 juststock, Exotek slipper eliminator, Pro-Line front wing and mount, Pro-Line body, and 2.2 Electrons (everything else stock). My B6D is weighing in at 1496 grams. I'm going to switch to the Hobbywing 3.1 stock spec esc and add a fan to the motor to get it up to legal weight.
afm223 is offline   Reply With Quote
Old 08-24-2016, 08:53 PM   #2800
mellow's Avatar
About the pucks system...I've been out of the scene for awhile, so bear with me.
It's my understanding that the 17.5 puck system here: https://www.amainhobbies.com/mip-puc...p16080/p520428 would be better for stock racing..hence the name.
And the bi metal puck system here: https://www.amainhobbies.com/mip-ass...p16060/p524958 is more suited for mod?
It appears the bi metal kit would be a heavier overall system with the steel outdrives and metal pucks, compared to the plastic pucks and aluminum outdrives on the 17.5 system. This sound about right?
Old 08-24-2016, 09:01 PM   #2801
MikeR's Avatar
Trader Rating: 15 (100%+)
I don't like any of Associated's plastic 1/10 scale servo horns in the kit. They never fit on the Futaba at least. You can see the servo spline teeth cutting into the horribly made molds. Just never felt sure it was gonna fit right.
Pretty much the way to go now- clamping for the B6;
https://www.amainhobbies.com/exotek-...547blk/p467028
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 08-24-2016, 09:22 PM   #2802
Just starting a B6D with Laydown kit. I'm just going by the manual in the box - is there a more updated version online that I should be using?
microjam is offline   Reply With Quote
Old 08-24-2016, 09:23 PM   #2803
use the online version
Old 08-24-2016, 10:19 PM   #2804
You are correct. The 17.5 version is the one I have in my car. I think in the past that one was called bi-metal. Anyway, the all aluminum is the way to go for 17.5 racing.
Old 08-25-2016, 06:34 AM   #2805
Phillip F's Avatar
Is it true that the puck system is costly than using the stock parts?
Phillip F is offline   Reply With Quote
Currently Active Users Viewing This Thread: 13 (6 members and 7 guests)
brian mills, hairy17, JLinney, Mattmaroney, RaceAce701, Sean Cochran
