    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree311Likes
Old 08-23-2016, 01:17 PM   #2776
Super Moderator
racer1812's Avatar
Trader Rating: 30 (100%+)
This is getting old.
This thread isn't the place to look to buy, and it's not the place to offer to sell. Whether it's parts pieces or entire cars.. Sounds harsh but if we allow it this will be nothing but a sales thread.
Thank you.
Stand for the flag, kneel for the fallen.
Thank you to all of our service men and women!
racer1812 is offline   Reply With Quote
Old 08-23-2016, 01:20 PM   #2777
mellow's Avatar
Trader Rating: 17 (100%+)
It goes down in the PMs
"It'd be a lot cooler if you did."
mellow is offline   Reply With Quote
Old 08-23-2016, 01:24 PM   #2778
Super Moderator
racer1812's Avatar
Old 08-23-2016, 01:42 PM   #2779
mellow's Avatar
Will this make up for my horrible joke?
Old 08-23-2016, 03:20 PM   #2780
Phillip F's Avatar
Trader Rating: 15 (100%+)
Yeah... How much?
Phillip F is offline   Reply With Quote
Old 08-23-2016, 03:21 PM   #2781
mellow's Avatar
Originally Posted by Phillip F View Post
Yeah... How much?
Old 08-23-2016, 03:29 PM   #2782
mellow's Avatar
In stock
http://www.schelleracing.com/Schelle...1257?limit=100
Old 08-23-2016, 04:43 PM   #2783
Originally Posted by tsair View Post
I also run at Nor-cal with a Reedy M3. 31/69 works for me on the current layout at 38 degrees of timing, motor comes off about 135-145. I'd gear up a tooth on the pinion.
Slipper eliminator and MIP bi-metal drives will also do wonders for acceleration.
Tightened down my slipper a little more (about 3-4 threads visible), increased timing from 20 to 30, and also tightened up my ball diff. Someone noticed by sound that my diff was too loose, I kept thinking it was the slipper!
Anyway, all the adjustments helped and I had no issues clearing all the doubles on a fresh pack today (norcal hobbies).
Current set up had the motor (17.5 reedy m3) clocking in around 110 deg. Next time I get a chance I'd like to try increasing timing a few more degrees or try a different pinion (using 31 right now).
Limeaway is offline   Reply With Quote
Old 08-23-2016, 04:57 PM   #2784
tsair's Avatar
Hah, you must have been the Asian guy with glasses and a blue shirt today? I was the other Asian guy driving the red/white/black B6 in my avatar. Next time I'll say "hi". Glad to hear your buggy is working better.
Razor RC blog:
http://razorrcblog.blogspot.com
http://youtube.com/c/RazorRC
tsair is offline   Reply With Quote
Old 08-23-2016, 08:06 PM   #2785
AZJP's Avatar
Trader Rating: 20 (100%+)
https://www.amainhobbies.com/mip-car...p16110/p523239
AZJP is offline   Reply With Quote
Old 08-24-2016, 09:55 AM   #2786
Tower has in stock the #1366 25T Futaba fitting servo horn if anyone is waiting for this. I just hope it slips on nice, I hate the badly made spline teeth ones that you have to hammer on and pry off with the screwdriver.
Yokomo BD8 x 2 , BD7 2016, YRX-12, Tamiya TRF419, Associated B6, B6D, B5M Factory Lite, B64D, B44.3, RC8B3, RC8B3e
My Outdated R/C Car collection:
Associated B44, Associated NTC3, Tamiya TRF415, TRF415 MSX MRE, TRF416X
190mph is offline   Reply With Quote
Old 08-24-2016, 10:03 AM   #2787
mellow's Avatar
Have the stock servo horns been causing issues? There's a lot of horn talk over on the fb page.
Old 08-24-2016, 10:12 AM   #2788
I don't like any of Associated's plastic 1/10 scale servo horns in the kit. They never fit on the Futaba at least. You can see the servo spline teeth cutting into the horribly made molds. Just never felt sure it was gonna fit right.
Old 08-24-2016, 10:32 AM   #2789
jmcelroy42's Avatar
I had a really hard time getting the plastic Associated horn on my Protek servo. I had to use a combination of tapping it on and using the screw to pull it down. On my 2nd car I just dremeled the last hole off of my Racers Edge one so it would clear the upper plate, and so I didn't have to mess with the Associated one.
EB48.4 - TEKIN RX8 & SMC 2100
XB4 '16 - TEKIN RSX & ORCA 5.5
RC10B6 - HW Justock & 24K 17.5
jmcelroy42 is offline   Reply With Quote
Old 08-24-2016, 10:34 AM   #2790
JEFFs SC10's Avatar
Trader Rating: 14 (94%+)
Will the exotek slipper elim from the B5 fit on the B6?
JEFFs SC10 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
