    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree285Likes
Old 08-18-2016, 08:27 AM   #2686
mellow's Avatar
Trader Rating: 17 (100%+)
Haha, let's hope so
"It'd be a lot cooler if you did."
mellow is offline   Reply With Quote
Old 08-18-2016, 09:18 AM   #2687
celt's Avatar
Originally Posted by jmcelroy42 View Post
It looks to me like they just took a picture of one and mirrored it. All of the little imperfections look identical just mirrored.
Indeed, your right...good eye.
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is offline   Reply With Quote
Old 08-18-2016, 10:10 AM   #2688
Trader Rating: 48 (100%+)
Anyone tested 3x1.4 pistons In the rear yet? I'm curious to see how it effected the car?
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 08-18-2016, 01:33 PM   #2689
I am actually in the process of making this change along with tall tower and 31mm Kashima shocks. Ill let you know how it goes after I take it to the track.
TOBAMA is offline   Reply With Quote
Old 08-18-2016, 02:32 PM   #2690
Trader Rating: 14 (100%+)
I'm really interested in what you find out
"Go that way really fast, if something gets in your way, turn"
TLR 22 3.5 SR, TLR 22-4 1.875, Sanwa M12S, Savox, Hobbywing, Schuurspeed, Protek
DG Designs is offline   Reply With Quote
Old 08-18-2016, 02:54 PM   #2691
celt's Avatar
Default Tessmann inverted shocks...
Anyone dare to try this?
That's some low CG.
Stan Garvin
Old 08-18-2016, 03:07 PM   #2692
Pville Stig's Avatar
I think he was messing with people.
RC America/XRAY
LRP America
AKA Products
Pville Stig is offline   Reply With Quote
Old 08-18-2016, 03:10 PM   #2693
Quick question, can a gear diff be put into a B6D if one wanted to?
DrVest is offline   Reply With Quote
Old 08-18-2016, 03:35 PM   #2694
Yes you can use the B5M gear diff by adding 91605 shims in the gearbox or buy a B6 gear diff which is basically a diff + the needed shims
MatthieuL is offline   Reply With Quote
Old 08-18-2016, 03:50 PM   #2695
celt's Avatar
Nope, my understanding, he ran it that way at the Nats.
Stan Garvin
Old 08-18-2016, 04:08 PM   #2696
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
Tanner and Ty ran it that way at Nats....but....that car is all kinds of wonky.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 08-18-2016, 04:58 PM   #2697
xyzracer's Avatar
The problem with mounting the shocks like this is that the pistons are sitting in the air gap at the top of the stroke so you have no actual damping at full droop
xyzracer is offline   Reply With Quote
Old 08-18-2016, 05:28 PM   #2698
They use bladders so there is no air gap. At least that's how Gord Tessman builds them according to his youtube video. I suspect Tanner's setup is the same also.
will5879 is offline   Reply With Quote
Old 08-18-2016, 06:55 PM   #2699
Trader Rating: 15 (100%+)
Can anyone running a B6 gear diff comment on its ability to hold oil? I had one in my SC10 and within a few race days all the black grease would have worked its way out. I had one in my B5 and it leaked. I bought the aluminum cap and it was better, but still not great.
Daragh Slowey
22-4 2.0/R10/Scorpion5.5/S6040/Nosram shorty
B5R/R10/LRP8.5/1258TGBlk/Nosram shorty
EB48SL/RX8/TekinT8i/Hitec7599/SMC4500(4S)
Grasshopper/Tekin FX/Twister 27T/FutabaS9551/Speed power
HeavyD99 is offline   Reply With Quote
Old 08-18-2016, 07:00 PM   #2700
Silverstonev8's Avatar
Did you sand the case? My B6 is on the way but haven't had problems with the B44.3 or RC8 truggy or buggy. I sanded them a bit tho.
Silverstonev8 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
coaltrain
