    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree287Likes
Old 05-03-2016, 03:04 PM   #256
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
Ok. Cool. The manual will help answered a lot of questions once it is online
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 05-03-2016, 05:12 PM   #257
Cridd's Avatar
Trader Rating: 16 (100%+)
getting the shocks straight B5 fronts carry over, any 5 series vehicle rears carry over to B6 Rear?
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 05-03-2016, 05:26 PM   #258
yeaimfast's Avatar
the carpet b6 would run a super high grip clay okay or would it be better to go with the 6d?
yeaimfast is offline   Reply With Quote
Old 05-03-2016, 05:46 PM   #259
RC*PHREAK's Avatar
Trader Rating: 119 (100%+)
I'm more confused than ever on which to go with for high grip clay (slicks). I may cancel my pre-order and wait for this thing to play out.
RC*PHREAK is offline   Reply With Quote
Old 05-03-2016, 06:00 PM   #260
3n90t's Avatar
It's like the B5m, it was meant for the Higher grip tracks compared to the B5R, but it can be made to run on dusty bumpy loose tracks like we have here in Australia.
I think the B6 with the gull wing arms allow you to lower ride heights for the higher grip tracks (correct me if I'm wrong)
AE: B5, B5M, B44.3, B6D, B64D
Tamiya: MF-01X Suzuki Jimny JB23
3n90t is offline   Reply With Quote
Old 05-03-2016, 06:07 PM   #261
Jmuck69's Avatar
In the B6 Facebook group, Kody said for OCRC (med-high grip) he would run the B6D and sometimes the B6. I think it would be wise to get the B6D then buy the components to make it the B6. Complete laydown transmission with its waterfall, gullwing front arms and tower. If conditions call for the high grip, then swap it out. Honestly the only dirt tracks I know that have carpet/turf grip levels are SRS in Arizona and Beachline RC in Florida.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 05-03-2016, 06:40 PM   #262
ANDRXW's Avatar
Anyone understand how the battery strap works? Seems almost redundant to have the thumbscrews and new collars below the strap, yet have the two button head screws at the back.
/ / ANDRXW.com
ANDRXW is offline   Reply With Quote
Old 05-03-2016, 06:44 PM   #263
Jmuck69's Avatar
I would think the two screws on the strap to adjust for the slight differences in battery dimensions. Needs to be a snug fit. The collars are to adjust for the height of lipos so when you tighten down it clamps and doesn't bend the strap. Actually a elegant system. No need for foam.
B6D | B64D
Old 05-03-2016, 06:51 PM   #264
Jmuck69's Avatar
Default Pic of strap system by Kody
https://www.facebook.com/permalink.p...bstory_index=0
B6D | B64D
Old 05-03-2016, 06:58 PM   #265
ANDRXW's Avatar
Thanks, that definitely helps clear up some confusion. The button heads seem to be mounted to a 'retainer' underneath the strap that keep the battery from sliding backwards.
From the pictures, I was under the assumption the screws would thread through the strap and into solid posts mounted to the chassis; requiring you to remove thumbscrews AND the two button heads.
/ / ANDRXW.com
Old 05-03-2016, 07:39 PM   #266
Trader Rating: 18 (100%+)
I think people are getting confused about the difference between high grip dirt/clay and astroturf or carpet. The way the cars are set up for the two conditions are drastically different. Just because they call it high grip clay doesn't mean it has as much traction as carpet. I don't understand why everyone asks Kody what to run and then argue the point after.
Chris Brown is offline   Reply With Quote
Old 05-03-2016, 07:47 PM   #267
Because that is the way people are. They know it all and want him to confirm it.LOL!
Team Associated, JConcepts, M2C Racing, Big Pimpin Paints
Chris Reilly is offline   Reply With Quote
Old 05-03-2016, 07:56 PM   #268
RCBuddha's Avatar
Trader Rating: 33 (100%+)
I updated the first page to reflect some of the questions and answers from the facebook thread.
Some highlights:
Rear shock bodies on the B6/b6d are smaller than the B5/b5m.
turnbuckles are nickle plated spring steel
Shock towers are lower in the rear, thus the smaller shock bodies
B5 series diffs will fit in B6 gear cases with shimming
shocks use V2 shafts
No RTR B5/B5
No conversion kit for B6 to B6D...
B6/B6D chassis are the same and eliminate the front nose piece for strength
Gear diff and ball diff are interchangeable
wheels are the same offset as the b5 series
4 gear will be an option
RCBuddha is offline   Reply With Quote
Old 05-03-2016, 09:37 PM   #269
AZJP's Avatar
Trader Rating: 20 (100%+)
SRS is only super high grip when it's taken care of, which it hasn't really been since cactus. I wouldn't be surprised if cactus is held somewhere else next year.
AZJP is offline   Reply With Quote
Old 05-03-2016, 10:04 PM   #270
Kegman21's Avatar
Ordered the B6. 702 is my home track and with carpet I can not wait. Buggies or anything on carpet is all about the low cg. I heard Associated have been putting down time on the track on Mondays when the track is closed to test and practice on the Carpet.
But even Tracks of Las Vegas It is sugar or what ever they put on for the worlds still mixed in the dirt. High bite. Now I don't have to buy one of the X-rays or Schumacher buggies.
HB D413/ SMC160A/ Sanwa M12S/ Associated B6 🚓
Kegman21 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
