    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree309Likes
Old 08-15-2016, 05:28 AM   #2581
Ran the B6 for the first time Sunday. This was also my first time ever running a buggy. This car reacts very quickly compared to a T5M. I thought it did well, just had a bit of an issue with the car pushing during on-power turns. I thought going to 1mm spacer, or no spacer, on the ackerman might solve the issue. But, I just left it alone for the moment.
Race results were pretty good. First qualifier, spent a lot of time being marshalled and was 7th out of 8. Second qualifier I settled down and tried to be smooth, if not super fast. Placed third. My main came up and I was third again! Now, this was B-Main, so I understand I have work to do, but I was pretty happy with the results considering I've never ran buggy before. I think I'll keep this car.
Oh, I'll add it was the box stock set up. Using a Reedy Mach3 17.5, Reedy BlackBox 800Z esc, and Savox 1257 servo.
BruceR. is offline   Reply With Quote
Old 08-15-2016, 06:18 AM   #2582
skrichter's Avatar
Send a message via AIM to skrichter
Spencer's car from Nats.
Notice the NEW REEDY BLACKBOX.
LiveRC.com | Dirt Heaven Hobby & Raceway
skrichter is offline   Reply With Quote
Old 08-15-2016, 06:46 AM   #2583
Mason's Avatar
losi won nats? aw shucks. Well congrats to them.
If you're looking to move into a B6, starting today they could be a bit less expensive on the for sale forum.
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 08-15-2016, 07:27 AM   #2584
Trader Rating: 16 (100%+)
Yeah, but those were Losi with the laydown conversions. I think most will stick with the B6 vs a $600 Losi.
MX304 is offline   Reply With Quote
Old 08-15-2016, 07:35 AM   #2585
Suspended
Trader Rating: 61 (100%+)
Won the only class I care about; 17.5.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 08-15-2016, 07:48 AM   #2586
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
are you using pucks?
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 08-15-2016, 02:58 PM   #2587
Trader Rating: 115 (98%+)
is it true that pucks cause a small bind which gives up some traction.
ashxxx is offline   Reply With Quote
Old 08-15-2016, 03:03 PM   #2588
wonder what kind of sauce that is?
Xb4 Rc10b6 Rc8b3e
carpetburner is offline   Reply With Quote
Old 08-15-2016, 03:09 PM   #2589
Suspended
Less bind.
Old 08-15-2016, 03:14 PM   #2590
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
Originally Posted by Socket View Post
Less bind.
Giving out all the secrets....
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 08-15-2016, 03:33 PM   #2591
I am sure it starts as "Sticky" but cannot make out the next line on the label. I don't think it is Sticky Kicks as they have the different look and bottles.
Yokomo BD8 x 2 , BD7 2016, YRX-12, Tamiya TRF419, Associated B6, B6D, B5M Factory Lite, B64D, B44.3, RC8B3, RC8B3e
My Outdated R/C Car collection:
Associated B44, Associated NTC3, Tamiya TRF415, TRF415 MSX MRE, TRF416X
190mph is offline   Reply With Quote
Old 08-15-2016, 03:57 PM   #2592
fullsyzz's Avatar
Trader Rating: 102 (100%+)
Sticky Situation.
Official Team Associated B6 & B6D thread-12657398_1696575430589374_5316766251271516951_o.jpg
fullsyzz is offline   Reply With Quote
Old 08-15-2016, 05:21 PM   #2593
avaldes's Avatar
That was the handout traction compound at the nats.
avaldes is offline   Reply With Quote
Old 08-15-2016, 05:41 PM   #2594
mellow's Avatar
Trader Rating: 17 (100%+)
Hi Sy
"It'd be a lot cooler if you did."
mellow is offline   Reply With Quote
Old 08-15-2016, 06:40 PM   #2595
Gigasipke's Avatar
Probably blasphemous but I took my B6D out on dirt. I didn't race it because there was enough guys to run Truck so I ran my T5M. But I did practice with it and compared it to my B5.
I used the B6D setup in the manual and it was quite dialed. Had a push and needed a little more on power steering but wow does it have rear traction and flys like a dream. Running weight was 1502g using the standard transmission.
To be fair I had worked on the setup on my B5, I was still struggling with oversteer issues but was really good until it wasn't and then was snap loose. I had similar average lap times between both buggies but had my quickest laps with the B6D. I think more practice and setup tweaks I can get it even that much faster then my B5.
A quick note: Everyone at the track runs rear motor , except my son who runs a B5M and he usually finishes mid-pack.
The B6D felt nimble and planted in essentially box stock forum. During practice I was running right with one of the mod buggies, he could clear one of the triples when I had to double single but even on the straight I could carry more entry speed so he only would pull ahead a slight amount on the straight before I was right on him. I could hang with him on the infield without issue, for a little bit I thought that maybe he was running a 17.5 but remembering he could easily clear the triple knew he wasn't. He commented afterward on how fast my buggy was running.
At this point I will be getting my son one, our indoor track I think will be an astro turf one, so will throw in the laydown at that time.
-T5M (13.5), - B6D (17.5)
-Mad Dogz Hobby Team Driver
https://youtu.be/Rg4Jlid5dFo
Steve Aldous
Gigasipke is offline   Reply With Quote
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
TruggyStyle
