    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree309Likes
Old 08-10-2016, 08:00 AM   #2461
Silverstonev8's Avatar
Originally Posted by Wildcat1971 View Post
Oh, I 100% stole the idea from him. He even suggested the paints to custom mix that color....That pink is is a "custom" air brush spray bomb. lol. Sorry, but no one runs pink and the color really pops for my old eyes So, I will keep it
I ran pink a few years ago. Lol
Silverstonev8 is offline   Reply With Quote
Old 08-10-2016, 08:12 AM   #2462
I have a pretty dialed B5M FL that I run at DRP in Old Forge, Pa. But on Sunday I bought a B6 from A Main with a $20 off coupon and opted for the free shipping for $289. It should arrive on the 16th.
DRP is ozite carpet and very "supercrossy", there is usually one corner done in thin MDF to make it slick. I read this whole thread, but skipped the drama. I'm not the best driver, but I'm within 1.3 secs/lap of the fastest guys. I'm a 40 something with a descent job, and I do this more for the fun of it rather than trying to win the a-main. What are your thoughts on weight %s for 17.5?
What are some of the "must haves" for 17.5 carpet besides pucks and slipper eliminator?
FYI I also know I'll need to change to the ball diff to make the pucks work.
BigChris in PA is offline   Reply With Quote
Old 08-10-2016, 08:18 AM   #2463
jmcelroy42's Avatar
MIP has Pucks outdrives for the gear diff now
http://miponline.com/store/mip16041.html
EB48.4 - TEKIN RX8 & SMC 2100
XB4 '16 - TEKIN RSX & ORCA 5.5
RC10B6 - HW Justock & 24K 17.5
jmcelroy42 is offline   Reply With Quote
Old 08-10-2016, 08:22 AM   #2464
Did not know that thanks!
So that means no spacers in the tranny then right?
What about spacers as the axles pass through the rear hubs?
Old 08-10-2016, 08:23 AM   #2465
jmcelroy42's Avatar
Default Nobody runs pink?
I run pink too, although there's some blue and black also.
Official Team Associated B6 & B6D thread-pink1.jpg   Official Team Associated B6 & B6D thread-pink2.jpg
Old 08-10-2016, 08:25 AM   #2466
jmcelroy42's Avatar
The B6 gear diff still uses the spacers in the tranny, and you will most likely need the ones in the axles too.
Old 08-10-2016, 08:30 AM   #2467
Bigchris,
Don't go crazy with must have upgrades..
We run machined shock bushings, machined pistons, x rings. Last year's b5m with laydown I had kashima shock bodies... I ran a bone stock yz2 last year and was competitive in 17.5
I run @drp as well.
Scott
hyperdive08 is offline   Reply With Quote
Old 08-10-2016, 08:40 AM   #2468
Scott, Are you the red bull car? If so we've met.
Old 08-10-2016, 09:48 AM   #2469
Yes I am. Any help you need at all come see me.
Old 08-10-2016, 10:43 AM   #2470
I have and will. You were the one who helped get my B5M FL dialed in, and let me put a few laps on your car last fall. Thanks.
I'm kinda stoked 'bout getting the B6 and trying it out.
I'll post some pics along the way as I build and paint.
Here's what I've got coming:
B6 kit (AMain)
MIP 16085 B5M to B6 spacer conversion $9 (from MIP)
MIP 16041 B5/B6 gear diff outdrives $18 (from MIP)
MIP 14230 Bi Metal pucks ~$57 (from ebay power_hobby)
Old 08-10-2016, 11:51 AM   #2471
Suspended
Trader Rating: 61 (100%+)
Ready for the weekend!
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 08-10-2016, 11:56 AM   #2472
tony montana's Avatar
Trader Rating: 65 (100%+)
Looks good socket. What kind of surface are you running on?
K.C. Guy. Team Xray - rc america
tony montana is offline   Reply With Quote
Old 08-10-2016, 11:59 AM   #2473
Suspended
This weekend will be carpet at Ricochet RC....
In super super southern California
Edit: Thanks for the compliment. I appreciate it!
Old 08-10-2016, 12:05 PM   #2474
Super Moderator
racer1812's Avatar
Trader Rating: 30 (100%+)
I like the Motiv motor. Paul L is a pretty cool guy, and semi local (3 hours away)
Stand for the flag, kneel for the fallen.
Thank you to all of our service men and women!
racer1812 is offline   Reply With Quote
Old 08-10-2016, 12:07 PM   #2475
Just don't wander into Mexico by accident. They will want your RC gear or more to let you back into the USA.
Yokomo BD8 x 2 , BD7 2016, YRX-12, Tamiya TRF419, Associated B6, B6D, B5M Factory Lite, B64D, B44.3, RC8B3, RC8B3e
My Outdated R/C Car collection:
Associated B44, Associated NTC3, Tamiya TRF415, TRF415 MSX MRE, TRF416X
190mph is offline   Reply With Quote
Currently Active Users Viewing This Thread: 6 (1 members and 5 guests)
bshookup
