    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree287Likes
Old 08-09-2016, 07:58 PM   #2446
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
Alum hubs are less bite imo
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 08-09-2016, 09:15 PM   #2447
Phillip F's Avatar
Trader Rating: 15 (100%+)
Originally Posted by mx836 View Post
Aluminum hubs are a very popular upgrade and often a weak point on RC vehicles. One of few parts that are commonly switched from plastic to aluminum. I made the suggestion base on durability since he was having an issue with the hubs, same as I did. Fixing one weak point makes it more difficult to break your car, even if it is a bigger or more expensive part that may be the next weak link. I'd rather finish races than have more hypothetical bite. Just my opinion.
I see your point. But the plastic parts IMHO is fine as it is and the car is pretty dialed for my driving style. I just wish they have a beefier insert installed in their or even I can settle with the same inserplastic insert as long as associated sells it separately.
Phillip F is offline   Reply With Quote
Old 08-09-2016, 09:22 PM   #2448
Cuebulon's Avatar
Originally Posted by 190mph View Post
AMain says the kits are arriving this Thursday moving date up from the 17th.
Tower just got them in. Both kits In Stock Limited Quantities, hopefully just the first skid of many received this week.
I got to buy the D still and the Tower e-cash promo will soon line up next week likely with that. Hopefully it stays in stock.
Thank you so much for this. Just got mine ordered!
Cuebulon is offline   Reply With Quote
Old 08-09-2016, 09:36 PM   #2449
MaxxBashers's Avatar
Trader Rating: 107 (100%+)
Ditto. Got mine ordered as well. Thanks for the heads up.
MaxxBashers is offline   Reply With Quote
Old 08-09-2016, 10:26 PM   #2450
Originally Posted by Mason View Post
The simplest solution is to use some large faced washers that cover the top and bottom of the plate so the pressure is applied to the hub piece. I know of no one making the insert itself in any other material but it would be nice if possible.
Keep in mind this is only going to go so far. If you're landing on the edge of the wheel in a high speed tumble something must give. Chances are anything else would be more expensive.
Thanks, i will try a larger washer on both sides
Erolyobruh is offline   Reply With Quote
Old 08-10-2016, 02:21 AM   #2451
Originally Posted by Phillip F View Post
that motor is a beast....had to get a fan for that motor to get optimum performance.
BTW... that's one big picture file.
Love the paint job I race out of speed RC on Wednesday going today my name Jason. I have a YouTube channel called RC vitals we got some b6 racing out of there I go into their car setups. Anyway I'll be there tomorrow
828Army is offline   Reply With Quote
Old 08-10-2016, 03:57 AM   #2452
Originally Posted by Wildcat1971 View Post
Here is a few laps at SRS with my B6D and laydown. I was running un-sauced proline 2.2 clay slicks. Pucks, Avid Slipper and the laydown are pretty much the only upgrades.
https://www.youtube.com/watch?v=W_qiunFgWeU
Sweet track and nice laps!
Schuie Driver is offline   Reply With Quote
Old 08-10-2016, 05:37 AM   #2453
SuperRC's Avatar
Question,
Are the shock cap o ring (#91491) and the threaded shock collar o ring (#91304) the same 12mm o ring? They were in the same bag and all 8 of them looked identical.
On my SC5M they were in separate bags, however comparing the two, again they looked identical. Same thickness and diameter.
SS
SuperRC is offline   Reply With Quote
Old 08-10-2016, 05:51 AM   #2454
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
Originally Posted by SuperRC View Post
Question,
They are the same.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 08-10-2016, 07:07 AM   #2455
SuperRC's Avatar
Originally Posted by Matt Trimmings View Post
They are the same.
Thank you.
SS
Old 08-10-2016, 07:07 AM   #2456
Super Moderator
racer1812's Avatar
Trader Rating: 30 (100%+)
All pink body..who do you think you are, Untamed Fruit?
Stand for the flag, kneel for the fallen.
Thank you to all of our service men and women!
racer1812 is offline   Reply With Quote
Old 08-10-2016, 07:09 AM   #2457
Super Moderator
Uh oh.....who had the all pink body first?
Old 08-10-2016, 07:14 AM   #2458
Super Moderator
racer1812's Avatar
Rear hubs..I've NEVER seen that plastic part break. How do you even break that little piece and NOT break the hub itself
I have a NIB set of $35 aluminum hubs sitting in my box (B5m) only because I've seen WAY too many guys break ball studs with them, guys with WAY more talent than me. You're getting a DNF from breaking anyway, I would rather spend $9 for the stock hubs vs. $35 because the ball stud thread is stuck in the aluminum hub. Ya, sometimes you can get it out, but sometimes you can't.
IMO
Old 08-10-2016, 07:18 AM   #2459
Super Moderator
racer1812's Avatar
I'm gonna guess The Fruit. Maybe Crazy Kitty is trying to #MakeRCtechGreatAgain..?? OR he's a closet Fruit fan?
Wildcat knows me well enough to know I'm playing with him
Old 08-10-2016, 07:44 AM   #2460
Oh, I 100% stole the idea from him. He even suggested the paints to custom mix that color....That pink is is a "custom" air brush spray bomb. lol. Sorry, but no one runs pink and the color really pops for my old eyes So, I will keep it
TaGWolfgang likes this.
