    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree285Likes
Old 08-02-2016, 11:28 AM   #2236
avaldes's Avatar
Whether you obtain the correct steering throw electronically or mechanically, it makes very little difference. I agree with Wildcat.
avaldes is offline   Reply With Quote
Old 08-02-2016, 11:56 AM   #2237
Originally Posted by Wildcat1971 View Post
if the car drives straight and you have full left/right lock, I would just not worry too much.
Thanks very much. As I've returned to RC after a 20 year absence, I have found that nothing is the same and every mm counts! I was just worried that maybe the lengthening of the steering link may have some unknown adverse affect. I STILL haven't been able to get the B6D on the track yet... Hoping for Saturday!
Thanks again!
stevewolfie159 is offline   Reply With Quote
Old 08-02-2016, 12:48 PM   #2238
Phillip F's Avatar
Trader Rating: 15 (100%+)
Thanks again!
Welcome to the club. I'm in the same shoes. Club raced 5 times. ... It's like riding a bike. New Tech makes the hobby more enjoyable and convenient. Keep on racing!!!
Phillip F is online now   Reply With Quote
Old 08-02-2016, 12:53 PM   #2239
Thanks! I actually made it up to SCVRC with Gavri a few weeks back. Hope to make it up again soon.
Old 08-02-2016, 01:07 PM   #2240
the big rc's Avatar
Trader Rating: 39 (100%+)
Just talked to AE and was told the first batch of chassis weights went to fill back orders and the next shipment comes in mid August. Fail
the big rc is offline   Reply With Quote
Old 08-02-2016, 01:11 PM   #2241
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
Every new car from any manufacturer has parts supply issues at first. 95%+ of the B6 / B6D parts were available prior to release and most of these are still available today. Some issues always happen but I don't see this as a 'fail' on AE's part. Did you backorder them or did you expect to just order them up on day 1?
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 08-02-2016, 01:25 PM   #2242
Phillip F's Avatar
Race on a Sunday afternoon.. It's pretty laid back and not a lot of sand baggers in the sporstman class. LOL
Old 08-02-2016, 01:27 PM   #2243
I ordered my chassis weights on eBay just a few hours ago. No fail for me. I had a heads up, but still. Parts are out there.
Team Associated / Reedy / JConcepts / BoomRC
boucher is offline   Reply With Quote
Old 08-02-2016, 02:24 PM   #2244
Suspended
Trader Rating: 61 (100%+)
Lmao at the VRP plates. Good luck mounting your electronics to that milled surface.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 08-02-2016, 02:32 PM   #2245
"Smiley"'s Avatar
Trader Rating: 166 (98%+)
In case you have not noticed, the surface you are currently mounting your esc and receiver to are a milled surface. We have had zero issues, electronics stick great.
Vision Racing Products | Team Associated | AKA | Tekin | Sanwa | VP Powermaster Fuel | RC Concepts Engines | MIP | Avid | Boom RC Graphics | Paint By: "Smiley"
Vision Racing Products (VRP)- www.visionracingproducts.com
"Smiley" is offline   Reply With Quote
Old 08-02-2016, 02:37 PM   #2246
Suspended
No. It's flat and doesn't have any milling marks.
Old 08-02-2016, 02:44 PM   #2247
"Smiley"'s Avatar
You are incorrect. Look at the surface a bit closer and run your finger over it. It is indeed a milled surface. Ours is butter smooth compared to the stock chassis surface. Also, ours is machines in the usa, unlike the chassis. Look at the pic I have attached.
Old 08-02-2016, 02:48 PM   #2248
Suspended
So you're telling me this is a flatter surface:
Than this:
I'll have whatever you're having. It's some strong stuff.
Old 08-02-2016, 02:51 PM   #2249
davidfast's Avatar
Trader Rating: 22 (100%+)
You and milling
Thanks To:
Maclan Racing / JConcepts / Bubba's Bing / Xpert / R17 / Legit Lids / Bodies By Ed
davidfast is offline   Reply With Quote
Old 08-02-2016, 02:58 PM   #2250
Suspended
Originally Posted by davidfast View Post
You and milling
A machinist I'm not. I've never used a real CNC, I've been living in the dark ages with my old man's Bridgeport that was built in the 1930's. But damn does it run good, and I can turn out paper weights like Harry Carrey slams budwiser.
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
