    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree299Likes
Old 08-01-2016, 11:16 AM   #2176
Jmuck69's Avatar
Just found out that we may have a carpet track opening here soon....hmmmmm.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 08-01-2016, 11:17 AM   #2177
Where?
rcgerber is offline   Reply With Quote
Old 08-01-2016, 11:24 AM   #2178
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
nice. I still need to run on one sometime. closest one is about 3.5 hours away
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is online now   Reply With Quote
Old 08-01-2016, 11:25 AM   #2179
Suspended
Trader Rating: 61 (100%+)
Ran on carpet for the first time in my life on Saturday.
Amazing. I could see how it could get old, but this particular place did an excellent job with the track and layout. The great part was, you couldn't just "point and shoot" the track like I've seen on some layouts, you had to actually carry corner speed.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 08-01-2016, 11:26 AM   #2180
Suspended
You'll soon have one within an hour's drive.
Old 08-01-2016, 11:27 AM   #2181
I've heard of a carpet track opening about an hour from me. Time to get another car built I guess lol.
Team Associated / Reedy / JConcepts / BoomRC
boucher is offline   Reply With Quote
Old 08-01-2016, 11:44 AM   #2182
with in an hour? What city?
Old 08-01-2016, 11:48 AM   #2183
Originally Posted by Schuie Driver View Post
Anyone know the thickness of the J Concepts B6D chassis protector? Trying to decide between it and the thin Protek.
I wouldnt suggest the protek. they are a nightmare to pull off and leave a ton of sticky residue. I really like the j concepts.
walter white is offline   Reply With Quote
Old 08-01-2016, 12:01 PM   #2184
Trader Rating: 14 (100%+)
Really surprised SoCal doesn't have one yet.
"Go that way really fast, if something gets in your way, turn"
TLR 22 3.5 SR, TLR 22-4 1.875, Sanwa M12S, Savox, Hobbywing, Schuurspeed, Protek
DG Designs is offline   Reply With Quote
Old 08-01-2016, 12:14 PM   #2185
Thanks. Unfortunately, a day late and a dollar short in my case as I just ordered the Protek this morning
Schuie Driver is offline   Reply With Quote
Old 08-01-2016, 01:09 PM   #2186
Jmuck69's Avatar
Still like dirt but like the option and new experience. Hopefully it goes through.
B6D | B64D
Old 08-01-2016, 02:23 PM   #2187
Silverstonev8's Avatar
0.5mm thick
Silverstonev8 is offline   Reply With Quote
Old 08-01-2016, 02:27 PM   #2188
The assumption with a carpet offroad track is the option for carpet onroad as well. I could definitely get into that.
Old 08-01-2016, 02:31 PM   #2189
Suspended
Socal does have a carpet track. That's where I was on Saturday.
Old 08-01-2016, 02:51 PM   #2190
rvrslt1's Avatar
Trader Rating: 24 (100%+)
It does??? What city?
rvrslt1 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 10 (0 members and 10 guests)
