    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree308Likes
Old 07-30-2016, 09:31 PM   #2131
abailey21's Avatar
Trader Rating: 36 (100%+)
Went back to a 17.5, little rewire action and I may just race tomorrow
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 07-31-2016, 12:53 AM   #2132
Phillip F's Avatar
Trader Rating: 15 (100%+)
Which class were you racing last Sunday at SCVRC?
Phillip F is offline   Reply With Quote
Old 07-31-2016, 04:46 AM   #2133
Originally Posted by 30Tooth View Post
Please report back if you had success with the change in bulkhead shims.
Well moved the camber link back out (although not quite as far) and was good but still not much front and grip under power. Removed the 2x1mm washers under the front inner camber links and quite a bit of steering. Goes against all I've read but now you've explained what's happening I understand a little more.
Thanks, really appreciated.
Pistol123 is offline   Reply With Quote
Old 07-31-2016, 07:03 AM   #2134
Location: Beneath a rock down by the river. Don't have money for van
Glad to help. You will find that you can explore other adjustments a bit more and arrive at a different setup that suits you perfectly.
If all goes well, today or during the week will test a couple outside the box tricks.
*edit* Yep, too stiff front spring and too low RC height. One could also try increasing shims bellow the front hub.
( ͡ ͜ʖ ͡)
30Tooth is offline   Reply With Quote
Old 07-31-2016, 07:28 AM   #2135
abailey21's Avatar
I was there Saturday trying to shake the car down but I had an 8.5 in there.
It's just too much motor for that layout
K.C.C.O.
Old 07-31-2016, 07:29 AM   #2136
Phillip F's Avatar
Originally Posted by RCBuddha View Post
http://users.telenet.be/elvo/
look in "setup guide" for info on camber links/link length and what does what.
I have other links on the first page that make for a good reading.
Nice. Thank you.
Old 07-31-2016, 07:46 AM   #2137
RCBuddha's Avatar
Trader Rating: 35 (100%+)
Originally Posted by BIGSKI15 View Post
http://www.redrc.net/2016/07/schelle...ium-rear-hubs/
schelle updated the hubs to use with the kit inserts. I was thinking AE would update theirs too eventually.
Thanks for posting that!
I'll have a link on the front page once schelle update's their site.
RCBuddha is offline   Reply With Quote
Old 07-31-2016, 08:57 AM   #2138
Phillip F's Avatar
13.5T/10.5T would be the best motor to have their to clear that triple.
Old 07-31-2016, 09:29 AM   #2139
Originally Posted by QDRHRSE View Post
Anybody actually racing outdoors with the B6D? The car is awesome but the shock towers are not well suited for dirt. We've already broken a front and rear which is something that never happened once on the B5M. I hope they make plastic versions soon. So far that's my only gripe.
I think if the indoor clay tracks were big like an outdoor track and had some big air jumps you would see broken shock towers same there in a frustrating way. I just don't think the speed is there indoors for the most part.
Where you breaking them? I seen a picture before across the hole of the shock mount point on the ends.
Yokomo BD8 x 2 , BD7 2016, YRX-12, Tamiya TRF419, Associated B6, B6D, B5M Factory Lite, B64D, B44.3, RC8B3, RC8B3e
My Outdated R/C Car collection:
Associated B44, Associated NTC3, Tamiya TRF415, TRF415 MSX MRE, TRF416X
190mph is offline   Reply With Quote
Old 07-31-2016, 10:29 AM   #2140
Can anyone confirm or deny that the b5m puck system will fit b6d
Tlr 22 3.0 17.5 stock
Toro electronics
Orion batteries
Futaba 4pks
Lt hopkins is offline   Reply With Quote
Old 07-31-2016, 10:36 AM   #2141
Suspended
Trader Rating: 61 (100%+)
You know I'm racing outdoors!
Didn't yesterday though; ran at Ricochet raceway and LOVED it.
Outdoors the car is super stable. I haven't broke a tower, but then again, I don't make a habit of crashing
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 07-31-2016, 10:38 AM   #2142
Suspended
Originally Posted by suby723 View Post
So I just got done racing on a low/med bite track with my b6 laydown. I was the only one to even have a laydown car in the facility. I was very close on fastest lap times. I went to this race thinking my car was going to be undrivable and it completely exceeded my expectations. This laydown car can be successful on a low bite surface with the correct setup.
And the 25G laydown C just came out, as well.
Old 07-31-2016, 10:39 AM   #2143
Suspended
I can confirm.
Old 07-31-2016, 10:42 AM   #2144
Originally Posted by Socket View Post
I can confirm.
Sweet so safe ordering a b5m puck system thanks ordering now
Toro electronics
Orion batteries
Futaba 4pks
Old 07-31-2016, 10:44 AM   #2145
Anything special I need to do someone said it needed to be shimmed
Toro electronics
Orion batteries
Futaba 4pks
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
cbazq271, Rebuke
