    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree287Likes
Old 05-02-2016, 08:45 AM   #196
Johnn27's Avatar
Trader Rating: 69 (100%+)
Questions?? Lay Down
I just keep thinking why not a dirt car with a lay down trans
Johnn27 is offline   Reply With Quote
Old 05-02-2016, 09:07 AM   #197
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
Originally Posted by Johnn27 View Post
I just keep thing why not a dirt car with a lay down trans
Because they (the team / engineers at AE) figured out that a dirt car with a laydown does not compete on carpet compared to what else is out there. Watch some of the videos from AE and from EOS on redrc.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 05-02-2016, 09:17 AM   #198
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
What exactly are you asking? Are you asking why where are 2 cars?
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 05-02-2016, 10:10 AM   #199
EricW's Avatar
Because on lower bite tracks you want the weight more to the rear of the car? The lay down trans moves the motor forward.
Stickas are for straight up suckas......
**** "Luxury" ****
EricW is offline   Reply With Quote
Old 05-02-2016, 11:35 AM   #200
I spoke Brent and Cody at the EOS and the idea behind the car is good. Only downside it's a whole new platform with only a couple parts that are compatible with the B5(M). Car looked good in the finals. Brent told me they are aiming for a release in June, so it should be good. Curious about the final production car, I won't run it, but will check it out for sure.
株式会社 ヨコモ
dennisV is offline   Reply With Quote
Old 05-02-2016, 11:44 AM   #201
VegasHB's Avatar
Originally Posted by Wildcat1971 View Post
The main thing I dislike about the new car is the CF towers. I personally have sanding and sealing cf. And they still break and cost a ton to replace. I thought the composite front towers were fine. That being said, AE is offering a lot of car for $309.
Turf and carpet tracks almost require the carbon towers. Since the local track went carpet here, shock towers on everyone's cars were snapping. There's no give once you flip and catch a tower on the carpet.
It won't be long before we see carpet and turf designed cars shrinking towers down to TC onroad heights or cantilever setups.
Don't worry about saving pennies, worry about making dollars.
702rcraceway.com, sponsored by my wallet
VegasHB is offline   Reply With Quote
Old 05-02-2016, 11:50 AM   #202
I have seen cf towers break also. I personally would have preferred composite for racing on clay. Unsure how much carpet will take over here in the US. We have a new track coming soon and the last i heard is it will be dirt. I kind of wish it was a carpet track like the 702. I think bringing in the onroad guys will only increase business. That being said, I have no idea long term if the offroad guys will destroy the carpet for the onroad guys.
Old 05-02-2016, 11:56 AM   #203
thecman26's Avatar
Trader Rating: 98 (100%+)
**** Also, why is there still no OEM fan mount, lol. Surely there must be enough 17.5 drivers to design one.
For like $9.99 (Trinity fan mount) plus a fan and you have a fan mount! Not a deal breaker for most as people just gear so the motor doesn't get too hot. But for the few that don't, there ya go.
http://www.amainhobbies.com/rc-cars-...ep3057/p469847
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 05-02-2016, 02:28 PM   #204
Flip boy's Avatar
Originally Posted by mgers75 View Post
Pre ordered the B6D. Looks like the geometry stays very close to the B5m so I doubt it handles much differently or will be markably faster. Looks like a good well refined buggy. Hopefully the kit comes with ti-nitrade shock shafts and ti turnbuckles like the marketing pics. Also like that it comes with more Aluminum and good bearings. Justifies the extra $30.
AE managed to address some of the weak points of the b5 i.e. the front spindle inserts. Im going to get the parts to run the laydown tranny just to see how it works on dirt. I race on medium grip indoor so it may not work but I like tinkering.
No titanium nitride shafts or v2 shafts or xrings
Flip boy is offline   Reply With Quote
Old 05-02-2016, 02:50 PM   #205
ajj
ajj's Avatar
Trader Rating: 18 (100%+)
From the product release info:
"V2 12mm "Big Bore" threaded aluminum shocks with 3mm TiN coated shafts and low friction x-rings for improved smoothness"
ajj is offline   Reply With Quote
Old 05-02-2016, 02:52 PM   #206
Super Moderator
Yes, it comes with this. The previous post was in reference to that being a deal breaker if it wasn't included...hence the tears, lol
Old 05-02-2016, 03:21 PM   #207
Flip boy's Avatar
Old 05-02-2016, 03:35 PM   #208
Well look who's coming around
jslider is offline   Reply With Quote
Old 05-02-2016, 04:17 PM   #209
ANDRXW's Avatar
Upon closer look at Cav's setup, they appear almost of a ti-material but maybe it's just me; I understood that the tuning weight plates were made of steel?
/ / ANDRXW.com
ANDRXW is offline   Reply With Quote
Old 05-02-2016, 04:39 PM   #210
Jmuck69's Avatar
I think they're steel, just polished. If they were Ti, they would note it in the specs. If they are Ti, then score!
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
