    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree287Likes
Old 07-29-2016, 09:12 AM   #2071
Phillip F's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Wildcat1971 View Post
gun the throttle less and smooth it out.. maybe a softer tire when it dries out.
would adding weight at the back tames it down? Like replacing the aluminum C mount with a 20g. brass C mount?
Phillip F is offline   Reply With Quote
Old 07-29-2016, 09:13 AM   #2072
Phillip F's Avatar
Originally Posted by Matt Trimmings View Post
Maybe a track with more consistency?
I wish,
Old 07-29-2016, 09:15 AM   #2073
Phillip F's Avatar
Originally Posted by boucher View Post
B6 built to kit? Maybe try swapping the shocks to the back of the arm to calm down rotation.
It's already set at the back. Running stock pistons . 30wt . Yokomo Green rear springs.
Old 07-29-2016, 09:19 AM   #2074
Phillip F's Avatar
No word yet on the motor fan mount for the B6?
Old 07-29-2016, 09:20 AM   #2075
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
if the car is good before the track dries out, it might just require a tire change. Now if you want to strap on brass go for it. My local track typically has good traction, but it can dry out and the cars handling changes. I find it best to change the tire or change your driving. I mostly change my driving. Alter how I enter/exit corners etc. I dont run on your surface, so hard to really say. I suggest talking to the local sponsored AE drivers.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is online now   Reply With Quote
Old 07-29-2016, 09:22 AM   #2076
Suspended
Trader Rating: 61 (100%+)
Okay. I ran my B6 tonight at the track and when the track dries out a bit. The rear just breaks loose and loses traction when I gun the buggy exiting a corner. What should I do?
What track?
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 07-29-2016, 09:28 AM   #2077
Here's a cheap solution I found on fb that won't rely solely on double sided tape..
Use a longer screw on the "driver's side" of the C block, couple ball stud washers, a servo mount, and a nut.
Team Associated / Reedy / JConcepts / BoomRC
boucher is offline   Reply With Quote
Old 07-29-2016, 09:52 AM   #2078
RC*PHREAK's Avatar
Trader Rating: 119 (100%+)
it could make it worse by exaggerating the pendulum effect. if you're juicing it coming out of a corner and the buggy isn't straight yet and it's sliding out, adding more weight to the back will make it swing more.
RC*PHREAK is offline   Reply With Quote
Old 07-29-2016, 10:27 AM   #2079
To you guys running fans taped to the chassis behind the motor: is there room for a 30mm fan or are you using 25mm? I have a B6D and laydown conversion back ordered from Tower and just wondering what size fan I need. I have a 30mm in the mail.
Gearhead82 is offline   Reply With Quote
Old 07-29-2016, 10:27 AM   #2080
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
You will be fine with the 30mm fan.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 07-29-2016, 10:36 AM   #2081
This exact same thing happened last night at LRH. At one point, they didn't water for maybe 1.5 hours and it just dried out. Coming out of turns on throttle the car would just spin out. I had to adjust my driving. Once the watered it was great.
40yoCaliRacer is offline   Reply With Quote
Old 07-29-2016, 10:36 AM   #2082
Trader Rating: 14 (100%+)
I had to cut the body to get The R1 fan to fit.
"Go that way really fast, if something gets in your way, turn"
TLR 22 3.5 SR, TLR 22-4 1.875, Sanwa M12S, Savox, Hobbywing, Schuurspeed, Protek
DG Designs is offline   Reply With Quote
Old 07-29-2016, 11:47 AM   #2083
Phillip F's Avatar
Sweet. Thanks.
Old 07-29-2016, 12:46 PM   #2084
Just called my LHS and lo and behold they had a B6D kit in stock so I guess after work I'll be picking up a new car
Schuie Driver is offline   Reply With Quote
Old 07-29-2016, 01:35 PM   #2085
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Are you starting to race again? Did you quit flying Heli's.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Currently Active Users Viewing This Thread: 4 (2 members and 2 guests)
Dirtraycer, Sal Amato
