    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree285Likes
Old 07-28-2016, 05:13 PM   #2041
rvrslt1's Avatar
Trader Rating: 24 (100%+)
Originally Posted by Socket View Post
Who's battery hold down are you useing?
rvrslt1 is offline   Reply With Quote
Old 07-28-2016, 05:25 PM   #2042
Suspended
Trader Rating: 61 (100%+)
Schelle.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 07-28-2016, 06:19 PM   #2043
Is the wire for the transponder pinched under the servo to the weighted plate
Team Associated, JConcepts, M2C Racing, Big Pimpin Paints
Chris Reilly is offline   Reply With Quote
Old 07-28-2016, 06:51 PM   #2044
Suspended
Servo is slightly shimmed up to clear the wire.
Old 07-28-2016, 07:14 PM   #2045
RCBuddha's Avatar
Trader Rating: 33 (100%+)
http://www.redrc.net/2016/07/jconcep...ont-axle-sets/
RCBuddha is offline   Reply With Quote
Old 07-28-2016, 07:23 PM   #2046
BIGSKI15's Avatar
Trader Rating: 18 (100%+)
Has anyone referenced this spring chart from petitrc? I've found 3 kyosho charts and all three differ from one another in regards to spring rates and the color spring that it is.
http://site.petitrc.com/reglages/BuggyBigBoreSpring.pdf
Or does someone have a link to an accurate kyosho spring chart?
B6D
B5M
Airtronics M12
BIGSKI15 is offline   Reply With Quote
Old 07-28-2016, 07:55 PM   #2047
rvrslt1's Avatar
Schelle.
Looks nice. Will have to order one
Old 07-28-2016, 08:07 PM   #2048
Socket what tires for carpet you have on the car in the picture a page back?
Yokomo BD8 x 2 , BD7 2016, YRX-12, Tamiya TRF419, Associated B6, B6D, B5M Factory Lite, B64D, B44.3, RC8B3, RC8B3e
My Outdated R/C Car collection:
Associated B44, Associated NTC3, Tamiya TRF415, TRF415 MSX MRE, TRF416X
190mph is offline   Reply With Quote
Old 07-28-2016, 08:24 PM   #2049
Suspended
Schumacher yellow premounts. Mini pin rears with stagger fronts.
I heard about the nightmare of gluing carpet tires so I went with these.
Old 07-28-2016, 09:11 PM   #2050
awidz's Avatar
You want the best carpet tires out checkout gone bananas racing skinz on facebook. Love them and last forever, I ran 4 months on 1 set. Best tires available for indoor.
awidz is offline   Reply With Quote
Old 07-29-2016, 01:33 AM   #2051
Phillip F's Avatar
Trader Rating: 15 (100%+)
Okay. I ran my B6 tonight at the track and when the track dries out a bit. The rear just breaks loose and loses traction when I gun the buggy exiting a corner. What should I do?
Phillip F is online now   Reply With Quote
Old 07-29-2016, 02:48 AM   #2052
Pinkz's Avatar
not all carpet tracks are ozite, many places don't allow foam tires. on some carpets/turfs the spikes are the way to go
It rubs the lotion on its skin or else it gets the hose again.....Yes, it will, Precious, won't it? It will get the hose! https://www.youtube.com/watch?v=cyn0DVSn96I
Pinkz is offline   Reply With Quote
Old 07-29-2016, 04:42 AM   #2053
celt's Avatar
Foam is no bueno on turf, they don't work.
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is offline   Reply With Quote
Old 07-29-2016, 04:44 AM   #2054
I've tried the Schumacher mini pins rear and stagggered rib fronts on my T5M. I found the fronts a little too bitey. Is that a word? It is now ;P I actually switched to AKA Chainlinks for the front.
For the B6 I'm going to try the new Jconcepts Pindowns in rear and Swaggers on the front. I saw JR Mitch testing them at the Extreme Carpet Initative a few months ago. He, Blake Boggs, and a couple of the fast guys were running them as prototypes. They look good, we'll see how they fare. I hope for some long life out of them.
BruceR. is offline   Reply With Quote
Old 07-29-2016, 04:53 AM   #2055
Hey all. After a 10 year plus layoff from RC racing, I've got the bug again and this car certainly has my attention. I'm curious, for 1/10th scale stock buggy racing, what's the general opinion as to how much capacity you need in a 2S pack? Would something in the 4000mah to 4500mah range be too small? Also what specs should I be looking for in steering servos for 10th scale buggy? Thanks for any advice you can provide.
Schuie Driver is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
frdtrkguy
