    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree287Likes
Old 07-24-2016, 04:22 AM   #1906
Just finished building my B6. Has anyone gone from box to high grip carpet to test out the stock setup? Any observations?
Only upgrade I've done so far is the front bronze bulkhead and a PL Trifecta wing. Waiting on the body to be finished. Planning on doing aluminum steering links and servo horn, rear aluminum D mount, the steel plate under the electronics, sway bars if I find that I need them and aluminum wing buttons.
Running a Track Star 8.5 setup, Savox 1258TG, SMC 60C 4400mah Shorty, Airtronics MX-V radio. Front tires are low profile PL Wedges, cut rim, no insert and rear are PL Pin Points stock insert.
nttdemented is offline   Reply With Quote
Old 07-24-2016, 06:52 AM   #1907
team green's Avatar
My Ti screws and turnbuckles finally came in. So I was able to complete my build.
I will never go back to brushed motors or NIMH's!!!!
Awesomatix EVO2
Tamiya TA07 Pro
Associated B6
TLR 22-4 2.0
team green is online now   Reply With Quote
Old 07-24-2016, 06:58 AM   #1908
Looks really nice. I'm new to this c,d mount & pill toe in system. Is 5 degree max toe and 1 degree min toe using pills in c and d mount? Thanks
Wassmer is offline   Reply With Quote
Old 07-24-2016, 07:54 AM   #1909
Trader Rating: 14 (100%+)
The latest setups seem to have mored toward narrower inner pivots.(if i my decoder ring is working correct) This would help calm down the rear end a bit correct? I am running the laydown on a mid bite track. My skill level probably should have me using the standup but the corner exit speed makes it really hard to do. Most of the issues i was having was with fresh tires but it was a handful
"Go that way really fast, if something gets in your way, turn"
TLR 22 3.5 SR, TLR 22-4 1.875, Sanwa M12S, Savox, Hobbywing, Schuurspeed, Protek
DG Designs is offline   Reply With Quote
Old 07-24-2016, 07:57 AM   #1910
Finished and ready to roll!
Designed all stickers myself so I wont mix up another color into the design scheme
Official Team Associated B6 & B6D thread-b6d-2.jpg   Official Team Associated B6 & B6D thread-b6d-1.jpg
man1ac is offline   Reply With Quote
Old 07-24-2016, 08:14 AM   #1911
Cool Man1ac
I think your (man1ac) chassis cover is super cool !!
flbugboy is offline   Reply With Quote
Old 07-24-2016, 08:22 AM   #1912
Old 07-24-2016, 08:30 AM   #1913
Originally Posted by the big rc View Post
Not a bad start with the B6. We had a reedy format race today. 6 heads up races all random order 3 wins 3 seconds. First race with it and it's amazing. I used Cavs setup, such a balanced car
So you have the B6 and not B6D? What track surface type and traction level you were racing on? What tires and inserts you running? Thanks in advance.
Yokomo BD8 x 2 , BD7 2016, YRX-12, Tamiya TRF419, Associated B6, B6D, B5M Factory Lite, B64D, B44.3, RC8B3, RC8B3e
My Outdated R/C Car collection:
Associated B44, Associated NTC3, Tamiya TRF415, TRF415 MSX MRE, TRF416X
190mph is offline   Reply With Quote
Old 07-24-2016, 09:12 AM   #1914
Literally built one that looks similar to this last week on my Dreamer. I also have one for the laydown and one the outs the fan down on the chassis. Good work. Cool seeing other people's 3D printed stuff
Originally Posted by Socket View Post
Jade67 is offline   Reply With Quote
Old 07-24-2016, 09:12 AM   #1915
elex300's Avatar
Trader Rating: 102 (100%+)
Cleaned up my wiring today.
elex300 is offline   Reply With Quote
Old 07-24-2016, 09:35 AM   #1916
DRJVogel's Avatar
elex300, that is one sweet wring clean up! Talk about perfection!
near Grass Valley, CA --- let's bash
DRJVogel is offline   Reply With Quote
Old 07-24-2016, 09:39 AM   #1917
Originally Posted by belewis01 View Post
Might have to change it. With a Savox servo, I swapped the 1mm to a 2mm to center the rack.
Bruce
Strange, my Savox has the same issue.
Old 07-24-2016, 09:57 AM   #1918
celt's Avatar
Very nice...
A welcomed change on the new platform is just how much room there is for electronics, even when running the laydown gearbox. Pretty much any modern servo, ESC or receiver can be made to fit easily.
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is offline   Reply With Quote
Old 07-24-2016, 11:33 AM   #1919
Originally Posted by celt View Post
Very nice...
I really liked that I was able to fit my huge receiver in there and not need to upgrade to a radio that uses smaller receivers. Between the servo/esc wiring, on/off switch and esc cap I used up pretty much all the space and only have a small nook to fit the transponder when I rent one at the track.
Old 07-24-2016, 05:16 PM   #1920
Is anyone running a D with a laydown on medium grip clay? Wondering if it's worth a try or just go with standard trany.
Sean B. is offline   Reply With Quote
Currently Active Users Viewing This Thread: 7 (0 members and 7 guests)
