    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree303Likes
Old 07-23-2016, 01:10 PM   #1891
RCBuddha's Avatar
Trader Rating: 35 (100%+)
Looks good socket. Any shots with fan mounted under a clear body?
RCBuddha is offline   Reply With Quote
Old 07-23-2016, 01:10 PM   #1892
Suspended
Trader Rating: 61 (100%+)
I'll get some "pro" shots next week for ya
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 07-23-2016, 02:20 PM   #1893
Phillip F's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Socket View Post
where did you get that?
Phillip F is offline   Reply With Quote
Old 07-23-2016, 02:53 PM   #1894
Suspended
Prototype right now. I should have "mine" next week for testing and it should be out from there.
Old 07-23-2016, 02:54 PM   #1895
AZJP's Avatar
Trader Rating: 20 (100%+)
Why not behind the motor on the chassis with tape?
AZJP is offline   Reply With Quote
Old 07-23-2016, 03:00 PM   #1896
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
There isn't enough room for a fan back there with the standup trans. Laydown you are good though.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 07-23-2016, 03:47 PM   #1897
AZJP's Avatar
See it now.
Old 07-23-2016, 05:09 PM   #1898
Phillip F's Avatar
I have the laydown. Hopefully Socket is going to make one for the laydown tranny too.... matte black would be nice too.
Old 07-23-2016, 05:26 PM   #1899
Super Moderator
There is plenty of room to mount a fan on the laydown.
Old 07-23-2016, 08:15 PM   #1900
RC*PHREAK's Avatar
Trader Rating: 119 (100%+)
i will be running a laydown when i can get my hands on one and i would buy a waterfall fan mount in a heartbeat.
RC*PHREAK is offline   Reply With Quote
Old 07-23-2016, 08:30 PM   #1901
BLKXJ96's Avatar
Originally Posted by Chris Brown View Post
Has anyone had any issues with the steering system? I have the aluminium steering rack and set up up per the manual with a ko low profile servo. With the servo horn at the 90 Mark, the rack is off center to the left. I took it apart and rebuilt it bit no dice. Any ideas?
do you have the correct spacer in the rod end linkage between the servo and the rack.
Jeff
RC10 Team Car, Gold Pan, RC10 B5m B5mCE, Sc5m, Rc8B3e, B6
BLKXJ96 is offline   Reply With Quote
Old 07-23-2016, 09:06 PM   #1902
Trader Rating: 18 (100%+)
The 1mm spacer? Yeah.
Chris Brown is offline   Reply With Quote
Old 07-23-2016, 09:45 PM   #1903
Might have to change it. With a Savox servo, I swapped the 1mm to a 2mm to center the rack.
Bruce
belewis01 is offline   Reply With Quote
Old 07-23-2016, 10:34 PM   #1904
the big rc's Avatar
Trader Rating: 39 (100%+)
Not a bad start with the B6. We had a reedy format race today. 6 heads up races all random order 3 wins 3 seconds. First race with it and it's amazing. I used Cavs setup, such a balanced car
the big rc is offline   Reply With Quote
Old 07-23-2016, 10:49 PM   #1905
Bruce
Ok thanks. Seems weird but I'll play with it.
Currently Active Users Viewing This Thread: 7 (0 members and 7 guests)
