    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree287Likes
Old 07-21-2016, 05:44 PM   #1831
slakr's Avatar
Trader Rating: 28 (100%+)
This is very odd, and now I have to ask a question, but first... I am missing at least one part from my kit. THE CHASSIS!
So now my question... do the bags jump and skip around?
I have bags 1, 2, 3, 5, 6, B8, 9, 11, 12, B14, 15, 17, 18, B19, 20, B22, 23, 24, "additional hardware, "tools", thrust and diff greases, body & wing, sticker kit, directions, VRC gift certificate...
This is a first for me... I have put a lot of kits together, from most all the different brands, and from time to time there is a missing part. Nobody is immune... but the chassis???
TLR 22 4.0, 22-4 2.0, 8IGHT & 8IGHT-E 4.0~XRAY XB2C~AE TC7.1
Tim aka "slakr" ROAR No. 3-119960
slakr is offline   Reply With Quote
Old 07-21-2016, 05:51 PM   #1832
goehm's Avatar
Trader Rating: 44 (100%+)
My chassis bag came with other bags in it - 3-4 or so. That might explain why you're missing some bags as well.
--GO!
Come visit G's RC Raceway / Shippensburg, PA / www.GSRC.us
goehm is offline   Reply With Quote
Old 07-21-2016, 05:55 PM   #1833
slakr's Avatar
Thanks goehm... guess I need to call AE tomorrow.
Old 07-21-2016, 06:00 PM   #1834
Phillip F's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Wildcat1971 View Post
I put washers on the button head. to spread the load
Where do you get those?
Phillip F is online now   Reply With Quote
Old 07-21-2016, 07:50 PM   #1835
RCBuddha's Avatar
Trader Rating: 33 (100%+)
Originally Posted by Socket View Post
Buddha, I edited the wiki, take that and just plug it into page 1 please!
done
RCBuddha is offline   Reply With Quote
Old 07-21-2016, 07:55 PM   #1836
RCBuddha's Avatar
http://www.redrc.net/2016/07/x-facto...r-gear-shafts/
http://www.redrc.net/2016/07/schelle...battery-strap/
Old 07-21-2016, 08:54 PM   #1837
abailey21's Avatar
Trader Rating: 36 (100%+)
For those of you running the Brass C mount in the rear and looking for just a bit more weight. I'm using a bellcrank weight from Centro that with minimal shaving under the lay down trans...
Ends up putting just about 30g in the perfect spot
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 07-21-2016, 09:12 PM   #1838
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
A friend gave me a pile of them a while back. These are the same size from AE. https://www.amainhobbies.com/team-as...sc89218/p16809
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 07-21-2016, 09:14 PM   #1839
Originally Posted by goehm View Post
You added nothing. Please, then, explain the effect of changing the static weight distributions.
Few care what it IS (which is what you provided), most care what it DOES (which is what I was trying to explain).
Edit: What I'm getting at is while it is changing the weight distribution, it isn't weight between the wheelbases which is pretty straight forward. That is simple static weight distribution. In this case one of the configurations has weight being put BEHIND the axle.
In terms of static weight distribution it doesn't matter where and how masses are moved around in the car, it's the final corner weight figures that count. It does increase polar moment of inertia moving the shocks back though. So in proportion to the static weight distribution, 'weight transfer' (as you refer to it) under acceleration is likely reduced, at least transiently.
AntH3000 is offline   Reply With Quote
Old 07-21-2016, 09:36 PM   #1840
Phillip F's Avatar
English please.
Old 07-21-2016, 09:39 PM   #1841
DRJVogel's Avatar
Indubitably.
near Grass Valley, CA --- let's bash
DRJVogel is offline   Reply With Quote
Old 07-21-2016, 10:38 PM   #1842
SuperRC's Avatar
Does AE have a metric screw kit that has various different size screws,not car specific? i.e just a spare screw kit to replace any stripped screws and can just be used randomly. Saves buying a pack with a bunch of same size screws.
(Not Ti or steel, just standard kit screws)
SS
SuperRC is offline   Reply With Quote
Old 07-21-2016, 10:50 PM   #1843
Suspended
Trader Rating: 61 (100%+)
Schelle battery strap is in stock.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 07-21-2016, 10:57 PM   #1844
English please.
Fo shizzle my nizzle; Car-ey goey forwardy bettery. Turny round cornery a bit slowery. If mounted on backy.
Safe
Old 07-21-2016, 11:06 PM   #1845
Phillip F's Avatar
Safe
thanks for explaining, Einstein. That's a really nice way of explaining to people who don't have english as their first language. It's almost racist.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Carpetbombing
