    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree310Likes
Old 07-20-2016, 12:33 PM   #1786
jmcelroy42's Avatar
Originally Posted by aeRayls View Post
The B6D manual says to put the hub in the 0 position (all the way down) which is 0 insert "up". It's also the standard B5 height.
The manual shows 0 but the setup sheet in the back of the manual shows +1, there is a couple other discrepancies between the setup sheet and the step by step part of the manual
EB48.4 - TEKIN RX8 & SMC 2100
XB4 '16 - TEKIN RSX & ORCA 5.5
RC10B6 - HW Justock & 24K 17.5
jmcelroy42 is offline   Reply With Quote
Old 07-20-2016, 12:45 PM   #1787
aeRayls's Avatar
Regardless of what the manual tells you to build or the setup sheet. It's just an adjustment for tuning to different track conditions. If you're running the Standup or laydown on medium to high grip. Start with +1, that's been a great feeling so far.
Ive tried all 4 positons on my home track which was medium to low grip indoor clay very dry and dusty, using the standup gearbox. +1 turned a single faster lap, the 0 position felt the best and was only 1-2 tenths off on fast lap.
I also ran at the JC summer indoor nats using the laydown and +1 was by far the best. +2 just felt sketchy and too free.
Also remember, each time you raise the hub add .5mm rear droop to the rear shocks to keep the static shock feel the same.
aeRayls is offline   Reply With Quote
Old 07-20-2016, 12:54 PM   #1788
Suspended
Trader Rating: 61 (100%+)
Who doesn't like weights?
HAHA
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 07-20-2016, 12:58 PM   #1789
Super Moderator
racer1812's Avatar
Trader Rating: 30 (100%+)
Originally Posted by Socket View Post
Much nicer wiring job compared to your last mess..
Stand for the flag, kneel for the fallen.
Thank you to all of our service men and women!
racer1812 is offline   Reply With Quote
Old 07-20-2016, 01:44 PM   #1790
Suspended
You know me!
Old 07-20-2016, 01:48 PM   #1791
Phillip F's Avatar
Trader Rating: 15 (100%+)
Default B6 kit build
Anybody having problems with missing parts on their B6 kits? I am in the process of building one right now and I have parts missing.... Hopefully they are tucked in one of the plastic bags in the kit.
The gear diff was a pain to build too. I ended up not using the outdrive shims because when I close the transmission case.. it binds and the whole assembly would not turn.
Phillip F is offline   Reply With Quote
Old 07-20-2016, 01:49 PM   #1792
Phillip F's Avatar
How did you mount that fan on that waterfall or whatever they call it?
Old 07-20-2016, 01:51 PM   #1793
Super Moderator
racer1812's Avatar
You know me!
Ya, you're a slow learner...lol
Old 07-20-2016, 01:57 PM   #1794
Suspended
hahaha, that you deleting my posts?
Old 07-20-2016, 02:02 PM   #1795
Super Moderator
racer1812's Avatar
Nope. Are you making posts/threads that break the rules
Fyi,this isn't the place to discuss it
Old 07-20-2016, 02:28 PM   #1796
Suspended
Old 07-20-2016, 02:54 PM   #1797
suby723's Avatar
Trader Rating: 21 (100%+)
Ok now you have just gone off the deep end! Lmao looks good!
suby723 is offline   Reply With Quote
Old 07-21-2016, 12:05 AM   #1798
egalsim's Avatar
Trader Rating: 39 (100%+)
Almost done, just need the esc and servo. Running Kyosho Velvet shocks on this.
Associated RC10B6 / Kyosho Optima / Associated Tekno SC8e / Awesomatix A700exl / Serpent Cobra BE 2.1 Rally / Kyosho MP9 Tki3.5 Tekno V4 / Xray Xb4 2017 / Serpent SDX4
egalsim is offline   Reply With Quote
Old 07-21-2016, 03:28 AM   #1799
That's such an awesome B6, dude! I love the retro style.
www.apexattitude.blogspot.com.au
Silberpfeil is offline   Reply With Quote
Old 07-21-2016, 06:16 AM   #1800
Mason's Avatar
nice job!
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
