    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree287Likes
Old 07-19-2016, 10:20 AM   #1726
aeRayls's Avatar
Originally Posted by rvrslt1 View Post
Thanks for the info and will move them to the back. I do already have the 12g brass mount and I used the AE front bulk head.
Make sure you use the long shock eyelets when putting the shocks on the rear and short on the front.
Which front bulkhead are you referring to?
aeRayls is offline   Reply With Quote
Old 07-19-2016, 10:30 AM   #1727
rvrslt1's Avatar
Trader Rating: 24 (100%+)
I did use short in front with 35wt and long in the rear with 30wt. Used the box springs white and green. It's the blue AE bulk head.
rvrslt1 is offline   Reply With Quote
Old 07-19-2016, 10:39 AM   #1728
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
When mounting the shocks in front of the rear arms you are supposed to use the short eyelets. In the front, short eyelets are to be used in holes A & B, long eyelets when using hole C of the F arms.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 07-19-2016, 10:58 AM   #1729
In my eyes there is no comparison. I can't think of one thing the b5m did better than the b6, seriously.
The b5r? Not even close. I've raced on some of the lowest grip dirt there is. Rear motor is a thing of the past. If you're not going faster with a mid car in those conditions you're not tuning correctly.
The thing that surprised me most is how good the b6 is right out of the box!
The questions is, does it anything worse than the B6D (especially on low bite clay/loose dirt).
Nevertheless, I will start my B6D build in Friday morning, will set it up with Brass C, 15g under the batterie, shocks front/rear: 1.6/35/green and 1.6/30/green, 3,5 toe in at rear.
Hopefully that wil do (for the B5m it really does )
man1ac is offline   Reply With Quote
Old 07-19-2016, 11:06 AM   #1730
Trader Rating: 48 (100%+)
I drive on a similar traction level. Running FrONT 32 1.6 Rear 30 1.7
Thanks to my sponsors:
My Credit Card
Speedychris22 is online now   Reply With Quote
Old 07-19-2016, 12:26 PM   #1731
Mason's Avatar
Originally Posted by Socket View Post
I have. Yes. It's why you see the pro's ESC's on the far right side of the front, to help offset the motor weight.
so the "optimized centered" motor mount/tranny is coming out next month? Starting to sound like xray or gasp, even Losi.
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 07-19-2016, 12:32 PM   #1732
Suspended
Trader Rating: 61 (100%+)
Who said that?
Losi has a motor centering kit?
Xray does?
Cite please.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 07-19-2016, 12:36 PM   #1733
Suspended
Originally Posted by Wildcat1971 View Post
what are your corner weight numbers?
There are some things I don't share, and that's one of them.
Old 07-19-2016, 12:44 PM   #1734
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
lol, I am pretty sure you just make up crap and follow what others are doing
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 07-19-2016, 01:00 PM   #1735
aeRayls's Avatar
I went with 1.6 30 and 1.7 27.5 this last weekend on a low bite wet loamy track. It was great! Remember, this car is lighter than the b5m lite! I also used the most narrow rear pivot. Using the alum D block I took the centered 1 inserts and turned them all inwards. I didn't yet have my brass c mount or 4gear and the car was great!
Old 07-19-2016, 01:16 PM   #1736
Pittster's Avatar
Great looking paint. Where'd you get the front tower protector?
Thanks a good mate does my paint jobs.
I made the front wing from the off cuts of old rear wings. That one is made from a b44 wing I have made around ten of them. It's only to protect the carbon tower from snapping
Team Associated B6D, Speed Passion Reventon Pro 1.0, Hobbywing V10 7.5t
Team Associated B64D, Speed Passion Reventon Pro 1.1, Hobbywing V10 G2 6.5t
Team Associated B5M CE, Tekin Rs Gen2, Fleta ZX 17.5t
Pittster is offline   Reply With Quote
Old 07-19-2016, 01:17 PM   #1737
Suspended
Yep. All those people I followed when I spent several months developing the XRAY...
Oh wait, there was no one to copy.
Old 07-19-2016, 01:18 PM   #1738
Suspended
I got some new outdrives today to go with my B6 and B6D cut gears.
You know, copying others...Oh wait, no one else in the country has B6/B6D cut gears...or these outdrives
Old 07-19-2016, 01:19 PM   #1739
awidz's Avatar
Because total car weight is more important.
That said, I believe they used both steel plates.
Yeah but what does weight do? Depending where u put it? And there are 2 kits of steel and brass weights
awidz is offline   Reply With Quote
Old 07-19-2016, 01:22 PM   #1740
OriginalDonk's Avatar
Trader Rating: 38 (100%+)
You continue to use the word "developing." While I do recognize that you helped identify that you could cobble together pucks, the word "development" is typically reserved for those designing and producing something. Perhaps tuning is a better word moving forward?
OriginalDonk is online now   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
