    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree287Likes
Old 07-17-2016, 02:19 AM   #1636
Carpet tyre question above, yes to the schumachers.
Rears: Minipin 2 yellow compound with a tubby insert
Fronts: cut stagger low profile, yellow, no insert.
Minipin 1 has slightly less grip, as does as stagger rib, in comparison to those above, should you need to lose dorm grip at one end.
andrewcoley is offline   Reply With Quote
Old 07-17-2016, 04:13 AM   #1637
celt's Avatar
Default B6 carpet / ozite
The B6 is sick on carpet. The only change I've made from the kit setup is shorten the rear camber link from the inner most hole to the center hole.
Need to free up the car a bit, so much rear grip it's stupid. The odd thing is, I suspect our gray ozite doesn't have the traction that the new black CRC stuff does, but I need more steering at any rate. Running schuey yellow mini pins rear and yellow cut stagger slim low-profile front. You're mother could drive this thing. Rear end won't step out for nothing.
Any carpet/astro guys with ideas? Need a pinch more front bite. Is there a front tire with more bite than the one listed above? Considering trying the same stagger in silver compound.
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is offline   Reply With Quote
Old 07-17-2016, 04:59 AM   #1638
hollywood3705's Avatar
Without knowing anything about what you are doing with option parts and setup....generally look at setup sheets from eos races. The cars all sport a front wing and brass pieces in the front. You are trying to make a car with a rear weight bias have steering. To do this you need to shift that bias towards the front. Both static and once the car is moving. A brass front bulkhead would be a good start. That kind of weight would help dig the front end going in to a corner and allow less transfer to the rear when exiting. Go to petit rc setups and have a look at the carpet section for the b6. Great place to start gathering the basic of ideas. Neil Craigg always has a balanced easy to drive car. Never a bad starting point for reference
Amain.com / Protek / VRP / The Ohio R/C Factory / The Bearded Wonder
hollywood3705 is offline   Reply With Quote
Old 07-17-2016, 08:53 AM   #1639
suby723's Avatar
Trader Rating: 21 (100%+)
Hard to do without the front and rear swaybars and chassis weights but Ryan cavs eos setup is what I'll be going with for a base setup.
http://www.reedyrace.com/ae/spotligh...EOS/index.html
suby723 is offline   Reply With Quote
Old 07-17-2016, 09:03 AM   #1640
Im about a page late on this, but I would not recommend sticky a$$ electrical tape for motor wires. Use snakeskin or heat shrink instead (or zip ties if you're out). And as for the ball cups, run a 3mm tap through them, the grease does practically nothing.
Omerta6 is offline   Reply With Quote
Old 07-17-2016, 09:21 AM   #1641
suby723's Avatar
Grease doesn't work but Chapstick is dialed.
Old 07-17-2016, 09:24 AM   #1642
Trader Rating: 14 (100%+)
Anyone running a 66t spur?
"Go that way really fast, if something gets in your way, turn"
TLR 22 3.5 SR, TLR 22-4 1.875, Sanwa M12S, Savox, Hobbywing, Schuurspeed, Protek
DG Designs is offline   Reply With Quote
Old 07-17-2016, 11:11 AM   #1643
Don't you need a left and right hand thread taps?
belewis01 is offline   Reply With Quote
Old 07-17-2016, 12:09 PM   #1644
AZJP's Avatar
Trader Rating: 20 (100%+)
Unreal how many people are struggling with ball cups. Chuck a tie rod in your drill and run it in and out a few times. An extra 10 minutes goes a long way. Do all your right hand cups first, switch drill to reverse and do the others.
AZJP is offline   Reply With Quote
Old 07-17-2016, 12:24 PM   #1645
Phillip F's Avatar
Trader Rating: 15 (100%+)
Anybody running a B6 on clay indoor track? (medium/high bite). I saw one guy running at my track and he was pretty quick. I gather if the gear diff is too sensitive for me... I can just get a ball diff.
Phillip F is offline   Reply With Quote
Old 07-17-2016, 01:29 PM   #1646
Suspended
Trader Rating: 61 (100%+)
Yep. Just get some cheap chinese RH and LH taps. I love them.
https://www.amazon.com/MIBRO-GROUP-7...ywords=3mm+tap
https://www.amazon.com/3mm-LEFT-HAND...rds=3mm+tap+LH
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 07-17-2016, 01:37 PM   #1647
Suspended
I'd start with the Kurt Wenger setup. I really liked how balanced it was.
It can be found here:
http://site.petitrc.com/setup/associ..._OCRC20160710/
Old 07-17-2016, 04:00 PM   #1648
awidz's Avatar
Default Spencer rivkin eos setup sheet?
Anyone know where I can find this, I just got my b6 and can only find cavaliers setup, ANY help would be appreciated. CavaLirI ran rear shocks in back of arm and rivkin ran them in front of arm. I want to put rivkin setup on my car.....thanks
awidz is offline   Reply With Quote
Old 07-17-2016, 04:01 PM   #1649
Suspended
It's no longer available on the AE website and PEtitRC direct linked to their website IIRC.
Old 07-17-2016, 04:14 PM   #1650
awidz's Avatar
Default ?
So it cannot be found?
Currently Active Users Viewing This Thread: 11 (6 members and 5 guests)
bobf24, jtodd57, Lenman73, lexusbest, RogerM, rubezzz
