    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree309Likes
Old 07-16-2016, 01:12 AM   #1576
Has anyone some more experience on the comparison between the B6D and B5m (FL) on loose clay with low/medium grip?
man1ac is offline   Reply With Quote
Old 07-16-2016, 01:38 AM   #1577
This car is faster and easier to drive than b5m lite. I'm on a b6d. I won my first rookie race at OCRC tonight on its maiden voyage. It's a keeper
Slash and used b5m lite didn't get it done for me lol
S2kDave is offline   Reply With Quote
Old 07-16-2016, 03:08 AM   #1578
Thanks, had a look at ocrc and that's not a loose clay track for me
But good to hear. I think the advantage of the B6 inincreases if the track has more grip...
Old 07-16-2016, 03:42 AM   #1579
GeorgePravata's Avatar
Trader Rating: 107 (100%+)
Ok so i sitting here putting together my nephews b6 it saids to use 2.5 toe in and 1* Anti Squat so that would be using the 0.5 pill now what about when using the Alum. D mount. We tried it with the stock D mount and put it on a Hudy set up gauge and the rear toe on the right was more then the left So we tried the stock D mount and the same Any help with this would be great Thanks
TEAM ASSOCIATED,REEDY POWER, AKA, TQ WIRES, SILLYBOYZ PRODUCTS.
GeorgePravata is offline   Reply With Quote
Old 07-16-2016, 04:30 AM   #1580
celt's Avatar
Other than being certain that both C-block pills are installed symmetrically, to maintain 2.5 toe, 1 anti-squat, put the center dot in the aluminum D-block.
The reference to remember is that:
center-dot on both the C and D blocks yields 3 degrees toe and 1 degree anti-squat. If you keep that in mind, you simply add or subtract values from that reference.
In your example, I have a B6 as well, (.5 out removes 1/2 degree rear toe) on the C-block and center-dot on the D-block, yields 2.5 degrees toe and maintains 1 degree anti-squat. Math checks out, all you need to remember is center-dot on both blocks = 3 toe. 1 anti-squat and adjust from there.
It gets confusing for some because with the alu D-block, you can also adjust values from there as well, whereas the plastic D-block is static at the center-dot.
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is offline   Reply With Quote
Old 07-16-2016, 04:40 AM   #1581
So if your looking at the .5 pill there is also a dot on it that dot will tell you where the hing pin is going to sit right. After looking at the book again we have the .5 pill in the right way but do I use the pill 0* to give me centerNow on the D mount I want to use the 0* pill for center
Old 07-16-2016, 04:43 AM   #1582
I've found a pic of BT b6 and he has a pic of the rear and his .5 pills the one on the right is standing up right so you see the 5 the right way on the left the .5 pill is not the same way giving him 3* toe
Old 07-16-2016, 06:02 AM   #1583
RCBuddha's Avatar
Trader Rating: 35 (100%+)
http://www.redrc.net/2016/07/jconcep...aero-wing-set/
RCBuddha is offline   Reply With Quote
Old 07-16-2016, 06:07 AM   #1584
RCBuddha's Avatar
Bezerk RC revised their battery strap prototype:
Old 07-16-2016, 06:16 AM   #1585
Phillip F's Avatar
Trader Rating: 15 (100%+)
Originally Posted by AZJP View Post
He's talking about rear toe.
Anybody here setups there front toe in with the RPM gauge? I remembered using those 15 years ago with my AE nitro stadium truck.
Phillip F is offline   Reply With Quote
Old 07-16-2016, 06:25 AM   #1586
eper's Avatar
Trader Rating: 14 (100%+)
Looks much better
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 07-16-2016, 06:26 AM   #1587
TAW
Trader Rating: 18 (100%+)
Send a message via AIM to TAW
I'm not too keen on the way the battery strap attaches, looks like we need a nut driver to remove the battery.
TAW is offline   Reply With Quote
Old 07-16-2016, 06:41 AM   #1588
Originally Posted by city.life View Post
My B6 with flat arms
Sweet rig. Did you take the paint off the AE aluminum shock caps? If so, how did you do it? I also like all the other silver bits!
dustneyes is offline   Reply With Quote
Old 07-16-2016, 07:27 AM   #1589
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
In that pic it definitely 'looks' odd but you need to pay attention to the dots. The hinge pin is moved further in by .5. Stock pin width is like the B5m with the GHEA +2 inserts. So you can alter it all quite a bit.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 07-16-2016, 07:54 AM   #1590
RCBuddha's Avatar
can someone post a picture of the exotek servo horn on their car?
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
