    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub View Post
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Like Tree311Likes
Old 07-15-2016, 11:12 AM   #1546
Quick question first...which hole is correct for rear inner ball stud mount on B6? Two different pics in manual, (middle/outer) and set up sheet different again. (Inner!!)
Re manual a few other things here too...and have checked online version and same as my printed copy.
A few screws haven't matched manual, but mostly I've found screws are a more useable/correct length in bags, wrong in manual. Good example steering ball joints...manual says 6mm, box had 8mm...6mm wouldn't allow for any spacers if you needed/wanted.
Good build though so far; I'm 2/3rds in.
andrewcoley is offline   Reply With Quote
Old 07-15-2016, 11:13 AM   #1547
aeRayls's Avatar
Originally Posted by wiggindude6969 View Post
what about for the rear springs? they come in sets.. soft, med and hard i think
The sets are so unnecessary. It comes with green rears. Pick up white and grey Maybe black. I've never needed anything else on dirt.
aeRayls is offline   Reply With Quote
Old 07-15-2016, 11:14 AM   #1548
Ok more on B6...
Steering build, rack build has 2mm spacer, set up sheet says zero.
Old 07-15-2016, 11:15 AM   #1549
aeRayls's Avatar
Just start with the middle hole. It's all going to get changed anyway when you tune to your specific track.
With the laydown in the B6d last week at Amain most of the team used middle hole with 2mm. Brent and a couple others tried the outside hole and I think stayed with it.
Test and try for yourself.
Old 07-15-2016, 11:16 AM   #1550
tsair's Avatar
Originally Posted by Wildcat1971 View Post
Weird, I did not have any screw issue for the B6D. I followed the manual and measured each screw before putting them in. I was missing one screw, but they had one in the "spares" bag. but, I opened several bags and dumped them into a parts tray, then measured and grabbed the ones i needed. I didnt specifically follow the bag number closely.
I just checked the B6D manual. Looks OK, screws look about right, but the B6 manual definitely has errors.
You're supposed to use M3x14's for the rear of the transmission into the rear camber block, B6 says M3x8, not sure M3x14's even got shipped with the kit, I used some M3x12's I had lying around.
Bottom of transmission B6D instructions are correct (4 M3x10, 2 M3x12). B6 is wrong (6 M3x12).
Razor RC blog:
http://razorrcblog.blogspot.com
http://youtube.com/c/RazorRC
tsair is offline   Reply With Quote
Old 07-15-2016, 11:16 AM   #1551
aeRayls's Avatar
Ok more on B6...
For the B6 start with 0
Old 07-15-2016, 12:32 PM   #1552
tropmonky's Avatar
Came here to check wiring pictures... instead just clicked through about 40 pages of the same fricking pictures of the build tips............
tropmonky is offline   Reply With Quote
Old 07-15-2016, 12:39 PM   #1553
Jmuck69's Avatar
here...
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 07-15-2016, 03:32 PM   #1554
abailey21's Avatar
Trader Rating: 36 (100%+)
Just finished wiring mine. I'm by no means good but i've found I don't like the battery strap or the waterfall for clean wiring.
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 07-15-2016, 04:57 PM   #1555
Jmuck69's Avatar
B6D | B64D
Old 07-15-2016, 06:18 PM   #1556
city.life's Avatar
Default B6
My B6 with flat arms
Official Team Associated B6 & B6D thread-img_5438_1600.jpg   Official Team Associated B6 & B6D thread-img_5439_1600.jpg   Official Team Associated B6 & B6D thread-dsc00391_1600.jpg
city.life is offline   Reply With Quote
Old 07-15-2016, 06:31 PM   #1557
Really good looking car, but just curious why did you take off all the blue anodizing ?
sgtlt is offline   Reply With Quote
Old 07-15-2016, 07:06 PM   #1558
jt409's Avatar
I personaly thank it Looks way better with out all the blue.
Mackinaker
jt409 is offline   Reply With Quote
Old 07-15-2016, 07:10 PM   #1559
suby723's Avatar
Trader Rating: 21 (100%+)
Wish they would have a black edition. I don't mind the blue though.
suby723 is offline   Reply With Quote
Old 07-15-2016, 07:19 PM   #1560
BRSracing's Avatar
Trader Rating: 53 (100%+)
I dig the blue, but if its not your color it would be pretty annoying
BRSracing is offline   Reply With Quote
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
