Like Tree9Likes
Old 07-29-2016, 09:13 PM   #76
fyrstormer's Avatar
I should clarify, I was thinking of *hardened* steel, like what MIP uses for their driveshafts. I see nothing wrong with using mild-steel or titanium turnbuckles to make adjustable upper links. I think they would be more useful if the upper links had more than one mounting point on the main chassis, though.
Also, turnbuckles for the steering links would be a good idea. I should swing by the shop tomorrow and see if I can scrounge up parts to make a set. No vehicle ever suffered for having adjustable toe-alignment on the front wheels.
Check out Fyrstormer's Garage in the Chat Lounge.
fyrstormer is offline   Reply With Quote
Old 07-30-2016, 05:39 PM   #77
croracer's Avatar
what alum servo arm will fit the one from a 22 or 8ight vehicles.
AMR ENGINES, KO PROPO RR, BONES BREW FUEL, PROLINE, MUGEN MBX7TR MBX7R, OS SPEED SPEC 2 TY TESSMAN, OS SPEED B2102, NINJA B04
croracer is offline   Reply With Quote
Old 07-30-2016, 08:26 PM   #78
fyrstormer's Avatar
Y'know, I can't seem to find the one I used online. The one from the 22 should fit fine though. Just get the 23-spline one if you're going to use the stock servo.
Old 07-31-2016, 09:46 AM   #79
DerekB's Avatar
VRC Mag's quick video review.
+ YouTube Video
Velocity RC Magazine
www.vrcmag.com
DerekB is offline   Reply With Quote
Old 08-01-2016, 03:08 AM   #80
Default Losi Baja Rey
I love the look of this Trophy truck. But Losi has a seroius issue with the rear diff. This is my second attempt to repair the weak link. Some are saying its a diff bearing. But I believe the 3rd member diff case should be made from aluminun and shimmed properly. The gear mesh is sloppy from stock. Its Sad to spend this money and not able to overcome such an issue. Anyone having samilar issues. Its lasting me about 7-8 battery cycles on 2 cell before it blows.
Sammy built is offline   Reply With Quote
Old 08-01-2016, 06:56 AM   #81
DEADWright's Avatar
Yes. I lost the inner pinion bearing on my second or third batt. I attributed it to the fact that the ring/pinion had no lube. Gear housing was dry. A new bearing and some grease and so far so good until I lost the center diff gear case due to heat,melted and deformed loosing gear mesh. An alum center diff housing and alum rear axle center section with larger bearings for the pinion would be nice.
DEADWright is offline   Reply With Quote
Old 08-01-2016, 02:12 PM   #82
fyrstormer's Avatar
I've been beating the crap out of my Baja Rey with no issues. If your ring and pinion gears were dry, that's a bad thing; they should be greased with lithium grease or marine grease, nothing silicone-based. The center gearbox gears should also be greased, and the center diff should be filled with thick silicone oil to limit how much it diffs-out; too much diffing-out will build up a lot of heat.
My diffs didn't need shimming. I added shims anyway, but I had to be very careful because the ring and pinion gears were meshing very close already; when I tightened the diff cover into place, the ring and pinion gears started binding and I had to remove almost all the shims I'd added.
I think most of the problems people are having with the drivetrains on these trucks are the result of improper assembly at the factory, not design flaws. Metal gears should not run dry and should not be lubricated with silicone; silicone doesn't provide enough lubrication for metal parts, and it's also very sticky which adds a lot of drag and makes parts heat-up faster.
Old 08-02-2016, 04:31 PM   #83
Out of the box these trucks will need some preventative maintenance. I would suggest if anyone buys one to re-grease the diffs. I can agree its lacking in that part. I just finished putting my truck back together. Luckily it was just a bearing that went out this time. I did install 2 shims behind the pinion gear. And must say it feels better clearance then the 1st time I rebuild her. Went thru 2 battery packs on 2 & 3 cell and it feels great. The bearing that slips on the diff behind the pinion gear are not the best. Maybe an upgraded and more quality bearing is needed any suggestions?
Sammy
Old 08-03-2016, 04:35 AM   #84
fyrstormer's Avatar
Hard to go wrong with Boca bearings. I like their Yellow Seal stainless/ceramic bearings because they never rust, but as small as the pinion bearings are on this truck, I might actually break from tradition and get Boca Green Seal chrome-steel bearings instead, because the chrome-steel races are harder.
IF RPM IS LISTENING, I THINK THERE'S A MARKET FOR A REAR DIFF BULKHEAD THAT ACCEPTS A 5x13mm INNER PINION BEARING. *cough*
Old 08-04-2016, 08:06 PM   #85
croracer's Avatar
so before 1st run, grease the rear diff, change servo arm alum?
Old 08-05-2016, 04:38 AM   #86
Seems that way. I haven't check the rear diff on mine yet. I did install the aluminum servo horn. I would most likely still be on the stock if I hadn't had the bad landing. But it does seem to drive better.
Billy Kelly is offline   Reply With Quote
Old 08-06-2016, 01:43 AM   #87
The front factory servo horn seems to give problems early on. I ve replace mine with the tlr 1557 aluminum servo horn. I ALSO upgraded to the Savox servo and steering is awesome!
Old 08-06-2016, 05:50 AM   #88
I can deal with the stock servo for now. Not great but ok for how I drive. Too early for me to replace it without having problem. I used the TLR 22 servo horn. This I did feel differece with.
Old 08-06-2016, 09:43 AM   #89
fyrstormer's Avatar
I replaced the servo, the servo horn, the receiver, and the ESC all at the same time, after several runs. It's just enough of a pain in the ass to get in there that I didn't want to do it three times. (doing it twice was unavoidable because I had to grease the center gearbox and the front diff early on, and they are inside the rollcage.) I'll probably change the motor to my preferred brand eventually, but there's no rush because the stock motor works fine.
Remember I posted a diagram of which screws to remove to take the rollcage off in one piece, back on Page 4. Otherwise you could end up taking the whole damn thing apart trying to figure out how it comes off.
Old 08-06-2016, 02:52 PM   #90
Trader Rating: 20 (100%+)
Default Noise from gear box
Are your trucks loud from gear noise mine seems much louder after I cleaned and lubed the gears?
Sjones is offline   Reply With Quote
