Like Tree9Likes
Old 01-20-2017, 11:07 AM   #301
Just got call from Metal Concepts. Getting shipped today.
Billy Kelly is offline   Reply With Quote
Old 01-20-2017, 04:34 PM   #302
Originally Posted by RCUK View Post
I haven't had any issues since shimming and replacing with Boca Yellow bearings
Forgive my ignorance, but can you explain how your do the shimming?
skeeler is offline   Reply With Quote
Old 01-21-2017, 07:23 AM   #303
If you add a shim (or washer) where shown by the red arrow (i.e. inbetween the face of the bearing and the back of the pinion gear, it will press the gears more tightly together and reduce movement overall). A judgement call on how thick the shim should be to avoid too much pressure on the gears. I am not 100% sure it is necessary but I was playing around when rebuilding.
RCUK is offline   Reply With Quote
Old 01-21-2017, 04:06 PM   #304
fyrstormer's Avatar
Generally speaking you want to shim the gears as tightly as you can without feeling the teeth bind together as you rotate the gears by hand. In some especially high-power applications you'll want to go ever-so-slightly tighter than that, because the diff case will flex under high loads and the gears will separate slightly.
Check out Fyrstormer's Garage in the Chat Lounge.
fyrstormer is offline   Reply With Quote
Old 01-22-2017, 07:23 AM   #305
Cool. Thanks for the info in shimming the drivetrain.
Old 01-22-2017, 06:20 PM   #306
Does anyone know if you can buy the drive shaft pin screws without buying a driveshaft??
novajustin is offline   Reply With Quote
Old 01-22-2017, 08:40 PM   #307
Also, can you suggest shims/washers of the appropriate dimensions?
Old 01-23-2017, 04:41 AM   #308
fyrstormer's Avatar
I use Kyosho shims because they come in packs of 0.1mm, 0.2mm, and 0.3mm thicknesses. The ones you'll need for the pinion shaft are 5x7mm. I think the ones you'll need for the diff itself are 10x12mm, but can someone verify I'm remembering correctly?
Old 01-23-2017, 05:31 AM   #309
Thanks.
Old 01-23-2017, 05:42 AM   #310
If you can find the size. Then yes there is a chance. Other brands also use them. I don't know size. Did see it listed. When I replaced center rear drive shaft. Screw was stripped. Had to grind it out.
Old 01-23-2017, 07:31 AM   #311
fyrstormer's Avatar
The screw-pins are a standard Vaterra part, you can find them easily.
Old 01-23-2017, 08:13 AM   #312
Thank you!! I think these are the same ones
https://www.rcplanet.com/Vaterra_Scr.../vtr246001.htm
Just saved me $30! Somehow one of the screws backed out even though I had used Loctite when I put it back together.
Old 01-23-2017, 08:23 PM   #313
fyrstormer's Avatar
Yes, those are the same ones.
Old 01-24-2017, 05:41 AM   #314
Arrived far quicker then expected. I usually don't buy bling stuff for my truck. But figured I give this a try.
Old 01-24-2017, 11:43 AM   #315
Rascalbum's Avatar
Hello all,
I relatively new to the hobby and picked up my Baja Rey about 4 weeks ago. So far I've enjoyed the truck in stock form other than the noticeable steering issues that will be addressed shortly with a better servo and aluminum steering horn. I will say however that in comparison to my other truck the rey seems to reverse extremely slow, practically at crawling speed. Is this a common issue or is this something I may have overlooked in my transmitter settings when I bound it to the truck? Currently running a spectrum DX4C transmitter and the truck on a 2s 5000mah lipo.
Rascalbum is offline   Reply With Quote
