Like Tree9Likes
Old 11-17-2016, 05:03 AM   #211
ptracer13's Avatar
Couple pictures of my 2wd conversion.
Official Team Losi's Baja Rey Thread-img_0442.jpg   Official Team Losi's Baja Rey Thread-img_0443.jpg   Official Team Losi's Baja Rey Thread-img_0433.jpg
ptracer13 is offline   Reply With Quote
Old 11-17-2016, 01:20 PM   #212
fyrstormer's Avatar
Do you have a plan to compensate for the lack of rear weight bias which is generally required for RWD RCs to handle properly?
Check out Fyrstormer's Garage in the Chat Lounge.
fyrstormer is offline   Reply With Quote
Old 11-17-2016, 02:38 PM   #213
ptracer13's Avatar
No
Old 11-25-2016, 04:08 PM   #214
Going to try the Boca ceramics in the rebuild and see if they do any better
RCUK is offline   Reply With Quote
Old 11-26-2016, 01:17 AM   #215
fyrstormer's Avatar
They should. I've always had good experiences with Boca's ceramic bearings.
Old 11-27-2016, 11:30 AM   #216
Default Changing front drive shaft.
So I was tearing down the Rey before I gave it its first run just to make sure stuff was nice and tight and found out that the front driveshaft is bent. I ordered a new one but need to know if I have to pull off the whole front end to get to it? Any help would be appreciated thank you.
Subwire is offline   Reply With Quote
Old 11-27-2016, 02:04 PM   #217
fyrstormer's Avatar
It's been a while since I've had to work on mine, but I think removing the center gearbox will be easier because you don't have to futz with the steering assembly.
Old 11-29-2016, 08:00 AM   #218
monsterbrad's Avatar
there is a way to straighten that drive shaft
monsterbrad is offline   Reply With Quote
Old 11-29-2016, 04:51 PM   #219
Wicked's Avatar
Can someone lmk the battery compartment size?
Baja 5B Flux, Baja 5T, HPI Savage Flux XL, Brushless Erevo, Summit, X Maxx, Arrma Big Rock, Tamiya Bruiser, & Hi lux, Slash, Skully,
Blade 200qx, Inductrix 200, Nano qx2 fpv, Cx, Proto X SLT
Wicked is offline   Reply With Quote
Old 12-03-2016, 10:53 PM   #220
I found i had trouble with the bearings in the rear diff... Couldn't handle a 3s with only about 4 uses. Overheated, seized then melted the diff housing. Luckily there was no damage to the diff gears. Have you found an alloy upgrade yet?
Originally Posted by Sammy built View Post
I love the look of this Trophy truck. But Losi has a seroius issue with the rear diff. This is my second attempt to repair the weak link. Some are saying its a diff bearing. But I believe the 3rd member diff case should be made from aluminun and shimmed properly. The gear mesh is sloppy from stock. Its Sad to spend this money and not able to overcome such an issue. Anyone having samilar issues. Its lasting me about 7-8 battery cycles on 2 cell before it blows.
Official Team Losi's Baja Rey Thread-15318014_10211513567184808_4178289479301155905_n.jpg
sirweasle is offline   Reply With Quote
Old 12-04-2016, 09:52 AM   #221
Work in progress following rear diff rebuild and bearing replacement throughout...
... there is a Metal Concepts solid rear axle TT10 but I have only seen online.
Official Team Losi's Baja Rey Thread-img_2144.jpg   Official Team Losi's Baja Rey Thread-img_2143.jpg   Official Team Losi's Baja Rey Thread-img_2142.jpg   Official Team Losi's Baja Rey Thread-img_2106.jpg
Old 12-04-2016, 10:42 AM   #222
We're did you get those wall mounts? I really like that idea
Malazan is offline   Reply With Quote
Old 12-04-2016, 11:54 AM   #223
They look like TV mounts. I've seen others using wooden rods before.
Billy Kelly is offline   Reply With Quote
Old 12-04-2016, 12:18 PM   #224
yes - they are DVD mounts. "AMOS DVD Wall Bracket" from Amazon. You can adjust the width of the arms which is useful.
Old 12-04-2016, 12:36 PM   #225
Is anyone making upgrades yet , like vanquish or ssd
