Like Tree9Likes
Old 10-06-2016, 01:10 PM   #181
ptracer13's Avatar
If this was that big of an issue why won't they make a recall?? I have been very fortunate with mine and I beat the crap out of it on 2s and other than bearing failure that I have fixed with better bearings I have not had any issues with my drivetrain... (knock on wood)..
ptracer13 is offline   Reply With Quote
Old 10-06-2016, 01:43 PM   #182
Originally Posted by DEADWright View Post
The front diff has been a problem for me also. I'm waiting to see if the aftermarket comes out with anything to fix. In the meantime,my BR sits broken.
If you want an RC that will allow you to run battery after battery and not break with only some maintenance every so often,the first one in my sig is it.
I no longer expect much from the aftermarket part of hobby. If something comes out great. But I don't get hopes up. Too many vehicles have been ignored of past 3-4 years.
No issues with front diff or rear bearing. Haven't run in awhile. Kinda lost spots once schools started up. And getting dark earlier.
Billy Kelly is offline   Reply With Quote
Old 10-07-2016, 08:36 PM   #183
ptracer13's Avatar
Ring and pinions on back order till dec, that's all....
Old 10-08-2016, 07:21 AM   #184
croracer's Avatar
has anyone tried the HD diff, and internals and was it better? it seems like mine is hard to get traction with the stock locker set up, on my loose track conditions.
AMR ENGINES, KO PROPO RR, BONES BREW FUEL, PROLINE, MUGEN MBX7TR MBX7R, OS SPEED SPEC 2 TY TESSMAN, OS SPEED B2102, NINJA B04
croracer is offline   Reply With Quote
Old 10-08-2016, 07:37 AM   #185
DEADWright's Avatar
HD diff?
Tekno SCT410,EB48.3,ET48.3
DEADWright is offline   Reply With Quote
Old 10-08-2016, 07:40 AM   #186
croracer's Avatar
HD diff?
https://images.amain.com/images/larg....jpg?width=475
Old 10-08-2016, 08:51 AM   #187
DEADWright's Avatar
Been a while since I had mine apart, whats the difference between that and the stock one?
Old 10-08-2016, 08:55 AM   #188
croracer's Avatar
I'm not sure if it's just a replacement for stock. I haven't taken my apart but the Manuel show the rear diff has a locker in it? I'm not sure. Or if it's a Upgrade from stock
Old 10-08-2016, 09:13 AM   #189
ptracer13's Avatar
The stock rear diff has a locker/ spool. The front and middle have gear diffs.
Old 10-08-2016, 11:04 AM   #190
croracer's Avatar
could you use the regular gear diffs in it? rear
Old 10-08-2016, 11:13 AM   #191
wrightcs77's Avatar
Trader Rating: 521 (100%+)
I think they fit, but not sure how the axle shafts would mate with the internal sun gears...
wrightcs77 is offline   Reply With Quote
Old 10-08-2016, 10:02 PM   #192
ptracer13's Avatar
Exactly, the gear diff would fit but the axles wouldnt mate with it. The axles have a square end that goes into the spool/locker. So I guess the answer is no.
Old 10-09-2016, 07:21 AM   #193
fyrstormer's Avatar
It's easier to drive with a locked rear axle anyway. Unlocking the rear axle would cause massive torque steer.
Check out Fyrstormer's Garage in the Chat Lounge.
fyrstormer is offline   Reply With Quote
Old 10-10-2016, 11:07 AM   #194
Default Work in Progress
A few Pics of the Evolution.
Official Team Losi's Baja Rey Thread-img_2224.jpg   Official Team Losi's Baja Rey Thread-img_2225.jpg   Official Team Losi's Baja Rey Thread-img_2226.jpg   Official Team Losi's Baja Rey Thread-img_2227.jpg
OW RC is offline   Reply With Quote
Old 10-10-2016, 06:40 PM   #195
fyrstormer's Avatar
I noticed a squeak that started mid-run today and got slightly more prominent by the end of the run. I may have another failing diff pinion bearing. I ended up using another cheap bearing when I replaced the first one that failed, because I didn't have the fancy ceramic bearings I wanted to use in the size I needed. Shimming the rear diff pinion propshaft seems to be helping it, whereas the front diff pinion propshaft is getting a little wobbly, so I suspect it's the front diff pinion bearing that's failing this time. I didn't notice drive cup being hot after the run, unlike when the rear diff pinion bearing failed, so maybe it's still fine, I dunno.
