Like Tree9Likes
Old 09-09-2016, 11:25 PM   #136
Ok thanks for answering my that. Anyone happen to know what length shock fits in the rear secondary mounts? Thinking about getting a set of hot racing shocks with fake remote resis and should help with dampening if I run 45 in the stock shocks and maybe 30 in the 2nd shocks.
Expo_cam is offline   Reply With Quote
Old 09-10-2016, 08:53 AM   #137
RC Bombshells's Avatar
Trader Rating: 143 (100%+)
Default RC BOMBSHELLS MONSTER BAJA REY
Here are some glory shots inside the scale garage at SKRD (SIK RIDES) in Las Vegas. This project was a perfect opportunity to show what RC BOMBSHELLS could put together with a fusion of paint, vinyl and matte finish on a scale build sure to please everyone. Don't ask me about the garage, It's awesome all hand built and that lift was a one-off thing the guys won't make another. #rcbombshells
R/C BOMBSHELLS Custom Paint by Rocco
www.rcbombshells.com
www.facebook.com/rc.bombshells
RC Bombshells is offline   Reply With Quote
Old 09-10-2016, 12:30 PM   #138
wrightcs77's Avatar
Trader Rating: 517 (100%+)
Awesome
wrightcs77 is offline   Reply With Quote
Old 09-11-2016, 07:45 AM   #139
DEADWright's Avatar
Those Method bead locks look great. They are 2.2 wheels but have to be pushed out to clear the suspension. Looks like they would beat the body up with any real use.
Tekno SCT410,EB48.3,ET48.3
DEADWright is offline   Reply With Quote
Old 09-11-2016, 07:10 PM   #140
I picked up a cheap light bar and turnigy fan set for the motor. The light bar they had at the hobbystore was almost exactly the width of the support beams of the upper roll cage, that let me mount it right on. I took off the metal side supports and replaced them with a long piece of black HDPE cut to bolt onto the sides of the LED bar and both bolt holes of the upper cage. It's not going anywhere now, still fits the body fine, and is super flexible in case I crash it. Great!
It seemed like an associated XP light bar, but it didn't have any branding on the package. Still thinking about how I want to do the break lights.
ltzerge is offline   Reply With Quote
Old 09-12-2016, 08:05 AM   #141
monsterbrad's Avatar
still wish there was enough people in my area to get a bunch of these on the track.
Stock with whatever electronics you want and just run them.
No special anything just race for fun.
monsterbrad is offline   Reply With Quote
Old 09-12-2016, 08:46 AM   #142
I'd be good just to see another one run in person anywhere. I've bought only one store sold.
Billy Kelly is offline   Reply With Quote
Old 09-12-2016, 05:49 PM   #143
OK I was at work today so I was able to use the CNC machine. I fabricated a rear brake light bar out of a 3 LED board and some black HDP. I then cut and sanded the body to create an opening for it. The board is sandwiched between two plates with an in-depth cutout and a sheet of red tinted lexan. Pops right in, and like the other light bar it fastens to the chassis.
Old 09-12-2016, 09:10 PM   #144
fyrstormer's Avatar
I think people are turned off by the price. $450 up-front is hard to swallow; people would rather spend $200 on an RTR and $350 on upgrade parts.
Check out Fyrstormer's Garage in the Chat Lounge.
fyrstormer is offline   Reply With Quote
Old 09-13-2016, 04:14 AM   #145
DEADWright's Avatar
$450 up front and still needing upgrades is like buying a Slash. Problem is for the Baja Rey,the upgrades don't exist.
Old 09-13-2016, 05:51 AM   #146
That may be true about the up grade parts.
However running a truck for what it is can be just as fun as modding something.
Been at this for 20 years and I have had the most fun with stock stuff like the yeti trophy geared up a bit.. Hold the throttle down and watch it work.
These trucks are awesome replicas of the real thing.
Those of us crazy about CORR trucks can't get enough.
Old 09-13-2016, 06:08 PM   #147
ptracer13's Avatar
$450 is actually a great price for this machine, most decent bashers are all around that price point.
ptracer13 is offline   Reply With Quote
Old 09-13-2016, 10:02 PM   #148
fyrstormer's Avatar
The only things that are actually deficient in the stock build are the undersized diff pinion bearings and plastic servo horn. Everything else works as intended. If you want a truck that jumps 20 feet and does a double-backflip before landing, that's a different issue.
Old 09-13-2016, 11:06 PM   #149
ptracer13's Avatar
The servo horn is the underlining to the weak servo. Can't expect much from a rtr servo. The bearing size is fine, the quality of the bearing is what sucks. I upgrade my pinion bearings and they have not been an issue at all.
Old 09-14-2016, 06:55 AM   #150
RTR bearings are always kinda iffy
you either get good ones or not.
The pinion bearings in this kind of set up take a huge amount of abuse.
