Old 12-16-2005, 02:45 PM   #1
Default Weird servo problem!
Just got a Helios EX-10 with the Spektrum module. i was having glithing problems with my old XR3i..
Well got every thing installed in my xxxt MF1, and then the steering servo went wild! i can control it very well, but when it returns to neutral, it stars to freak, going left to right in rapid succesions... now ive tried the same servo with my old futaba t6xa, and it works fine, i put my XR3i back, same old glitching problems that i tried to resolve with the new controler...
anybody has some ideas???
Xular is offline   Reply With Quote
Old 12-16-2005, 06:03 PM   #2
what servo do you have?
It's glitching with the Spektrum module and receiver?
briansid is offline   Reply With Quote
Old 12-16-2005, 08:01 PM   #3
mattxxx-nt's Avatar
i have a servo problem too.
when i start my truck sometimes, the throttle servo will open to full. it has done that a couple of times.
my steering servo is glitching. i drive it in a line and whenever i let off the throttle, it will start to turn left and right uncontrolably.
does any one know anything about the team losi xxx nt sport rtr 2 ball diff.
if u do, could u pm me
mattxxx-nt is offline   Reply With Quote
Old 12-16-2005, 11:58 PM   #4
fhm101's Avatar
On the Losi MF truck. Do you have your receiver mounted with a double layer of servo tape? Also, make sure the antenna wire is not touching the chassis at all. Also make sure you have the foam liners in your battery tray so none of the cell ends are touching the chassis.
fhm101 is offline   Reply With Quote
Old 12-17-2005, 11:20 AM   #5
my servo is a system 2000 super hi torque metal gear BB TS-71 (couldnt find any info on this servo on the net btw).
and thanks fhm101, i had to grind the chassis so my batery would fit in there... so ill have to add some protection in there.. although all my bateries have some electrical tape all around them so the battery bars and cell ends are protected.
I also tried with a futaba S3003 and the effect is the same...
Servo problem ???WTF Please TRFTIM Electric On-Road 1 11-20-2006 02:03 PM
ESC or SERVO Problem kimbalion7 Electric On-Road 4 02-02-2006 03:27 AM
weird problem vectra Electric On-Road 2 09-08-2004 04:26 PM
Weird power supply problem micros_rock Electric On-Road 9 07-29-2004 12:20 AM
weird ko propo servo problem VenomWorldOrder Australian Racing 6 01-09-2003 02:21 AM
SEO by vBSEO 3.5.0
